Headers....
Old Jun 19, 2006 | 08:57 AM
  #201
Puppetmaster's Avatar
Originally Posted by kamilkluczewski
Would it be possible to run APEXi AFC-II with a reflashed ECU from Technosqaure?
Only if you get the L-Spec...
Old Jun 19, 2006 | 08:59 AM
  #202
chernmax's Avatar
Nations 1st 6th Gen Turbo
Originally Posted by AllBlackMax
Hey Chern, you watch this clip yet?
Yes just saw it, sounds great but I would say mine has a deep sound but slightly different. Remember you VID was recorded inside a building so the sound is bouncing off the walls.
Old Jun 19, 2006 | 09:46 AM
  #203
Redmax's Avatar
Redlinemax Owner
AllBlackMax, The sound of his exhaust is Insane!!!!! From 5500 untill Redline the car opens wide up sounds like a beast. I was afforded the opportunity to beat the hell out of it on the test Drive and will tell you that the sound is nothing short of Amazing. I would slow down just so I could get enough room to go WOT.... Alot of fun.
Install was a Beyotch!!! Could you do the install in your garage? Maybe. Install time...2 days. I would recommend that anyone who wants to do this at home to put the car up on ramps and lay under the rear exhust manifold and see if you could manuever and work under there for sveral hours. I think not! Our hourly rate is 75. per hour. but we will charge 575. for the install.
Old Jun 19, 2006 | 10:27 AM
  #204
One comment on the design of the headers, Hotshot has done this on their headers for the 5th Gen too, and that is to leave the O2 bungs for the primaries high up on one collector tube. This is presumably done so that minimal work is required for you to use your stock O2 sensor wiring, ie. you don't have to extend the wires or harnesses to reach the bung.
Since the primary O2s influence your AF ratio (at least in closed loop driving), I still think the bungs for the primaries should still be down where the 3 tubes meet, so that the primaries can get an AF reading from all 3 cylinders on each bank as opposed to just reading the AF from a single cylinder on each bank. I guess at WOT, it doesn't matter anyways, and I don't know how big of a deal this really is, but just thought I'd post it for discussion's sake.
Old Jun 19, 2006 | 10:51 AM
  #205
chernmax's Avatar
More good news , Hotshot just emailed me back stating they will now honor the Header warranty for any 6th Gen Max installing them, at first when they thought it would not fit the 6th Gen they told Corey of RedLineMax the warranty would be void since we where going to do whatever it takes to make it fit. Since our install did not require modification of the Header all 6th Gen get the warranty like the Alti...
Old Jun 19, 2006 | 11:40 AM
  #206
UK-nissan's Avatar
The other reason to put it at the junction of the three primaries is that the lower temps there will let the O2 sensor last a lot longer.
Mike
Old Jun 19, 2006 | 12:19 PM
  #207
AllBlackMax's Avatar
aka The Doom Ship
I defintely gotta come check ya'll out when I get in the Maryland area. The only thing worse than installing those headers is the 20 hour drive from TX to MD. I do it one a year though.
Old Jun 19, 2006 | 12:20 PM
  #208
chernmax's Avatar
Mike
The two O2 sensors on the Hotshot headers are about 1" lower down the pipe on the header then stock. I know because we had to stretch the wires to reconnect.
Old Jun 19, 2006 | 01:14 PM
  #209
NmexMAX's Avatar
dot dot dot ...
Y no header wraps? I hear they work really well for the V8 F body cars in lowering temps
These might annihilate the flex section due to heat.
Old Jun 19, 2006 | 01:44 PM
  #210
chernmax's Avatar
OK the current plan is:
Corey "Redmax of RedLineMax" is going to contact the Dyno tuner for a Wednesday Dyno and Apex Tuning. (I have to be in upper VA that day on business but my schedule leaves my afternoon open to get it done) OK, then I will post numbers..
Second, on June 25th is the East Coast Nationals at Maryland International Speedway in Budds Creek, Maryland (www.mirdrag.com) and I will do 3- 1/4 mile runs and post my best time. Sound OK!!!
Old Jun 19, 2006 | 02:05 PM
  #211
kamski's Avatar
.org extraordinaire
SO how much for a night with your Maxi? Mr. Chernpimp?
Im curious about your Dyno, I predict 248whp.
Any bets?
Kam
Old Jun 19, 2006 | 02:18 PM
  #212
chernmax's Avatar
Any bets?
Kam
As much as I want to be a pimp, that title is owned by Ramberg and I'm not about to be disrespecting!!!
Old Jun 19, 2006 | 02:38 PM
  #213
aka The Doom Ship
Any bets?
Kam
My earlier prediction was kinda high(265). Looking at the Altima SE-R dyno with these headers I'm gonna have to go with 250-252whp.
Old Jun 19, 2006 | 05:16 PM
  #214
chernmax's Avatar
I'm gonna have to go with whatever it turns out to be...
Old Jun 19, 2006 | 05:59 PM
  #215
Glude's Avatar
Il say mid 240s, possibly 250 if its tuned real good.
Old Jun 19, 2006 | 06:08 PM
  #216
vsamoylov
230-240 whp is what i say
Old Jun 19, 2006 | 06:20 PM
  #217
bluestreakgts's Avatar
How much power does it give?
Old Jun 19, 2006 | 06:43 PM
  #218
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
thats my guess right there...
Old Jun 19, 2006 | 06:46 PM
  #219
chernmax's Avatar
I'm guessing.........................
Old Jun 19, 2006 | 06:55 PM
  #220
RHMax's Avatar
Newbie just Registered
Sexima got 260 with Stillen headers, SAFCII, and Stillen cams; with other bolt-os. 245+ would be my guess.
Old Jun 19, 2006 | 06:58 PM
  #221
NmexMAX's Avatar
dot dot dot ...
Stillen makes cams.. Or are they the JWT pieces?
Old Jun 19, 2006 | 07:00 PM
  #222
vsamoylov
or jwt knockoffs
Old Jun 19, 2006 | 07:04 PM
  #223
NmexMAX's Avatar
dot dot dot ...
I guess I should have asked what were the specs...
Old Jun 19, 2006 | 07:05 PM
  #224
chernmax's Avatar
Sexima has everything I have with the exception of Cams, have not done this yet because my car was still under warranty...
Old Jun 19, 2006 | 07:08 PM
  #225
NmexMAX's Avatar
dot dot dot ...
So..... what about all the other mods re: warranty?
Old Jun 19, 2006 | 08:36 PM
  #226
kamski's Avatar
.org extraordinaire
What BOUT nismo Cams?
Kam
Old Jun 19, 2006 | 08:47 PM
  #227
NmexMAX's Avatar
dot dot dot ...
What about them?
Old Jun 19, 2006 | 10:08 PM
  #228
kamski's Avatar
.org extraordinaire
Do the nismo cams void warranty?
Kam
Old Jun 19, 2006 | 10:45 PM
  #229
DeusExMaxima's Avatar
Sexima's car sounds pretty mean, btw.
Old Jun 19, 2006 | 10:46 PM
  #230
chernmax's Avatar
Kam
My guess is yes...
Old Jun 19, 2006 | 10:50 PM
  #231
My guess is with all the bolt on stuff we have available, including ECU reflash, light weight flywheel, which no one has yet, I bet we can get 320-330 hp and the flywheel. Also, since we have another 35 lbs we can lose with the headers, we can easily lose 150 lbs as well. That is some darn nice numbers! About 10lbs/hp.
Old Jun 20, 2006 | 01:34 AM
  #232
ramberg's Avatar
GrandPa
Thanks my friend. I will wait till You get your dyno done. Good luck at the track. I will be running my car at English Town Raceway on Saturday.
Old Jun 20, 2006 | 07:46 AM
  #233
chernmax's Avatar
You earned it, and good luck also, time to open up the Juice on baby...
Old Jun 20, 2006 | 08:55 AM
  #234
kamski's Avatar
.org extraordinaire
POP QUIZ HOT SHOT:
Chern with Ramb 1 on 1 at the 1/4 mile..........
WHO WINS???
DEUS!!!
http://www.ultrarev.com/Unorthodox_R...te-p27441.html
DO that thing ^^^^^ and give em a run fo the money money money!!!
Old Jun 20, 2006 | 09:11 AM
  #235
Glude's Avatar
Sorry but I dont think the 350z clutch or flywheel will work on our cars without modifications. Ive also heard that a lightweight flywheel isnt very good for drag racing, its better used on a road course when u need to get the revs up high faster.
Old Jun 20, 2006 | 11:54 AM
  #236
Tek-Niq's Avatar
my rear view mirrors flap like a f-ing bird
Kam
you have to rip apart the whole top half of the engine to put those in, timing chain and all have to come off, so take a guess..lol..
Old Jun 20, 2006 | 03:17 PM
  #237
chernmax's Avatar
POP QUIZ HOT SHOT:
WHO WINS???
DEUS!!!
Win or Loose, he's still my Boy.
I cheer for any Max owner who can achieve speed and teach me what to do.
East Coast, West Coast, Japan, Australia and even Canada, it's all good if it helps each other succeed...
Old Jun 20, 2006 | 03:20 PM
  #238
My-Body-Is-Ready's Avatar
a bit off topic but i cant start my own threads but... where can i get those maxima.org stickers =)
Old Jun 20, 2006 | 03:26 PM
  #239
chernmax's Avatar
You have over 15 posts so yes you can post a new thread on your own...
Moderator, need some help here...
Old Jun 21, 2006 | 03:22 AM
  #240
ramberg's Avatar
GrandPa
[QUOTE=kamilkluczewski]POP QUIZ HOT SHOT:
I wouldn't care if I lost to my best friend. Its all about having fun.
