help! removal of light assembly!
Old Oct 22, 2006 | 07:00 AM
Atlpinoy's Avatar
Need help with removal of light assembly of my 05 Max... trying to change out fog bulbs! I blew one out. Thanks!
Old Oct 22, 2006 | 09:57 AM
Tek-Niq's Avatar
my rear view mirrors flap like a f-ing bird
well,
you can either try to change the bulb out itself cause you can do it,
or, you will have to remove the bumper/ grill then the headlight to get to it.
Old Oct 22, 2006 | 10:04 AM
Atlpinoy's Avatar
how hard is it to replace...and do you have any pics or diagrams to show how to do it??
Old Oct 22, 2006 | 10:22 AM
Tek-Niq's Avatar
if you got big hands it will be a harder job vs someone that has small hands.
here is a diagram:
http://tekniq.homelinux.net/6thgenhost/fog.jpg
once you get to the retaining clip, it will be held down by a screw on one side, unclip the side opposite of that wich has no screw but a tab. you just move it upward to it releases it and it should move like a door hinge after that, then the bulb will come out.
NOTE:
do not loosen the screw
Old Oct 22, 2006 | 05:27 PM
jsmithsole's Avatar
*moderator*
Sticky:
http://forums.maxima.org/showthread....=1#post3734123
It's easy and my hands aren't that small...
Old Oct 26, 2006 | 04:45 PM
Atlpinoy's Avatar
Yo! Thanks guys replaced them today! Went with the yellow piaa's! And yeah you do need small hands! Junk hurt my hands and thumbs!
Old Oct 26, 2006 | 04:52 PM
Tek-Niq's Avatar
glad we could help..
just keep in mind that the piaa's have also blown, so keep an eye on them.
Old Oct 26, 2006 | 06:35 PM
gtp2k1's Avatar
Atlpinoy:
Where did you get your yellows and how much if you don't mind?
Old Oct 26, 2006 | 06:40 PM
jsmithsole's Avatar
*moderator*
Yeah mine lasted just over a year and that was running them pretty much all the time...as Tek said glad to have helped!!!
Old Nov 8, 2006 | 01:28 PM
Killah Kane's Avatar
So finally, one of MY fogs have blown as well. Is the above procedure the same for changing out the fogs on a 2004 max? So all I have to do is remove the air filter housing and the fluid resevior and I should then gain access to the bulbs? By the way, the link for the diagram above is actually not working...
Old Nov 8, 2006 | 05:21 PM
jsmithsole's Avatar
*moderator*
Yup, that's it...
Old Nov 12, 2006 | 09:50 AM
Originally Posted by jsmithsole
Yup, that's it...
Any steps on removing the air filter housing?
Old Nov 12, 2006 | 09:58 AM
jsmithsole's Avatar
*moderator*
I for get now, should just be a couple of bolts...
Old Nov 12, 2006 | 12:41 PM
4MySwee's Avatar
Kane,
If you've got a second, check out www.6thgenmaxima.org! That's if you haven't already. They have diagrams and tech info pertaining to our make and years. Cool wesite! They might be able to help there also.
Swee
The Frye
Sep 2, 2021 11:03 AM
mvm062
Nov 30, 2020 09:00 AM
MaxLife17
Jun 27, 2019 01:37 PM
MaxLife17
Sep 8, 2015 02:36 PM
A32goldylocks
Sep 2, 2015 06:39 AM
