RACINGLINE MotorMount Inserts
Old 11-19-2006, 03:11 PM
  #41
MisterSparkle's Avatar
Originally Posted by kamilkluczewski
TO Public, MANUAL Only.
Automatics will find out shortly.
Kamski
this isn't the news i like hearing...lolxz
MisterSparkle is offline
Old 11-19-2006, 06:38 PM
  #42
I Donate! Why Don't You?
xoomer.com's Avatar
and the verdict is ????????
xoomer.com is offline
Old 11-19-2006, 06:51 PM
  #43
Nietzsche's Avatar
Won't know till next week.
Nietzsche is offline
Old 11-20-2006, 10:10 PM
  #44
max35ds's Avatar
While you wait for the AT motor mount . Check this out . LSD for the VQ35de. Go To www.gspec.com
max35ds is offline
Old 11-28-2006, 11:23 PM
  #45
Nietzsche's Avatar
Just got the mounts
Old 01-11-2007, 10:41 PM
  #46
You embarrass me.
zero2sixtyZ's Avatar
Does anyone have a pdf of the installation instructions?
zero2sixtyZ is offline
Old 01-12-2007, 10:16 PM
  #47
aryathegreat's Avatar
how much would a shop charge to put these mounts in since there are some kinks to get around? Looking forward to getting one for the auto once it is test fitted but i dont think ill be able to do it myself
aryathegreat is offline
Old 01-13-2007, 01:13 AM
  #48
DeusExMaxima's Avatar
My wheel hop is really bad. I need to get these for my 6 speed
DeusExMaxima is offline
Old 01-13-2007, 05:49 AM
  #49
Albert's Avatar
More questions...
1. Would these MMI affect the torque steer problem?
ie. improve, make worse, or no affect?
2. If they fit automatics, is removing the y-pipe all it
takes to install the rears and no need to drop the sub-frame?
Albert is offline
Old 01-13-2007, 07:03 AM
  #50
TAZ
TAZ's Avatar
Originally Posted by Albert
More questions...
MMI's will do little if anything to counter tq steer. Tq. steer is largely a result of axle length vs. axle diameter and an open differential
Y Pipe removal is recommended on all cars not just autos. The problem the autos face is on the 5 speed autos the transmission is too large to allow for one of the bolts that holds the mount in place to be removed. The bolt hits the tranny. Therefore more clearance is needed. lowering the sub frame is the only reasonable option unless your removing your transmission for some reason.
The front can be done without removing the y pipe but you better have little hands or lots of patience. Removing the pipe makes things alot easier. On our test cars we've reused the existing gaskets and there were no leakes. The y pipe comes out real easy, just 8 14mm bolts
TAZ is offline
Old 01-13-2007, 10:32 AM
  #51
wat is required to do to drop the sub frame?
Old 01-13-2007, 10:47 AM
  #52
.org extraordinaire
kamski's Avatar
did you order them yet deus?
Kam
kamski is offline
Old 01-13-2007, 11:33 AM
  #53
Kam
Not yet. Real soon Kamski
The subframe removal procedure was described by me in a thread that is a sticky. http://forums.maxima.org/showthread.php?t=484065
Old 01-21-2007, 02:03 PM
  #54
Albert's Avatar
Is there a reason why the OEM motor mount have a hole in the middle?
Albert is offline
Old 01-23-2007, 05:09 PM
  #55
TAZ
TAZ's Avatar
to absorb vibration. Cars are engineered for get from A to B as smoothly as possible. Manufacturers care little for the enthusiast. Well to a certain extent they do, but they generally build a car a appease the masses not the relative few that want more from their car.
TAZ is offline
Old 02-08-2007, 08:07 AM
  #56
Nations 1st 6th Gen Turbo
chernmax's Avatar
OK I just ordered a set (F/R) for my 04 Max with 5spd Auto.
chernmax is offline
Old 02-08-2007, 08:11 AM
  #57
xoomer.com's Avatar
Taz, any update on FSB and MMI (ETA)
Old 02-22-2007, 05:02 PM
  #58
.org extraordinaire
kamski's Avatar
Bump For Chernmax
kamski is offline
Omar Abdurrahman Siddiqi
08-26-2016 05:18 PM
ballerchris510
09-23-2015 08:46 PM
intimidator
09-05-2015 07:23 PM
MaximaDrvr
08-19-2015 08:20 PM
Quick Reply: RACINGLINE MotorMount Inserts
