Berk Techno
Old Jun 23, 2006 | 01:27 PM
djfris's Avatar
Berk Techno
Nissan Maxima 2004-05 APEXi Power Intake Kit
This is what I want, I emailed Berk and they said "We only have that intake in stock with the AEM filter. It has been a very
popular option because it gives you most of the benefits of the Apexi
filter, but at a reduced cost. Those kit are good and in stock. Your price
is $129.99 w/ free shipping on that kit.
Regards,
Bryan
Berk Technology
IS THIS WORTH IT<OR DOES THE APEXI FILTER MAKE A DIFFERENCE OR SAME ****?????????
THANKS
Old Jun 25, 2006 | 08:30 AM
aria's Avatar
apexi filters are > AEM imho
look intot he technology of Apexi... and the cone design.
Old Jun 25, 2006 | 08:35 AM
AscendantMax's Avatar
doubt you'll feel a difference.
Old Jun 25, 2006 | 10:48 AM
logik05se's Avatar
i second that doubt.
Old Jun 25, 2006 | 08:33 PM
!PrjctMax!'s Avatar
I third that doubt
Old Jun 25, 2006 | 08:38 PM
Ankit69's Avatar
i was gonna third it but you beat me to it =) so i fourth it
Old Jun 26, 2006 | 01:34 AM
VQPRO's Avatar
the aem filter is better than the apexi because it flow more air ,the apexi filter is like the stock filter .the aem is like the k&n open, more air more power
Old Jun 26, 2006 | 08:47 AM
how is the apexi filter like the stock filter? both are open cone elements.
Old Jun 26, 2006 | 01:50 PM
aria's Avatar
i dont know what you guys are talking about.... i doubt you would feel any difference ok +-1HP
Old Jun 26, 2006 | 07:30 PM
Glude's Avatar
The Apexi filter has been proven to flow higher than K&N and filter wayyy better. I dunno where you got your info from, but its not completely accurate. I dont doubt that its a good filter because the new AEM filters are supposedly dry element like that apexi.
Old Jun 26, 2006 | 11:38 PM
that 129.99, can anyone get or was that a quote for you only?
Old Jun 27, 2006 | 02:48 AM
VQPRO's Avatar
here is a little test i use on the apexi and stock filter, if you hold the apexi filter and the stock filter up to the light, you will see the same amount of light coming through both of them .
Old Jun 27, 2006 | 03:07 AM
VQPRO's Avatar
i had the berk tech intake with the apexi filter, the apexi power filter reduces air turbulence within the filter and creates smooth air flow into the throttle body . this is true, but the aem oil filter is more open and give a higher amount of air at full open throttle
Old Jun 27, 2006 | 05:32 AM
aria's Avatar
i think it smore of preference... your choice... and for you to make the choice... i got the berk one with apexi because i thought it was worth it...
its a sweet intake...
Old Jun 27, 2006 | 09:50 AM
logik05se's Avatar
i had the apexi filter on my berk for quite a while, after sometime i got tired of it and ordered a foam oil filter....suposidly i herd foam was better for performance etc....i put it on, i def cant say that it chopped .5 of my et's but maybe a really slight difference is there.
Old Jun 27, 2006 | 10:25 AM
Glude's Avatar
I believe foam flows better but the filtration is horrible. Here is an old page that shows the difference between certain filters.
http://www.mkiv.com/techarticles/filters_test/2/
Old Jun 27, 2006 | 01:51 PM
logik05se's Avatar
interesting page, i have the wepon R filter, I wonder how that one measures up.
Old Jul 4, 2006 | 10:55 PM
sorry to bump this back up, but to the original thread starter, did you end up buying the intake with the AEM filter?
Old Jul 5, 2006 | 01:25 AM
RideTuner's Avatar
I could be wrong but I believe the thread starter purchased from us and went with the Berk w/ APEXi. Could be different people but both are from CT.
Old Jul 5, 2006 | 08:13 PM
aryathegreat's Avatar
how much power is the short ram even adding since either filter will prob add or subtract 1 or 2 hsp (like stated above)
Old Jul 5, 2006 | 08:49 PM
!PrjctMax!'s Avatar
You will most likely feel a loss in the low-end, but you will feel a little in the mid-top end; but we're talking about around 5HP max(to the wheels) so it's not like it'll make that much of a difference. Combine an intake+full exhaust(headers just came out!) and you'll notice a pretty decent power gain across the whole power-band imo. Hope this helped
Dan
Old Jul 6, 2006 | 03:46 PM
Babyfixer's Avatar
I doubt that third.
Old Jul 6, 2006 | 09:26 PM
ull prob feel better with the intake+exhuast+ECU. ull ge the most of off each, with proper air/fuel balance. / end thread hijacking :]
Old Jul 6, 2006 | 09:52 PM
Glude's Avatar
10char
hawks25
30
Jun 25, 2002 05:59 PM
cobymoby
67
Jun 18, 2002 12:15 AM
SkiLlz
May 24, 2002 11:03 AM
y2kse
Apr 2, 2002 07:17 AM
MichaelAE
Mar 4, 2002 09:54 AM
