Progress Sway Bar installed noises help
Old May 4, 2006 | 11:54 AM
MaxJ04's Avatar
like the title says i just had the bar installed yesterday and today i was driving with the windows up with no music and i hear some rumbling from the rear is that normal? i had it greased already is it supposed to be like this or not enough grease? thanks guys
Jun
Old May 4, 2006 | 11:56 AM
viguera's Avatar
Define "rumbling"
I definitely have never heard anything that sounds remotely like "rumbling" from the lack of grease. It was a definite "low pitch squeak" (if there is such a thing) and only when bouncing on a bump/dip.
Old May 4, 2006 | 12:04 PM
MaxJ04's Avatar
Originally Posted by viguera
Define "rumbling"
no squeaking is like a lower pitched noise as you go over a bump kinda thing kinda rumble ... sounds like it was coming from rubbing with the tires or something .. it dont' sound to be the middle of the bar more liek the ends of it do i make sense?
Old May 4, 2006 | 12:21 PM
viguera's Avatar
Well if it wasn't doing it before the bar, and it's doing it now, then chances are it's the bar...
Who installed that for you? Did you do it yourself? If you didn't, I'd say take it back and have them do it right...
Either way, from the way that you make it sound, it definitely sounds like the brushings. I know mine were so bad at one point that you could bounce the car (open the trunk and push the back up and down ) and you could hear them. It's more like an old mattress making noises than a rumbling, but if it started with the RSB, then that's probably what it is... unless you broke something installing it
Old May 4, 2006 | 01:22 PM
RHMax's Avatar
Newbie just Registered
Was it installed correctly? It would almost fit up side down.
Old May 4, 2006 | 02:48 PM
MaxJ04's Avatar
you could have it flipped up side down and it would be able to install? because my mechanic looked at it and he fliped it before he installed.
Old May 4, 2006 | 04:28 PM
RHMax's Avatar
You can make it kinda fit, but it will rub big time, if not damaged.
Old May 4, 2006 | 07:08 PM
MaxJ04's Avatar
ok i took a few pics of the install the original
i'll take it back tomorrow to see if it is correct by the pic?
and it went on there fine with no rubbing or whatso ever it fitted liek the original it wasn't upside down or backwards ... it seemed ok to me let me know thanks
Old May 4, 2006 | 08:14 PM
RHMax's Avatar
I don't remember who it was, but someone here had it installed upside down and had creaking noise when drove home. That's why I think your's could be upside down.
Old May 4, 2006 | 08:17 PM
MaxJ04's Avatar
i mean it can't be upside down or wahtever because it fitted fine with the stock one he aligned it perfectly before he put it in .. it could be my imagination but i think it needs to be settled in or something .. hope it won't fall out b/c i'm going to take a trip to syracuse tomororw and back ... i'll check with the mechanic tomorrow before i go just to make sure everythnig is ok ..
but you guys' can't tell from the pic? that is correct or not?
Old May 4, 2006 | 08:20 PM
RHMax's Avatar
Is the pic upside down or rightside up?
Old May 5, 2006 | 11:58 AM
madmik's Avatar
I put mine on a few weeks ago myself. I put some grease on the bar and the rest inside the bushing. They are kinda tight. Your pics look ok.
Its such a simple installation that I suspect you just need extra grease (unless the hand brake cable is caught on the bar or the bar is backward). Could spray silicone lube on the bushing but it may dilute the grease, not sure.
Old May 5, 2006 | 12:34 PM
Smooth's Avatar
I have to get under mine and check why its thumping..No squeeks just a thump and I went and tightened everything lastnight...it might be the P brake cable though
MaxLife17
Jun 27, 2019 01:37 PM
MaxLife17
Sep 8, 2015 02:36 PM
Johnny9595
Sep 3, 2015 05:18 AM
Justin Kroll
Sep 2, 2015 11:06 AM
Maxboy23
Aug 20, 2015 09:33 AM
