Problem with automatic sunroof...any help??
Old Jul 27, 2006 | 07:46 PM
alboogz's Avatar
whassup guys? i am having a problem with my sunroof that just happened yesterday. when i slide the button back that automatically opens my roof, it doesnt work. but the button to the right, the manual button which only partly opens it, still works. any idea what it might be or what i need to do to get it fixed? this happen to anyone else? worst comes to worst, i will take it to a shop to fix it, but if anyone has any info on this problem, let me know. thanks!
Old Jul 27, 2006 | 07:52 PM
4MySwee's Avatar
I forgot how to reset it. But that usually happens after you have disconnected your battery. Check your manual on 'how to reset the sunroof'.
Old Jul 27, 2006 | 08:11 PM
alboogz's Avatar
yea i just installed HIDs so i did disconnect my battery. i hope that was the problem. ill look into it...thanx 4 ur help bro
Old Jul 27, 2006 | 09:47 PM
jcalabria's Avatar
NINE-time Maxima Owner
From the '07 manual... probably same procedure:
Restarting the sunroof sliding switch:
The sliding switch will become inoperable after
the battery terminal is disconnected, the electrical
supply interrupted and/or some abnormality
detected. Use the following reset procedure to
return sunroof operation to normal.
1. If the sunroof lid is open, push the tilting
switch repeatedly toward the DOWN position
to fully close the lid.
2. Push and hold the tilting switch for more
than 2 seconds toward the DOWN position
to reestablish the lids home position.
The sunroof should now operate normally.
Old Jul 28, 2006 | 08:10 AM
alboogz's Avatar
it worked!! thanx 4 the help guys. greatly appreciated
Old Jul 28, 2006 | 09:29 AM
MAX2DAMAX's Avatar
another happy customer
2kmaximel
Sep 16, 2015 03:19 PM
QueensMAX
Sep 15, 2015 04:14 AM
videomano
Sep 8, 2015 03:28 PM
