Rattling noise near rear deck speakers
Sorry for posting this as I thought it was on here before but I can't locate it. Does anyone remember how to fix this problem? It sounds like something is loose near the speakers in the rear deck. It is beginning to drive me nuts. Any advice would be helpful on this.
it might be that or it may be the lining that is right above ur rear window, i had the same issue and still do, but will fix it soon, one of the clips may have popped out. and it may be the side plastic things that run across the rear window as well; stick a peace of paper in between it and the window and see if that helps
i found some rubber from a tire patch kit and used that. I basically cut two pieces out and put them against the deck and the plastic molding that go to the roof. I am hoping that will work but I won't know for sure until I head to work tomorrow. I'll keep you posted on whether that worked or not.
http://www.nissanhelp.com/Ownership/.../NTB03-066.htm
Justin Kroll
09-02-2015 11:06 AM
