Intake vs. MPG
Old Jul 14, 2006 | 05:25 PM
Ankit69's Avatar
Intake vs. MPG
i duno what wrong from what i hear a new intake is suppose to improve your mpg but its the exact opposite for me, i recently installed a fujita intake and my gas mileage seems to be slaughtered, im averaging 16-17 mpg where as before i was averaging 20 ish in the same driving conditions. can anyone suggest something ? could the intake be installed wrong ?
Old Jul 14, 2006 | 05:46 PM
aryathegreat's Avatar
could it be that ur having ur car rev higher just to hear ur new intake scream?
Old Jul 14, 2006 | 06:03 PM
Ankit69's Avatar
never take it above 3 rpms
Old Jul 14, 2006 | 06:04 PM
erasat's Avatar
Well, after just finishing installing my new Fujita Intake, and test drive it, I can only say, forget about MPG, that sounds is just crazy.
I also thought on that, getting better MPG, but after I heard my car now, I doubt that I will accomplish it.
Old Jul 14, 2006 | 06:05 PM
Ankit69's Avatar
cant really forget about the mpg if im only gettin 225 out of a gas tank !!!
Old Jul 14, 2006 | 06:10 PM
erasat's Avatar
Well, where I live I'm getting 16-17 since I have the car, so for me it hasn't been that bad, let me see now what happens with the intake before I can judge it.
Old Jul 14, 2006 | 06:33 PM
Ankit69's Avatar
lemme know...
Old Jul 14, 2006 | 06:44 PM
MisterSparkle's Avatar
well on average in NY i was only getting 14-16 mpg...on the highway though i got from NYC to toronto canda...on i think 2 1/2 tanks...and thats a v6...i have a I-4 jetta which is about 3 to about 4 1/2 tanks to get to canada...so i don't kno...it seems betta to my memory...lolxz
Old Jul 14, 2006 | 06:47 PM
Ankit69's Avatar
weird, i was averaging around 20 in the same roads i am gettin 16 now...
Old Jul 14, 2006 | 06:49 PM
well lik most people say all over the web and in person...the intake is supposed to give you better MPG...buh i think nobody does...cause it just sounds so damn good...lolxz
Old Jul 14, 2006 | 06:50 PM
Ankit69's Avatar
true, also i got new brakes on the car i dont think that would make the mpg go down,
erasat's Avatar
Remember that to install the Intake you should have reset your ECu by removing the battery cables, once you do that, the ECU will re-learn the way you drive, so, I'm assuming that maybe before your Intake was there your car learned that your driving was getting you around 20 MPG, maybe, and I say Maybe, after you reset the ECU now your Car learned your more aggresive style and it's showing it.
Maybe you will need to reset the ECU again, and take it easy for a while to see if that gets you back to your 20 MPG.
Old Jul 14, 2006 | 06:59 PM
Ankit69's Avatar
ya im going to
will you keep you posted...
Old Jul 15, 2006 | 05:23 AM
MAXDOUT04's Avatar
* THIS SPACE FOR RENT *
Believe me my first week with my fujita MPG were shot but now im in my 3rd week and back to normal until i get on it 20-21mpg
Old Jul 15, 2006 | 05:56 AM
Ankit69's Avatar
ill wait to see what haps, been exactly a week today so ill let u know
Old Jul 15, 2006 | 05:19 PM
madmik's Avatar
I would double check the MAF installation or look for an air leak. Pictures?
Remember, that ECU's got a memory like your wife/girlfriend. Ruff up that pedal too much and it becomes more responsive. Could be CAI novelty making you spend more time at WOT.
Old Jul 15, 2006 | 05:31 PM
Smooth's Avatar
I run my car hard always manually shiftin git and constantly running it in stop and go and I get 22-24 every tank
Old Jul 15, 2006 | 06:52 PM
AscendantMax's Avatar
a lead foot doesn't help with milage at all. i suppose after getting an intake, most of us are eager to hear that growl...so we give it a little more gas than usual. (i know i would, just ordered the berk. )
Old Jul 15, 2006 | 10:37 PM
aria's Avatar
i get avg 12mpg with my berk... ****! anyway look i live in Brooklyn NY ****ing busy *** roads and li9ghts every 200 feet
Old Jul 15, 2006 | 11:40 PM
true dat...i can agree with that...nd i drive into the city from time to time for work...image that...
Old Jul 16, 2006 | 01:41 PM
HADA 11's Avatar
If the intake helps deliver more air, in turn the ECU will deliver more fuel. That, along with your right foot's ability to make more noise/power you're bound to use more gas.
Old Jul 16, 2006 | 02:16 PM
buh i achually thought the ECU compensated for the extra air...hense y u need to flash the ecu in order to make it work properly with any aftermarket upgrades...?
am i wrong to be under that assumption?
Old Jul 16, 2006 | 02:17 PM
yeah, the ECU compensates for the extra air. With the stock ECU, our cars aren't very bolt-on friendly.
Old Jul 16, 2006 | 02:36 PM
Jim C's Avatar
So if the ECU compensates for the A/F mix, then intakes are pretty much just for looks then ?
Old Jul 16, 2006 | 03:24 PM
madmik's Avatar
True, over time the ECU will adjusts some variables to compensate for normal wear. Adding certain aftermarket parts may have a similar effect, resulting in less HP than anticipated. Only a run on the dyno will show how much more power you got out of your CAI. Mine added about 12WHP. Read the posts on what Technosquare can do with your ECU. If you add headers, CAI, and other such goodies, a flash is worth it. Tek-Niq picked up another 17 WHP after the flash.
http://forums.maxima.org/showthread.php?t=478759
Old Jul 16, 2006 | 03:28 PM
Well, to be dead honest, I don't really care if the intake free up any HP. I'm getting merely for the looks and sound.
Old Jul 16, 2006 | 07:13 PM
aria's Avatar
i have a berk and its a noisy ****er and the girls always turn heads when you rev it up on a read light
Old Jul 17, 2006 | 04:23 AM
erasat's Avatar
I installed my FUJITA on Friday afternoon, after testing it hard on Friday night, I had 6.8 MPG, after almost normal driving on Saturday, my MPG was 13.0, today after my first normal daily driving when I checked my MPG went up to almost normal 16.5 MPG.
So, in a summary, before my intake my MPG was 16.7-17.2 MPG, and today is 16.5, so for me it's clear, it all depends on how you wants to drive.
Old Jul 17, 2006 | 05:08 AM
Smooth's Avatar
I am still floored with the milage I am seeing. I am dead serious when I say I am turning about 5k about every where I go and I average (eve idling for the ac) around 22 Do oyu guys drive with 87 octane or something?
Old Jul 17, 2006 | 05:11 AM
erasat's Avatar
93 Octane all the time.
Where I live that's the most I can get in a normal driving, around 17 MPG. Highways can get me 22-25 MPG depending on the trip.
Old Jul 17, 2006 | 06:36 AM
i rather refrain...precious gas is being guzzled if i do that...
Old Jul 17, 2006 | 06:43 AM
aria's Avatar
Just blast the music... that should get their attention right? lol
Old Jul 17, 2006 | 09:21 AM
PSYCHOMAX's Avatar
My mileage went up 1 mpg from 24 to 25 with my second generation Injen (w/"MR").
Old Jul 17, 2006 | 04:18 PM
IMO 1 mile increase is negligible. tire pressure, driving habits, etc can have an effect on milage.
now we're on the same page
Old Jul 18, 2006 | 04:03 AM
PSYCHOMAX's Avatar
I thought it was implied but that was a 1 mile per gallon increase without touching tire pressure (air was never added to the tires - which would hurt mileage, though outside temps have gone up a few degrees to help offset that), driving habits, which for me is close to constant - I've had the same driving routine for the past 10 years and I drive like I'm runnin' from da cops , and using the same fuel (same octane, same gas station). It's also wise to do the math yourself instead of relying on the car's computer. My mileage only varies by a couple tenth's from week to week (that, to me is negligible), so a full mile per gallon step was noticeable on paper. As for the 1 MPG difference, hell, at $3.50/gal, I'll take whatever I can get!
Old Jul 18, 2006 | 02:08 PM
well thats true over here in the tri-state area...omg gas prices plus traffic...haha you'd be lucky to get as much as psycho gets. so wuheva its all good. buh yea i wanted to ask psycho you have the injen sp w/mr tech rah? is it a dirct bolt-on...i mean have they fixed the problem with the harness? cause i kno chern had a problem with that nd he had to fix it...did you have that problem? nd are you goin cai or short ram? thanxz
Old Jul 18, 2006 | 07:07 PM
PSYCHOMAX's Avatar
I think Chern has the first gen. Injen. The second gen. (with "MR") has a beefy bracket welded to the intake. It also has a mount for the MAF sensor to plug into. I don't know if there's a performance difference between the two, but the newer one looks real sweet. I get alot of "wow!"'s from mechanics that walk by my car when the hood's popped. I've gotta get some pics posted soon.
Oh yah, I'm running the full CAI; it's tougher to install, inspect, and clean but it is what I paid for and if I was gonna go with a short ram, I probably would have gone with a cheaper intake.
aw11power
Oct 10, 2021 04:57 AM
ef9
Oct 4, 2015 08:43 AM
maxima297
Sep 30, 2015 03:32 PM
09maxshawn11
Sep 30, 2015 10:28 AM
MichMaxFan
Sep 30, 2015 09:18 AM
