Engine making a click noise
Old Sep 12, 2006 | 07:46 PM
vir420's Avatar
Just started about 2-3 days ago. Turned my car on, and started to hear this unusual clicking like sound come from under the hood. If I push the RPM past 3 1/2 or 4, the normal sound will be back, but if the engine is idle or I rev it up to 1 - 3 rpm's, I can still hear the little clicking noise
The clicking noise is what it sounds like, don't exactly know what the problem is & I really don't want to take it to Nissan, they might tell me I need to get a new engine and I'll have to say
Appreciate any suggestions to fix the problem or any input at all...
Old Sep 12, 2006 | 08:05 PM
Defiant_Max04's Avatar
This has happened to me too, I've noticed a f-in clickign sound and it pisses the **** out of me..
My Max is kinda fu**ed up at the moment because it needs to go in for the following..and while I'm at it I'll have them look at that...
Tranny Slip
Engine Click
New Spark Plug (May be the reason why engine clicking)
Squeaky engine on cold start
VERY odd noise on cold start that just happened 2 days ago
12V Power Blew Out
So they need to work on it..Still under warranty....2 yrs old, 30k miles
Old Sep 12, 2006 | 08:52 PM
6thGenSmoke's Avatar
I had this happen to me a couple of times before but it goes away after 5 mins or so.
Old Sep 13, 2006 | 04:44 AM
04BlackMaxx's Avatar
I guess I got lucky, 60,000mi and never a powertrain issue...Just minor things breaking in the cabin.
Old Sep 13, 2006 | 06:31 AM
chulo's Avatar
try putting different type of gas... i got this a couple of times when i first turned on my car, but then went to a different gas station and put super, didnt happen again.
Old Sep 13, 2006 | 06:32 AM
chulo's Avatar
try sunoco
Old Sep 13, 2006 | 04:21 PM
Sarara's Avatar
I think the CPU unit in your car runs auto diag and when it's done, you will hear clicking noise. This is I Believe normal for maxima or I may be completely wrong.
Old Sep 13, 2006 | 04:24 PM
!PrjctMax!'s Avatar
I'm loving the sig Chulo!!!!!!! How much the lambo doors run you? sry for jacking thread
Old Sep 13, 2006 | 04:47 PM
chulo's Avatar
hey i was trying to pm you but im " not allowed " or whatever ... umm.. i didnt pay much b/c im president of my car club and i get exclusive parts from some dealers and i used to work at a body shop before and i didnt pay to have them put on
Old Sep 13, 2006 | 05:13 PM
!PrjctMax!'s Avatar
DAEMN! You can now PM because you have 15 posts!
Old Sep 13, 2006 | 05:34 PM
chulo's Avatar
chulo, you do not have permission to access this page. This could be due to one of several reasons:
Your user account may not have sufficient privileges to access this page. Are you trying to edit someone else's post, access administrative features or some other privileged system?
If you are trying to post, the administrator may have disabled your account, or it may be awaiting activation.
"whatever"
Old Sep 13, 2006 | 06:23 PM
emub00's Avatar
Sounds like engine knock - try going one notch up on the octane of your gas, it should stop doing that...I personally use Shell V-Power (91) and never had this kind of problem. I hope this helps.
Old Sep 14, 2006 | 04:52 PM
SMOKIN'MAX's Avatar
Stang-seeking Max Missile
I had the same noise- it was the exhaust gussets- both were crached and made a horrible rattling sound.
Old Sep 14, 2006 | 04:57 PM
vir420's Avatar
Thanks for all the responses guys.
Well you guys said to try putting different gas in my car, but this all happened I think after I put Sunoco 93+ in my car, so maybe go back down?
I'm thinking it could be oil change, because I am close to it, 200 miles away.
I'll update you guys once I solve the problem, hopefully this weekend
Thanks again for the responses.
Old Sep 15, 2006 | 12:44 PM
BadBlackMaxSL's Avatar
If you left your car overnight on the streets of Baghdad then this ticking could really be a big problem.
Sorry, I have no idea what it could be.
Old Sep 15, 2006 | 01:18 PM
licnyc's Avatar
Hi vir420 I have a tick also in the engine compartment to. I have an appt. tomorrow for nissan to check it out but it only happens when it is at operating temp. and in drive tick tick or tick knock. I have been using ultra 93 sunoco gas since aug 2003 in this max and I only have 12,800 miles on her. I just love a really slow brake in period. I would look to tsb # 04019 go to www.nissanhelp.com and look for it. Im sorry I just dont know how to hyperlink it or even if I can here. good luck
Old Sep 25, 2006 | 01:06 PM
ggaudreau's Avatar
Noise
Do you hear the noise when you turn off the engine for a few seconds??
Guy
Old Sep 25, 2006 | 05:48 PM
05BlackSE's Avatar
Mine does this all the time...It makes me worried that I bought a lemon....You can really hear it when you are at a drive though window....
Old Sep 26, 2006 | 06:59 AM
ggaudreau's Avatar
The problem on my Maxima was an engine mount in the middle in the back of the engine. That electrical mount is located inside a steal support beam and is there to take the tork generated by sudden accelerations and engine start. It is a 500$ job (parts and labor) to get it replaced.
Old Sep 26, 2006 | 02:11 PM
05BlackSE's Avatar
Dang I think I will just let it click....
Old Sep 28, 2006 | 07:46 PM
madmik's Avatar
Valve lifter with too much clearance?
boomerbrian
Nov 8, 2015 05:10 PM
bc992164
Aug 26, 2015 12:19 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
egali045
Aug 16, 2015 01:19 PM
