Upgraded to HIDs *pics*
Old Apr 14, 2007 | 09:42 PM
AscendantMax's Avatar
The install wasn't as bad as I thought it would be. The hardest part for me, was removing the bumper. But after some tips from the forums, I got it off.
Stock 9012 HIR2
4300K HID
Dropped the bumper so I can get the headlight assembly out. Each assembly is held on by two bolts on the top, one on the side, and two on the bottom of the housing. Hence the reason to drop the bumper so that these bolts can be accessed.
Coverage on the road (with fogs on). Looks much better in person when compared to the pic.
The cutoff pattern. It's not much different (if any) then 6th gens with factory HIDs. But I must lower the passenger side down a bit...seems a bit high.
The kit I got is the 9006 model. The tabs on the 9006 didn't fit all the way in, so one of the tabs on the bulbs needed to be trimmed down. After a little trim, it twisted and locked in just like the stock ones did. Other than that...the kit installs just plug and play. Then a 1" hole is drilled on each endcap to allow the wires to pass through, and finally connected to the ballast.
Old Apr 14, 2007 | 10:17 PM
!PrjctMax!'s Avatar
naice! ...now do something about those fogs and turn-signals...
Old Apr 14, 2007 | 10:22 PM
haha i think i'll leave the fogs and turn signals alone for now.
although i do like the idea of HID fogs...
Old Apr 14, 2007 | 11:30 PM
nismos14's Avatar
§è~® f®ÈÄk
HID fogs for the win, check sig
Old Apr 15, 2007 | 05:14 AM
Ephraim's Avatar
is this how it is for all 6th gens?
looks like it turned out nice though.
Old Apr 15, 2007 | 06:55 AM
SmokinMaxSE's Avatar
SmokinMaxSE
Nice. Now all your neighbors knows how to get your headlights.
Old Apr 15, 2007 | 08:42 AM
larsim's Avatar
Wink. I'll do the rest.
Stock 9012 HIR2
4300K HID
Gosh, it seems like a LOT of work....
Old Apr 15, 2007 | 01:40 PM
it's not really that bad, but the end result is very much worth the effort
Old Apr 15, 2007 | 04:30 PM
maX5's Avatar
looks nice, how do you reaim the headights ? Which screw is it that you turn in the back ?
Old Apr 15, 2007 | 08:02 PM
not sure lol, i haven't tried to reaim them yet.
Old Apr 15, 2007 | 10:40 PM
kidd4l's Avatar
Cool Member
Link to adjust headlights:
http://forums.maxima.org/showthread.php?t=376775
Old Apr 15, 2007 | 11:42 PM
oh wow, didn't know you're a member over here...
thanks dude for the link.
Old Apr 16, 2007 | 09:59 AM
kidd4l's Avatar
Cool Member
Haha... No problem man.
Old Apr 16, 2007 | 10:40 AM
chernmax's Avatar
Nations 1st 6th Gen Turbo
Excellent, welcome to the club...
Old Apr 17, 2007 | 04:35 PM
thanks
now debating if i want HID fogs to match.
Old Apr 17, 2007 | 04:48 PM
nismos14's Avatar
§è~® f®ÈÄk
Yes, yes you do.
Old Apr 21, 2007 | 08:58 AM
SEmy2K2go's Avatar
Go BUCKS!!!
Looks good Gordo.
Finally was able to check them out.
How easy did the bumper go back ON?
Old Apr 23, 2007 | 01:25 PM
xoomer.com's Avatar
I Donate! Why Don't You?
You should have done fogs while you were there. gosh, my set has been sitting on the shelf so I shouldn't say much here. but yeah go for it. I've seen some at local meets, awesome.
Old Apr 24, 2007 | 10:55 PM
Matts04Maxima's Avatar
DO you have high beams (*brights*) with the kit now ?
Old Apr 24, 2007 | 11:06 PM
Originally Posted by SEmy2K2go
Looks good Gordo.
yeah, the bumper was fairly easy to put back on heh. it was sorta hard because it wasn't able to reach a few bolts. but i got the hang of it now.
yeah, i still have high beams. the stock 9012 bulbs are single filament. there is a shield that moves out of the way inside the projectors to allow high beam operation. under regular low beam mode, the shield is in place to block off some portion of the light so you'll get a cutoff line and not blind everyone.
Old Apr 25, 2007 | 08:05 PM
allmotorVQ35's Avatar
Looks good, I did it exactly the same way. Anyone know if our fogs are regular H3 or do I need to go with mini's if I go HID fogs?
Old Apr 28, 2007 | 05:43 PM
SickSE
Man I can not tell you how freakin jealous of you I am right now. I just ordered a pair, they came in and they were the wrong pair!!!! Just making sure you used 9005 bulbs right?
BTW-It looks sick.
Alex
Old Apr 29, 2007 | 04:43 PM
SickSE
What is the correct bulb? 9006 you say, but I was told by the an installer to get 9005........ Which one should I order????
Alex
Old Apr 30, 2007 | 09:48 AM
kidd4l's Avatar
Cool Member
I use 9006
Old Apr 30, 2007 | 09:52 AM
yeah, i used 9006. there's one tab that needs some minor trimming to make it fit into the socket.
Old Apr 30, 2007 | 11:01 AM
9006 here also. I think 9005 is very similar and either will work.
Old May 1, 2007 | 07:15 AM
turbodub's Avatar
Damn i want to upgrade to the HIDs but im not sure i want to take off the bumper. It seems so worth it though!!
Old May 1, 2007 | 09:11 AM
It wasn't as hard as I thought it would be, just took a long time because it always does the first time around, and I was being careful to not break any of the tabs and trying to remember where they need to go when I put it back together. Well worth the effort.
Old May 1, 2007 | 09:37 AM
97gshogun's Avatar
lights look great man!!
Old May 2, 2007 | 11:02 AM
cpar's Avatar
Cant help but notice your light pattern on the wall is the same as mine. I have a 06' SE with stock HIDs, the pattern drive me nuts! Why does Nissan have such a bad design with the headlights? I like the color but the light orientation from the low left side, to the high right side they emit at night is annoying. I tried to have the dealer align them twice, but after comparing them to regular halogen bulbs on another Maxima, they have the same crazy alignment. Does this bother anyone else? Dealer said it was a poor design of Nissan.
Old May 2, 2007 | 12:11 PM
Houstonhulk's Avatar
Max where did you get the kit.
Old May 2, 2007 | 12:28 PM
STILLENGLE's Avatar
Why dont you use the search for the topic he created.
Old May 2, 2007 | 12:37 PM
i don't think it's nissan's fault. my friend said the cutoff pattern is typical of e55 projectors. i asked my seller about the cutoff and he said the elevated right side helps light up road signs and such so it'll be easier to see. i lowered it a tad though...and so far it doesn't seem to be blinding anyone. i had a friend drive in front of me, and coming towards me...and he said there's not much glare (if any).
http://forums.maxima.org/showthread.php?t=515274
got it from that dude...he's in Houston as well.
Old May 2, 2007 | 01:48 PM
xoomer.com's Avatar
[QUOTE=AscendantMax]i i asked my seller about the cutoff and he said the elevated right side helps light up road signs and such so it'll be easier to see. QUOTE]
Yep, the passenger side is supposed to be a bit higher to light up the roadside, signs and peeps or bicycles there. The driver's side is lower as not to blind oncoming cars. Its been always like that whether with conventional lights or HID...when properly aligned of course.
Old May 5, 2007 | 05:05 PM
SickSE
Hey, I just got finished putting mine in, they looks awesome. One last problem, I got some moisture in the left light. What did you guys used to seal the lights after you were done?
Alex
Old May 5, 2007 | 05:16 PM
no moisture problem here....just let it air out or something. did you open up the entire headlight or what?
Old May 5, 2007 | 06:37 PM
crazyjeff100's Avatar
Man nice work! I'd be so afraid of trying that myself. I could probably get it stuff off, but no way I'd get it back on.
Old May 5, 2007 | 06:38 PM
Now that is cool looking!
Old May 6, 2007 | 08:58 AM
SickSE
Tonight when I turned them on, only one came on. I switched them both off and back on then they both lit up. Does this sound like the moisture is messing with it or just a loose connection somewhere??
Alex
Old May 6, 2007 | 10:25 AM
mike5411's Avatar
Check the wiring, relays and connections.
MaxLife17
Jun 27, 2019 01:37 PM
Fbana41
Aug 29, 2016 12:18 PM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
Vistance
Sep 17, 2015 05:17 AM
