My brakes are driving me crazy
Old Dec 1, 2005 | 06:26 PM
kdejour's Avatar
http://www.cardomain.com/my/ed
About two weeks ago my car started to make a high pitch noise almost like a cricket but it is constant. I narrowed it down to the brakes. My rear brake pads were worn down a bit but it wassn't metal to metal. I changed the rear brakes I used raybestos pads on it since I am plannig on moving up to drllied and slotted rotors when the weather breaks again. The noise is still there. I changed the front breakes today also. I am still getting the noise. I put that petroleum jelly stuff on all my contact points. My car has about 33000 miles on it. Please don't make fun of the pads I already know I could have done better. I just want to make it through the winter. My rotors arent warped that I can tell.
Old Dec 1, 2005 | 06:53 PM
maximob's Avatar
I'm not an expert, but it sounds like maybe something got caught between the rotor and the shield behind it.
Old Dec 1, 2005 | 07:41 PM
tony g's Avatar
hey i had something like happen to one of my car if u take the pad and put an edge on the ends of each pad u know (taper) the pad that should help pervent the squealing it worked for me and i taked to a few techs and they told me it works and it worked for me they say the thing that causes the noise is the dust between the pad a rotor cuz the pad vibrats befor ti hits the rotor so the taper edges would help wiht the squeaking this should work for u let me know how it turns out
Old Dec 2, 2005 | 05:42 AM
kdejour's Avatar
How would I go about tapering the edges? It sure does sound like a good idea.
Old Dec 2, 2005 | 06:30 AM
CanadianMoFo's Avatar
Any sort of powered sanding device. Palm sander, belt sander, even a detail sander. You just want a slight bevel to the edge.
CM.
Old Dec 2, 2005 | 07:35 AM
tototee999's Avatar
when you replaced the brakes, did you turn the rotors? that would cause over heating of the brake pads, leading to galvanisation of the brake pads causing the high pitch squeaking..
just an idea..
Old Dec 2, 2005 | 02:44 PM
kdejour's Avatar
just an idea..
I didn't turn the rotors yet. I had not gotten any pulsating in the brakes or the steering shakes but maybe I will try that if sanding the pads doesn't work. I guess I will pull out the roto zip and sand it. Thanks for the advice I was thinking about getting them turned. That might be the answer cause they are really irritating me now. I will be out in the morning freezing a little but if the noise stops its worth it.
Old Dec 2, 2005 | 07:47 PM
tony g's Avatar
u cAN TAPER THE PADS WITH A GRINDING WHEEL
Old Dec 2, 2005 | 09:32 PM
kdejour's Avatar
Cool I have a grinding wheel. I guess it's good I have a bunch of tools. I guess it would be quicker than my roto-zip.
Old Dec 3, 2005 | 06:20 AM
Albert's Avatar
From my experience, I usually go with Bendix IQ pads for the front and OEM pads in the rear. For the front, the OEM pads sucks in terms of fading once they heat up during traffic jam. For the rear, since Bendix doesn't make an IQ version I stick with the OEM to avoid squeeling.
Old Dec 3, 2005 | 09:05 AM
xorbitman's Avatar
I had my brakes cleaned by my dealer cause I was getting a grinding noise. I am still getting the !@#$%^&*() grinding noise. Any Ideas?
Old Dec 3, 2005 | 11:46 AM
jasonjm's Avatar
Check wheel bearing.
Take out the pistons from the calipers. Clean them out, flush your system while your out there. Make sure to oil the pins, and check the lines.
Check master cyl pressure too.
Maybe this will help...
Old Dec 3, 2005 | 10:30 PM
xorbitman's Avatar
Thanks, I will keep you guys posted on the progress.
mvm062
Nov 30, 2020 09:00 AM
BkGreen97
Apr 2, 2016 05:47 AM
captchaos
Mar 15, 2016 12:18 PM
Maxima30
Sep 7, 2015 06:13 PM
crazyespn
Sep 3, 2015 01:30 PM
