Has anyone ever replaced their headlamp bulb?
My right headlight is out, and I dont want to take it to the dealer to have replace it.
I was wondering if anyone has done this before.
Was it easy? Where did you get the replacement bulb?
Thanks in advance.
Thanks in advance.
Do you have the halogens or HID? If you have halogens then the bulb number is 9012. You can't find these in stores (at least I couldn't when I bought mine), but you can find them on Ebay for A LOT cheaper than what the stealership will charge. I changed mine awhile ago and it wasn't very difficult. I can't think of the exact procedure while I'm sitting here at work though.
a guy where i work asked me this today about his 04'+ does the whole headlight just pop out like hte 5.5's? (i have data dots so mine are bracketed in)
and another question, he said both his focs stoped working too...a while ago...and thing thats common there?
(his are halogens b.t.w.)
thanks
thanks
I replaced both the headlight and fog light. It's not hard at all. You can get the parts anywhere. Both regular bulbs if your car is non HID. You have to dsassemble stuff on both sides to gain access but it's If you need any help PM me.
Originally Posted by Barber7272
Does a Sylvania Silverstar 9005 fit in replacing the HIR 9012? Thanks alot
Originally Posted by dopestar129
I believe a 9006 will fit if you shave some plastic off the base. You should read up on the 9012s though. They're pretty cool as far as halogens go, but to each his own.
I just had to go through a hassle with + + + = 4 auto places to determine what type of bulb my car uses. I do not have HID bulbs but they kept insisting I had to purchase the 247.00 D2S headlight bulb for my headlight... I called the dealer 9 times that day and spoke to all different people who had no idea what light, other than the HID-D2S light I could use. Finally one used his head and the computer and looked it up in the manual and found that is was the 9012 HIR (High-Intensity Reflective) Light. Instead of trusting anyone I used the Net to find it and came across a site dediated to these types of lights. It was awesome and I learned that these lights are extrememly similar to HID and use less power. Yes, you can find the bulbs on Ebay for 25.00 which is way better than paying 83 at the dealer.
If you want to know about what your non-HID Max uses follow this link
http://www.finemotoring.com
Hopefully no one has to go through what I went through from 10:30 am til 7pm at night tryin to find a dayum headlight!!!
Also, when I first got my fogs, no one could understand why they were soo high and why they were in the front and the side. I also noticed that they didnt come on EVER... Until I went to an auto shop and they had to change the fuse which was too small (10 watt) so he recommended using a 20 watt fuse. The lights come on perfectly now. Anyone know about getting brighter fog lights?
ONE more thing..... I know in terms of brightness it wouldnt compare.. BUT would you still be able to use the 9006 silverstar ultra whites as an alternative to the 9012 HIR bulbs? Please let me know cuz I dont wanna spend 37 bucks on one of those for nothing!!! Let me know!!
Thanks thats what i figured. The only problem with the HIR 9012s is the price.
Hey everyone i'm new to Maxima.org please help i'm a noob, trying to replace my Stock light with HID kit and dont know howto accesse the headlamp and the bulb please.thank you
Does anyone know how to access or even get to the headlamp in order to replace the bulb or convert it ? step by step? PLEASE HELP NEED TO CONVERT MY Stock to HIDs please.
HID
If you have HID's listen to this...
I've got HID headlights on my '04 and I noticed that my passenger side headlight was out. I needed some new fogs anyway so I took my car apart and replaced my fogs. I bought the wrong style headlamps so I just pushed the passenger side HID headlamp back in and made sure it was in REAL tight! I put it all back together and both headlights worked perfectly.
I guess HID's have to make great connection in order to operate properly! I'd try this before buying new 100 some odd dollar headlamps....
To put new bulbs in is a piece of cake. You will need 1 flat tip, 1 phillips, a pair of pliers, a jack and jack stand. First jack up the side you want to change the bulb in and set the car down on a jack stand. Then using the phillips and the flathead remove the wheel well cover. You only have to remove from the front to the center top. there are two fastners that hold the wheel well cover to the inside cover at the front. those have to be taken off also. then the underside has a couple that need to be removed. once they are removed pull back the wheel well cover to gain access. then simply turn the cover for the bulb and remove the bulb. you can replace the 9012 with a 9006 but you need to cut about a quarter inch from one of the tabs. they fit snug after that so no need to worry. I switched from the 9012 to the Plasmaglow bulbs which come with a 10 year warrenty. If they burn out or anything happens I can return them for a free replacement up to 10 years. worth the cost of $42. Plus they have the glow of HIDs.
it may be that the left one was replaced due to the gas inside the bulb has depleted. but the right one should be on its way if your saying that its purple. when the bulb turns pink-ish or tan color then that means the bulb is dead. barely have enough xenon gas to light up the bulb. your best bet is to replace the bulb. the size your looking for on "ebay" or any other website is D2S - factory standards and kelvin is 4300k. Philips makes a great bulb the number is 85122.
HELP REPLACING FRONT BLINKER 2006SE
Hey Guys I need a little help here.
I have a 2006SE and the blinker on the front right is out. NON-HID lights. How the hell do I replace that dam bulb?
I was looking around and people say that you have to remove your wheel well cover and your front bumper cover to get to the light so you could remove it to get the bulb out. Is that true?
I don't want to take it to the dealership and then get @$$ raped by them for having them do it for me.
Any suggestions help?!?!
Yes, as stated above, you can use the 9006s. You just have to shave some of the tab off on the bottom. Really, though, keeping the 9012s is the best thing. I know the Silverstars have a whiter look, but really the brightness of the 9012s is getting close to HIDs. Just depends what you want: the look or the quality
Going through the exact same hestle for my wife's car ...2004 Maxima.. it has 9012 bulb, but I could not find it on ebay... People told me that 9006 is Xenon, and in order to put that in, I will need HID kit... which seems to be false after reading this thread :|...
Does 9006 had low beam and high beam in the same bulb as 9012? Is it better to upgrade to Xenon kit? What should I do
Actually, looking to clarify few things below...
1. 9012 has low beam as well as high beam in one bulb.. right?
2. Does 9006 has low beam as well as high beam in one bulb?
3. Does 9006 bulb fit without HID Ballasts (is it Xenon or Halogen)
When I search ebay for 9012, it just comes up with the conversion kit .. not a bulb.. The website finemotoring.com is charging 33 bucks for one bulb (including shipping), and I am wondering why dont I upgrade to HID kit, if I am spending that much money
03VQMAX
12-07-2015 04:59 PM
umnitza
09-01-2015 01:03 PM
YourLocalAsian
08-17-2015 02:33 PM
