Noise when hitting bump
Old Feb 2, 2007 | 04:14 AM
Albert's Avatar
Everytime I hit a rising bump I hear a click sound from the front
driver side. Anyone had this problem before? Is my strut gone?
Old Feb 2, 2007 | 05:14 AM
Big Mike's Avatar
My car makes the same noise. I am replacing the front struts with a set of KYB's.
Mike
Old Feb 2, 2007 | 06:32 AM
Albert's Avatar
I have 25k miles on these struts. They are starting to get soft.
I was hoping to get at least 40-50k out of them.
Old Feb 2, 2007 | 06:39 AM
4MySwee's Avatar
Hmm, noticed a sound two days ago from my front end as well. Have to check it.
Old Feb 2, 2007 | 10:35 PM
Killah Kane's Avatar
maxima struts are bad. They dont last very long at all.
Old Feb 2, 2007 | 11:06 PM
Crumbling_Mirth's Avatar
same problem here -
mine are bad to the point where it's a grinding sound...it's worse the colder it is outside (i'm in florida, so it's pretty random every morning)
just turned over 22,000 miles, i've got a fresh drivers side axle waiting at the dealership, i just need to work up the nerve to let them keep my car all day.
i swear, they ALWAYS screw something up...scratch this, or scuff that ...
Old Feb 3, 2007 | 04:13 AM
04BlackMaxx's Avatar
Yeah I know what you are talking about. I notice a small 'tap' from the front end when hitting a bump, It seems to me it occurs when the spring decompresses after a bump. Its nothing Id pay to fix unless it became worse. Is this a bad strut? I never thought so because the handling is same as it ever was, and this dosent even happen alot.
Old Feb 3, 2007 | 05:40 AM
Lovemycar's Avatar
I'm with you i hear a slit tap some times but i beleave thats normal i've
heard the same noise in other car's i also just painted my calipers and didn't see any leaks form the front struts and the handling hasn't changed
Old Feb 3, 2007 | 10:28 AM
MONTE 01&97 SE's Avatar
Yep it does that in our 03 Max and my old 97 did as well and sometimes in our G35.
Old Feb 4, 2007 | 05:35 AM
So basically, nobody thinkis this tap indicates a bad strut? Just a bad, or badly placed something else maybe?
Old Feb 4, 2007 | 06:11 AM
Monotaur's Avatar
I get this noise frequently (I think from both sides), and if I push down on at least one of the sides (just over the wheel) I can hear a 'clicking' kind of sound. Also, when I get in the car sometimes I hear a clicking like sound coming from the front somewhere.
Before the symtoms got this bad (and while I was still under warranty), I asked the dealer if my struts were bad and they said 'no'). Does this sound like one or more of the struts are bad?
EDIT: Also, there are strange thud or popping noises that come the front when going over bumps. They don't always sound like the broken mattress sound people usually associate with struts. However, there is a certain dip in the road on the way to work that I have to hit at about 35 (I try to brake at least a little if traffic allows), and that always make a thud & broken mattress sound, but didn't know if it is just because I am hitting it at speed.
Old Feb 8, 2007 | 12:23 PM
aogburn's Avatar
here also, I just noticed it a few days ago when going over speed bumps (slowly) I hear a squeking to somewhat grinding sound from the front of my max. I am seriously thinking about going to the dealer (maybe stuts going bad. only has 15k onner) Advice needed from loyal maxima owners
Old Feb 8, 2007 | 12:39 PM
KCMAXX's Avatar
KC's FINEST
Alot of it has to do with the cold temps. Mine did it a little today. I think it might have hit 18 here today.
Old Feb 8, 2007 | 06:21 PM
Banginbeats3's Avatar
have the same issue, had both front struts replaced, then new tires, then new endlinks, although handling is better, ride smoother, the same consistent noise never went away!!, I drive in the city all day, and notice it more than anything, I have to baby it over every bump, pothole, R.R. tracks, its very annoying. Im going back to the dealer very soon. I originally addressed this problem at about 24,000 miles, now have 29,000. Warranty is running out!! P.S. everything has been covered thus far....
Old Feb 11, 2007 | 09:07 PM
Smoke_Screen's Avatar
I have been troubled by what sounds to me like a 'clunking' noise from the drivers side front wheel well for months now. I just topped 30K miles on my '04. A while ago, the dealer did the 'recall replacement' of the struts, and it was a while after that I noticed the problem. I have had my car in for 3 routine alignments and Firestone has told me they see no problem with the suspension, and you'd think at least one of those times they'd want to try and sell me something to fix the 'problem' but nadda.
The next step is to return it to the dealer and tell them to find out where the noise is coming from and to fix it.
Old Feb 12, 2007 | 05:05 PM
normkit108's Avatar
That noise is also bothering me as well. everytime I hit a bump I get a clunk clunk noise as you guys mentioned. I'm set on replacing the struts however if they're not strut related, I'm reluctant to do so..
Old Feb 12, 2007 | 07:40 PM
BadBlackMaxSL's Avatar
I have this noise too, I am on my 3rd set of OEM struts at 24,500 miles. One thing I noticed is that when I hit the driveway bump without my brakes on I hear the strut noise and when I hit the same bump at the same speed with my brakes on- it is rock solid, no noise. Could the noise NOT be the strut and maybe the calipers, rotors or axles not being tight enough and that is what is really banging around? Otherwise the car handles great on the road, it is the sharp jolts to the car that make it unsteady.
Old Feb 13, 2007 | 06:07 PM
Lovemycar's Avatar
I can here a slit clunking noise althought it doesn't happen all the time and it's not getting any worse i've had the car for about 6 monhts although
i didn't even notice it till i read this thread i really don't think it's a bad strut
a have removed my wheel and there not leaking at all
Old Feb 14, 2007 | 04:45 AM
Albert's Avatar
The noise appears to be coming from the top of the strut in the hood area.
I noticed that whenever the strut compresses from coming up a dip or a bump on the road, the tapping noise occurs. I didn't hear it until 24k miles.
Old Feb 14, 2007 | 10:46 AM
T800's Avatar
I had similar problems. Sometimes there was a continues clicking noise coming from the front.
Took it to dealer. At first they could not reproduce the sound. Eventually I helped them out with it. :-) They retorqued something and that fixed the noise.
Recently, there was cling-cling noise coming from somewhere under the car. The dealer repaired the heat shield for the exhaust.
All was covered under warranty.
Old Feb 19, 2007 | 01:35 AM
Jrogerb's Avatar
Yep it's the struts, I put KYB's all the way around, klunking is gone....
user 11122324
42
Jul 18, 2022 03:35 PM
D Mason
Jun 21, 2016 04:43 AM
Need help
23
Oct 2, 2015 08:56 AM
uttadms31
Sep 30, 2015 05:24 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
