Wards Praises 3.5L VQ Engine in Detail
Old Aug 2, 2006 | 11:14 PM
SilverMax_04's Avatar
I just came across this article from Wards Automotive from last January. It gives more detailed information about why the VQ engines continues to be picked (for 12 years straight) as one of "Wards 10 Best Engines (or as the article says: "The Nissan VQ and the year's 9 other Best Engines").
This article also makes a pitch for something I have stressed in other posts in the 6th Gen and have bolded here: "Ward's judges remain intoxicated by the 3.5L V-6's riotous midrange urge, which is palpably abetted by a manual transmission."
Nissan Motor Co. Ltd. 3.5L DOHC V-6
By Bill Visnic
WardsAuto.com, Jan 4, 2006
An engineer for one of Nissan Motor Co. Ltd.'s rivals recently groused, “You know, you really ought to call it 'Ward's 9 Best Engines,' because Nissan automatically gets a win every year.” The comment was offered good-naturedly but with a twinge of frustration.
With a record 12th consecutive win for its landmark 3.5L VQ DOHC V-6, Nissan is making a case for the engineer's suggestion. It has been a 10 Best Engines winner every year for some variant of Nissan's fabulous VQ engine family since the competition began in 1995.
As far as competitors are concerned, it really has become something like “Nissan's VQ and the year's nine other best engines.”
In a dozen years since the launch of the original 3L VQ DOHC V-6, Nissan has wrought numerous improvements and changes. There has been the addition of electronic throttle control, variable valve timing and two major new variants: the 3.5L that for some years has been the smallest-displacement VQ V-6 for the U.S. market and a more recently added 4L unit employed in the company's light trucks and SUVs.
The matrix of VQ displacement and power and torque ratings is manifold. Regardless of variant and model, the baseline VQ design remains the foundation for the VQ modular family's iconic status: microfinishing of critical internal surfaces, keen attention to balance and a priority for reduced weight for reciprocating masses.
For its 2006 10 Best Engines win, Ward's tested the 3.5L VQ in the Infiniti G35 sedan with a 6-speed manual transmission. At 298 hp, the VQ, going into 13 years in the market, still plays in the upper strata of premium V-6s, generating a thunderous 85 hp per liter. The figure, remarkably, is just a few horses short of the class-leading, direct-injection 3.5L DOHC V-6 from Toyota Motor Corp. (also a 10 Best winner for 2006), which launched this year.
Moreover, the VQ performs as if it were a brand-new engine. Ward's judges remain intoxicated by the 3.5L V-6's riotous midrange urge, which is palpably abetted by a manual transmission. The power cascade is not confined to a narrow midrange window, either: One often runs out of road space (or nerve) before the VQ runs out of breath.
“Spectacular in-gear acceleration,” says one 10 Best judge.“ And this engine has brilliant throttle response in any speed range. Authoritative power and torque,” says another. It may be the grizzled vet of overhead-cam V-6s, but Nissan's 3.5L VQ V-6 still has got game – and plenty of it.
Judges' Comments:
McClellan: This is still a nice package and a terrific engine.
Winter: It still is soooo good.
Visnic: So broad, so even, the torque flows like an opened spigot. Midrange almost any V-8 would envy. Throttle response still should be studied by everyone.
Engine type: 3.5L DOHC 60° V-6
Displacement (cc): 3,456
Block/head material: aluminum/aluminum
Bore x stroke: 95.5 x 81.4
Horsepower (SAE net): 298 @ 6,400 rpm
Torque: 260 lb.-ft. (353 Nm) @ 4,800 rpm
Specific output: 85 hp/L
Compression ratio: 10.3:1
Fuel economy for tested vehicle (EPA city/highway mpg): 19/26
Application tested: Infiniti G35 6MT
{I did not have a URL for the pictures and the graph of HP and Torque. And my efforts to place them in another post did not work and I deleted it -- but not before the failure was noted in post #2, below.}
What is particularly impressive -- and was written about in this article -- is the very broad and flat torque curve. It shows 200 ft-lbs or more of torque from 1,100 RPM up to red-line at 6,500 RPM. And an even more impressive 250 ft-lbs or more of torque from 3,000 RPM up to 6,100 RPM.}
Old Aug 2, 2006 | 11:21 PM
Nissan 6's Avatar
Originally Posted by SilverMax_04
404 pictures not found
Old Aug 3, 2006 | 05:06 AM
04BlackMaxx's Avatar
Yeah the car has *****, thats why I bought it.
Old Aug 3, 2006 | 05:34 AM
NmexMAX's Avatar
dot dot dot ...
The engine they're praising, once again, is in the G35... :Not the FWD version... IBimbeingpetty.
Old Aug 3, 2006 | 10:41 AM
laflyer23's Avatar
Gotta Agree with NmexMax. Just look at the horsepower and torque and you should know right there that it's a G or Z. Although i'm not trying to say our engines aren't good b/cuz they're great also. Just a lil less tuned than the G or Z.
Old Aug 3, 2006 | 10:58 AM
LA02MAX's Avatar
that's not the point....the VQ has been praised by wards for 12 years now, and it all started in the maxima long before the G was released...a VQ is a VQ..it may be slightly different in the G due to IM/E changes etc. but it's still the same engine that we have
did you miss the part in the article that said, and I quote, "Ward's tested the 3.5L VQ in the Infiniti G35 sedan with a 6-speed manual transmission"
Old Aug 3, 2006 | 11:31 AM
ajcool2's Avatar
VQ 4 Life (or until it starts leaking oil all over the place)!!!!
Old Aug 3, 2006 | 11:40 AM
NmexMAX's Avatar
dot dot dot ...
IBimbeingpetty.
Seriously, I didn't know that
Old Aug 3, 2006 | 11:45 AM
LA02MAX's Avatar
ohimsorrywhydontyouusespacesandiforgotyouknowevery thingstupidme
Old Aug 3, 2006 | 11:51 AM
d00df00d's Avatar
Old enuf to pick his own gears
Actually they were very clear that they were praising the entire line. The G35 engine was just a highlight.
Old Aug 3, 2006 | 11:52 AM
NmexMAX's Avatar
dot dot dot ...
stupidme
I was being petty....
Old Aug 3, 2006 | 06:43 PM
d00df00d's Avatar
Pff. Maxima hater.
Old Aug 3, 2006 | 08:47 PM
DeusExMaxima's Avatar
I have the modified Z version programmed in my ECU and it IS INTOXICATING!!!
Old Aug 4, 2006 | 07:32 AM
NmexMAX's Avatar
dot dot dot ...
No dyno no care
Pff. Maxima hater
That's why I have 2 of them..
Old Aug 4, 2006 | 10:16 AM
d00df00d's Avatar
Clearly you're covering up your hatred by surrounding yourself with the object of your loathing.
shilov
Feb 19, 2024 09:40 PM
seesole
Sep 14, 2015 12:38 PM
ballerchris510
Sep 11, 2015 05:29 PM
16_SR
Sep 7, 2015 06:47 AM
maxfever1987
Sep 6, 2015 06:20 PM
