Kinetix intake installed!!!
Old Apr 20, 2007 | 01:52 PM
  #161
NmexMAX's Avatar
dot dot dot ...
Originally Posted by DeusExMaxima
How do you make a housing?
Please read the link provided mmmmk?
http://forums.maxima.org/showpost.ph...&postcount=143
Originally Posted by Pronto
I really don't see what the big focus on intake, maf and throttle body is.
FI vs N/A. N/A = revs
Our stock TB = 70mm. But...
http://forums.maxima.org/showpost.ph...1&postcount=18
And...
http://forums.maxima.org/showthread.php?t=434821
http://forums.maxima.org/showthread.php?t=517758
Old Apr 20, 2007 | 02:04 PM
  #162
RHMax's Avatar
Newbie just Registered
I searched my friend's shop and came up w/ several pieces of suitable 3" pipings, but I know I don't want metal because of the heat issue. I may go the HomeDepot route for this. The biggest part is to attach to stock airbox, and make it look stock. For those w/ either WAI or CAI, just get a pipe, cut a hole and make the mounting plate for the MAF. The only problem is, it could make the engine runs too lean and POOF... So when I get one made, I'll go to TS and install it there and have Tadashi check it out and retune.
Old Apr 20, 2007 | 02:34 PM
  #163
NmexMAX's Avatar
dot dot dot ...
It WILL make the engine run lean. (Larger housing)
Old Apr 20, 2007 | 02:48 PM
  #164
RHMax's Avatar
I got that from your earlier post. That's why I won't be driving around w/o tuning it first.
Old Apr 20, 2007 | 02:55 PM
  #165
Tek-Niq's Avatar
my rear view mirrors flap like a f-ing bird
what he said.
Old Apr 20, 2007 | 04:02 PM
  #166
DeusExMaxima's Avatar
Originally Posted by Tek-Niq
Deus,
why worry about running lean or so, just go get a dyno done and find out how your car is running.
I see you are looking at spending 500 on a utec without knowing for sure if you really need it.
I dunno why it isn't killing you to find out what you got for your money and find out how efficient the car is running before you mod on.
I think it almost goes without saying that I will need a UTEC since I have had the reflash done, and now the intake.
Its not killing me not knowing my power because I can feel it. But, I will be visiting the dyno a lot in the next few months I think.
Old Apr 20, 2007 | 04:34 PM
  #167
RHMax's Avatar
I think another reflash is all you need, and have TS dyno tune it. UTEC need adjusting when temperature or altitute changes, from what I read.
Old Apr 20, 2007 | 04:47 PM
  #168
Pronto's Avatar
Originally Posted by RHMax
Maybe because your Buick is FI? I'm making a 3" MAF housing to bolt on to the stock airbox, and put it to test. It'll be a little while for the result though.
The turbo is after the MAF. The MAF is 3" diameter inbetween the filter and turbo. Pulling the amount of air through a 3" pipe would be the same for either, one is pulled by engine vacuum, other is from turbo vacuum which is a higher volume. This is on an engine already bigger than the Nissan. As the hp level gets to the 500+ level 3.5" is common but the volume of air needed for that hp level is much greater. Over that they start looking like sewer pipes at 5".
Tuning with a WB (on the car or at the dyno) is the only way you will know if your A/F ratio is correct.
Old Apr 20, 2007 | 05:10 PM
  #169
NmexMAX's Avatar
dot dot dot ...
You guys need to read my damn sticky and get caught up with the electronics behind this.
It's not only the volume, it's the added throttle response and the timing changes that are the benefits.
Old Apr 20, 2007 | 07:09 PM
  #170
Pronto's Avatar
In the first thread one of the responders links to Kenne Bell. He was big into TBs years ago. He touted the 70mm throttle body on them too along with a bunch of other horsesheet. 90% of his stuff has been debunked by the TB community, can't see it being different for any others.
Old Apr 20, 2007 | 09:01 PM
  #171
NmexMAX's Avatar
dot dot dot ...
Ok, moving on...
Old Apr 20, 2007 | 09:03 PM
  #172
RHMax's Avatar
Turbos and superchargers can force more air in the engine than pistons can suck in, isn't that why they are forced induction? What the Max has is a stock 3" TB with a 2.75" MAF housing, so there's like a vacuum effect there. You have a smaller, 62mm (2.45"), TB with 3" MAF housing on your Buick, so your MAF allows more air thru than your TB. You would need larger TB before larger MAF. If this is not the case then what am I missing?
Old Apr 20, 2007 | 10:43 PM
  #173
NmexMAX's Avatar
dot dot dot ...
Didn't read my thread/sticky............did you?
:sigh:
Old Apr 21, 2007 | 10:41 AM
  #174
RHMax's Avatar
:sigh:
Please don be disappointed, NmexMAX...
I did read all you links you've posted. I was talking about just the airflow.
Old Apr 21, 2007 | 12:49 PM
  #175
Apollos2's Avatar
And the second stage, all bolted up. I had to make two holes. One is visible on the upper right side. Tuyhe other bolt is near the metal air condiitoning hose on the left. The other I made a spacer and bolted it to the side. Totally secure now. I have some finish work to do on it, but wanted to get opinions. I may put some thin red pin striping.
I may not quite understand all the tech info coming in (it is appreciated though) but I will say your engine bay is looking sharp!!!
If you want to try something else for what's left of your stock intake, check this out http://www.6thgenmaxima.org/forums/v...235&highlight=
And since your in there cutting up stuff, why not open up that stock intake all way too http://img168.imageshack.us/my.php?i...1010015zh6.jpg
Old Apr 21, 2007 | 11:40 PM
  #176
Not a bad idea. I'm all for more airflow, but I prolly need that UTEC to get more gas in there.
Old Apr 22, 2007 | 12:27 AM
  #177
Nietzsche's Avatar
Deus, what size is your current piping/housing?
Old Apr 22, 2007 | 11:18 PM
  #178
Ill have to check. I am using the Stillen intake, with my own pipe beofre and after the MAF up to teh Stillen pipe.
Old Apr 23, 2007 | 02:36 AM
  #179
Pronto's Avatar
RHMax, the intake track to the turbo is 3". After the turbo the stock up pipe from the intercooler is 2.75" and stock TB is 58mm. Since it's under pressure the TB size is not as important up to a certain hp level. In a total stock state of intake some guys have gone low 12s. An open element filter attached to the MAF is usually the first mod done to Buick. It's been my experience with atmo motors that they benifit from a venturi effect of the intake ie; larger intake going down to a smaller TB.
Old Apr 23, 2007 | 10:28 AM
  #180
RHMax's Avatar
That's why turbo cars gets the most gain when change from stock air filter. Plus you can make more power on a turbo car w/ stock TB by going with larger turbo to a certain point, as you said. The setup we have in the Max is a smaller MAF than TB. With those who went w/ Fujita, they run a little leaner because of larger tubing for the MAF without tuning. I just want the get the same size MAF and TB and keep stock airbox, get a more air at higher RPM and maybe raise the peak a little higher.
Old Apr 23, 2007 | 02:33 PM
  #181
Pronto's Avatar
How are you going to modify the stock air box to accept a larger intake pipe? With the increase in potential flow why do you want to keep the stock air box?
Old Apr 23, 2007 | 03:34 PM
  #182
RHMax's Avatar
Stock box seems to work well for a lot of 350Z guys, with K&N panel. And I dynoed about the same Tek's w/ Fujita CAI with my modified airbox setup and K&N before TS ECU.
Both openings of the MAF housing is 3", the middle tube is 2.75. I don't want to hack up my stock one because they're $200 used and $500 new, so I'll use a PVC or something. I'll get to it in the next week or so, I hope.
Old Apr 23, 2007 | 05:43 PM
  #183
Pronto's Avatar
http://www.fullthrottlespeed.com/items.asp?CartId={57DA918E-A715-4B03-ABE7-6E477EVEREST75C5DEA}&Tp=&iTpStatus=1&Cc=PIPES
This might help for the pipes.
Do you have any pictures of the modified stock box?
Old Apr 23, 2007 | 06:23 PM
  #184
I was looki ng at the intake a few moments ago, and I'm wondering if the front scoop can be attached to some kind of sealed box which contains an open element which then goes to the MAF and then throttle body. If the battery was relocated to the spacious trunk, that would make tons of room for a sealed airbox. Any ideas?
I also like the idea of a larger pipe funneling down to the throttle body to create a Venturi effect.
Old Apr 23, 2007 | 07:08 PM
  #185
RHMax's Avatar
Thanks for the link. I found one of those tubes at my friend's shop, but I think plastic/PVC so the sensor won't get too hot.
No pics, just remove the lower resonator so more air can get in the box than the stock long neck intake. Some said it doesn't make a difference, but it works for me.
Old Apr 23, 2007 | 07:09 PM
  #186
RHMax's Avatar
You can make a cover like stock box with openning in the fender like a CAI.
Old May 3, 2007 | 03:57 PM
  #187
GrimMax's Avatar
Where is my shirt?
Did removing the engine cover make your hood feel hotter or anything during a regular drive?
Old May 3, 2007 | 05:53 PM
  #188
No, since it only covers the front valve cover.
Old May 4, 2007 | 05:40 PM
  #189
GrimMax's Avatar
Where is my shirt?
Awesome thanks bro. Great job on it. My lady is going to buy this for me on my B-Day!! lol I will put pics of my max up soon. Thanks again.
Old May 4, 2007 | 10:20 PM
  #190
Looking forward to pics of it. I have my engine cover off in preparation for paint. I removed the ugly NISSAN logo and filled it in.
Old May 5, 2007 | 01:09 AM
  #191
VQPRO's Avatar
nice mod it looks great, camshaft upgrade would go great with that IM longer and more valve opening
Old May 5, 2007 | 09:03 AM
  #192
I `certainly have cams in mind. Not thrilled about it being a 13 hour job though. I may wait until I get headers.
Old May 5, 2007 | 05:59 PM
  #193
GrimMax's Avatar
Where is my shirt?
Nice!! So does the engine cover fit back properly after the manifold was installed? Oh wow!! Do they even make Cams for the 6th Gen? I concur with you on getting the headers first.
Old May 5, 2007 | 06:02 PM
  #194
NmexMAX's Avatar
dot dot dot ...
Z33 cams fit the A34. So, whatever aftermarket cams fit the Z33 (350z), they will also fit the A34 (6th gen)
Old May 5, 2007 | 09:16 PM
  #195
I had to mod the engine cover to fit. I am presently sanding it to prep it to paint it after removing the nissan logo and filling in the impression left by the logo.
Old May 7, 2007 | 06:37 PM
  #196
GrimMax's Avatar
Where is my shirt?
Nice!! Ok thanks for the heads on the engine cover. Looking forward to pics of the cover when complete.
Old May 8, 2007 | 09:45 AM
  #197
GrimMax's Avatar
Where is my shirt?
Way off topic but... Where can I purchase the CE Y-Pipe??? I cant even get there website or the 800 number??? Any clues to this???
Old May 8, 2007 | 12:33 PM
  #198
CE is out of business. Cattman is making a y pipe that should be ready shortly
Old May 8, 2007 | 06:47 PM
  #199
GrimMax's Avatar
Where is my shirt?
Ok thank you very much for that info. I was going crazy trying to find them. Guess I gotta make the intake priority again. Again; thanks for the info.
Old May 9, 2007 | 02:04 AM
  #200
Ritz's Avatar
Grim, if you really want a CE y pipe, Cattman and Taz (racingline) were selling the remaining pipes for cheap since CE went down.. I don't know if they have any left though, but it could be worth a shot.. but if money's not an issue, and you want a better quality one, I'd definitely wait for Cattman's.. I'll be swapping out my CE pipe for his when it's out, more than likely.
