Fog Light Opinion
Fog Light Opinion
Hey guys,
I am replacing the fogs in my max from the dingy yellow ones i have to a set of piaa's.. i havent decided whether to go blue or super white.. what would look best with my HID headlights? here are some sample links for you guys to choose from..
http://cgi.ebay.com/ebaymotors/PIAA-...ayphotohosting
Please by all means, dont think I want to limit my replacement H3's to these sole fogs alone. If you do have any suggestions please do link me
Thank you guys
![Smilie](https://maxima.org/forums/images/smilies/smile.gif)
![king](https://maxima.org/forums/images/smilies/king.gif)
Originally Posted by minsbang
for some reason, whenever i go and buy some aftermarket h3's, one of them blows out.
I'd spend around $200 to buy a set of h3 hids for the fogs..
btw, go with white.
btw, go with white.
now that i think of it, im not sure if those fogs i have in there are HID's.. i did get the HID option when i bought the car.. perhaps those are HID h3's as well? its an 2006 SL with Driver Preferred Package
Originally Posted by UNFADEABLE MAX
Does anybody know what size the Halogen bulbs are in the 06 Maxima? Im trying to retro-fit a set of HID's but I cant seem to find the bulb size. Please help..
![Tard smash](https://maxima.org/forums/images/smilies/smashfreak.gif)
Originally Posted by jsmithsole
I went with yellow, gives a different look....
Kamski
listen really have no idea about these HIDs. buh want to learn.
hey for all those who achually have the mini h3 or full size h3s as fogs...
question
1. are they all HIDs or no? if no, what are they?
2. should i stick to non-HID fogs or go 3000K yellow?
3. have your passenger side fogs blown out? if yes, have you found the problem or just left it and keep replacing?
4. under what condition have your fogs gone out? (i mean is there a connection onto y they blow out?)
5 i plan on goin 6 or 7000K HIDs in my headlights, will i need to change my ballast, and transformer?
thankxz again
question
thankxz again
Ok, my 04 max just got delivered on thurs. My passenger fog light is out.
What bulb should I get to replace it. Is there an easy way to change it, without disencombooberating the half the front end to get to it? has there been some problems with that side of the car, and the driving light?
question
thankxz again
question
thankxz again
#1. if you get an HID kit, they are all HID's, don't get those bulbs that say they output like HID's cause the don't.
#2. a 3000k HID bulb will be best over any bulb. this depends on how much you are willing to spend.
#3. as an HID kit, it has its own ballast, the ballast gives the bulb its own power, so I think they won't blow like the oems would. the HID will last longer.
#4. this only applies to oem lights, we think they are getting too much power somehow, or the stock lights just plain suck.
#5. if you plan on going 6-7000k in the headlights and already have HID's in them, you don't have to change the ballast or anything but the bulb..
Originally Posted by Tek-Niq
I have HID mini H3's in my fogs, 6000k.
- How hard is the install for the hid fogs?? Do I gotta remove the headlight assembly off the car?
- How about putting it back on?
- Do I have to realign/re-aim both headlights?
- Is everything plug and play when installing the hid fogs?
taking everything on and off is all simple.
you don't have to reaim anything..
I have a how to here:
http://www.6thgenmaxima.org/forums/viewtopic.php?t=796
you have to register to see it though, free..
There's info on how to change the bulbs in the stickies, you DO NOT have to remove the bumper (for reg bulb replacement, HID however is a different install)
![Reading](https://maxima.org/forums/images/smilies/read.gif)
http://forums.maxima.org/showthread....=1#post3734123
Do you or anybody have a pic with both the headlights and yellow fogs on? I'm thinking of getting h3 mini yellows for my fogs but I wanted to see how it looks first.
![](http://memimage.cardomain.net/member_images/8/web/464000-464999/464988_52_full.jpg)
The Frye
09-02-2021 11:03 AM
dvcamp
09-18-2015 10:17 AM
Maxima30
09-07-2015 06:13 PM
