fluid flowing when starting and accelerating
Hello all,
I bought my 04 maxima last month and absolutely love it. About a week ago I started hearing what seemed to be water flowing when I accelerate. I couldn't tell if it's coming from the roof, door, or from the engine. Yesterday I noticed that the same sound occurs when I start the car. This leads me to think the problem is in the engine. Has anyone ever had this kind of problem, or can speak to it?
Thank you
Thank you
It's been a well know issue. Listed in with the other TSB's I believe. There is a pretty detailed method of elevating the car to fill the coolant and purge the trapped air out of the system. The air in the heater core is causing the gurggling sounds you hear. It shouldn't cause any troubles, but it is annoying.
CM
CM
It does cause troubles, the heater/defroster go cold at idle. (Starbucks drive through, long traffic lights etc.) You can let the damned thing idle in the driveway for two hours and the windshield will still be frozen and the interior cold. Plus it sounds funky.
Originally Posted by foreeyed
thanks everyone. Will this solution fix the problem permanently? Or will this process have to be repeated for the life of the car?
mine has been fixed for a month and half, no problem so far. coolant flush and refill. pressure test.
sctludwig
09-01-2022 01:32 PM
Justin Kroll
09-02-2015 11:06 AM
