Lighter Flywheel.
Old Nov 11, 2005 | 08:59 PM
kamski's Avatar
.org extraordinaire
Lighter Flywheel.
Anyone use this yet?
With a UDP and a lighter flywheel teh VQ35 would scream up and down. What do you guys think? Worthy investment?
http://performancenissanparts.com/ca...oducts_id=5833
Peace,
Kam
Old Nov 11, 2005 | 10:46 PM
DeusExMaxima's Avatar
I think it is very worthy. I lvie near Performance Nissan and I have bought many parts from them for my former Spec V and my present Maxima. I talked to a guy in the parking lot who had a 350Z with lightened flywheel and he said it really made a difference in the way the engine revved. I also know from my racing experience that lightened flywheels work. When my clutch needs replacing, Im getting a lightened flywheel. Remember, when you lighten rotating mass, its like losing 3-4 times the actual weight of the item. If your flywheel is 15 lbs lighter, than its like losing 45 lbs or so off the car in dead weight.
Old Nov 11, 2005 | 11:17 PM
chernmax's Avatar
Nations 1st 6th Gen Turbo
Before I drop another flywheel I'll wait for my warrenty to expire. That would be the fourth thing on my list besides Headers, Super Charger and upgraded ECU.
Old Nov 12, 2005 | 04:46 AM
SKnucks's Avatar
What does it do to the mileage???
Old Nov 12, 2005 | 10:34 AM
There was a thread on the mileage as it pertains to a lighter flywheel.
Old Nov 12, 2005 | 12:07 PM
UK-nissan's Avatar
It depends upon the gear you are in.
The effective radius of the weight removed makes a difference too.
Assume 10 lbs removed at a radius of 5", and a 12" radius of the driven tyre.
Also assume a gear ratio of 14:1 in first.
That combination would give you 10x14x5/12 =58 lbs "lighter"
And the benifit is less in the higher gears.
Old Nov 12, 2005 | 02:26 PM
kamski's Avatar
.org extraordinaire
What does all that mean??
Old Nov 12, 2005 | 07:19 PM
bluemaxx's Avatar
Moderator GT-R
It means if you're installing a light flywheel you probably don't give a **** about milage.
Old Nov 12, 2005 | 07:35 PM
ColdSHO's Avatar
i noticed a gain in mpg on my car once i got my fidanza installed, i knwo i have a vq30 but i doubt that would make much of a difference
Old Nov 12, 2005 | 09:45 PM
chernmax's Avatar
Excellent point!!!
Old Nov 13, 2005 | 12:26 AM
UK-nissan's Avatar
I just went through the maths for you so you would be able to work it out for your flywheel, and used some numbers that are close to real life.
If you remove weight from the rim of the flywheel it makes more difference to the butt dyno than if you remove the same weight from the center of the flywheel.
You cant remove too much weight from the rim because that is where the ring gear is that the startermotor drives against.
For a typical lightened flywheel you are looking at the equivalent of shaving 50-100lbs from the car in first gear, steadily reducing to 10-25lbs off in Top gear.
Mike
Old Nov 15, 2005 | 12:08 PM
kamski's Avatar
.org extraordinaire
Mike
So basically the engine goes VROOM VROOM alot quicker?? But how does that increase you gas mileage?
Kam
Old Nov 15, 2005 | 12:47 PM
RHMax's Avatar
Newbie just Registered
Kam
I'm not sure it does help. I think MPG will suffer since you would need to rev higher to get the car moving, and can't lift while criusing.
Old Nov 15, 2005 | 12:59 PM
blakstarz's Avatar
I think I read in a previous post somewhere, that installing this is a pain and it's a rather pricey installation job....is that true?
Old Nov 15, 2005 | 02:44 PM
Glude's Avatar
Im sure it is. If any of you have a UDP, the lightweight flywheel would be similar but would be felt a lot more. I dont think it adds power, just revs quicker. I have heard that its harder to drive and not really worth it unless you track the car.
Old Nov 15, 2005 | 04:56 PM
Longhorn1's Avatar
Anyone know how long we can expect the clutch that came with our manual shift maximas to last? Is it something every manual car will have to replace at some point in it's life? You all know a lot more about cars then me. Thanks!
Old Nov 15, 2005 | 07:46 PM
Depends on how u drive. If u drive a lot of highway miles, than it lasts more miles. If u do "jackrabbit" starts, it could go out very quickly. And who really gives a shzit about mileage. The feeling of a light flywheeel and revvy engine is worth it.
Old Nov 18, 2005 | 10:26 AM
kamski's Avatar
.org extraordinaire
soo...............
with a lightened fly wheel and udp this thing should be as peppy as a jack rabbit on steroids and viagra?
Kam
Old Nov 22, 2005 | 10:44 AM
jasonjm's Avatar
You should ask (i think it was Jason) at Perf. (if he's still there) about the flywheel/clutch combo he had on his 350z (before he sold it)...(hm...those where the days...sigh). WHOA. SO MUCH power throughout the band. It may have only gained 1hp "Peak" but the midrange power boost felt like 50hp increase. There might still be videos. If not I'm sure i might still have it.
OH yeah, trade off is that it was very hard to drive. Might take a week to learn it. At that early time you could only buy the crazy Tilton clutch whose engagement point was very very tight. Since then there have been a few more clutches that are compatible with the extremely lightweight (7 lbs) flywheels.
Old Nov 22, 2005 | 12:50 PM
kamski's Avatar
.org extraordinaire
lemme see some pischtures.,
Kam
Old Nov 22, 2005 | 10:31 PM
Maxima2006SE's Avatar
cool thing
Old Jul 14, 2006 | 02:46 PM
kamski's Avatar
.org extraordinaire
Originally Posted by Maxima2006SE
cool thing
So are there actual lightened fly wheels for the 6thGEN? This is where guys like SR20DEN should chime in..
Kamski
Old Jul 14, 2006 | 04:04 PM
MisterSparkle's Avatar
yea they have em...
Old Jul 14, 2006 | 04:39 PM
kamski's Avatar
.org extraordinaire
Originally Posted by MisterSparkle
yea they have em...
k, back urz wurdz up wiz some info, G.
Sorry, my ebonics iz outz of date, fo shizzle.
Kam
Old Jul 14, 2006 | 06:53 PM
Kamski: U can score lightened flywheels at lots of places. I think Performance Nissan has them, and Jim WOlfe too. Google it, bro!!!
Old Jul 14, 2006 | 08:41 PM
kamski's Avatar
.org extraordinaire
I know I see them online all the time but they are for the RWD VQ engines, and I read in other threads in the All motor section that the teath have to be cut and such other retardation. I just wondering if there is a direct bolton/replacement that will keep our final drive ratio on the 6sp on the 6gen.
Kam
Old Jul 14, 2006 | 09:08 PM
The final drive isnt affected by changing ur flywheel. There are bolt ons. I was just looking at them the other day, but I dont recall the website. They are out there for sure.
Old Jul 14, 2006 | 10:24 PM
Glude's Avatar
I think fidanza makes one for the 5.5 gen, I don't see why that one wont work.
Old Jul 16, 2006 | 05:59 PM
By the way, I am planning this mod when my clutch wears out.
Old Jul 16, 2006 | 06:09 PM
Glude's Avatar
That will probably be a while, the clutches on these cars are pretty strong.
Old Jul 16, 2006 | 10:56 PM
Not when u have taught two teenagers to drive stick shift, hehe
JRod28
Feb 4, 2016 11:07 AM
Violator
Sep 9, 2015 10:14 AM
sc10692
Aug 9, 2015 09:37 AM
Jeff92se
Nov 1, 2001 12:14 AM
Black VQ
Feb 11, 2001 09:10 PM
