Coolent System Flush Needed... $$$ = stealership
Old May 31, 2007 | 02:21 PM
2LEET4U's Avatar
It time for my coolent flush. Ive noticed that my air isnt as cool and takes long to cool off in the car.
I have yet to do a coolent change in the car. So it may be time.
The local stealership is charging 79.95 for this service. Should I go to a local auto-repair and get it down cheaper????
I dont want them f&^%ing up my max....
Old May 31, 2007 | 02:58 PM
gen4maxima536's Avatar
you mean you need to have your AC system checked for leaks and recharged?
Old May 31, 2007 | 05:14 PM
lobewiper's Avatar
Originally Posted by 2LEET4U
It time for my coolent flush. Ive noticed that my air isnt as cool and takes long to cool off in the car. I have yet to do a coolent change in the car. So it may be time. The local stealership is charging 79.95 for this service. Should I go to a local auto-repair and get it down cheaper????
The term "coolant" normally refers to the contents of the engine cooling system, and includes anti-freeze and/or water. Changing that will have no discernable effect upon your air-conditioning system. I assume you mean, as suggested by the previous poster, changing the the refrigerant in your air-conditioner. If your car is still under warranty, and there is a leak somewhere, the dealer should fix it for free. If it's not under warranty, I still would want the dealer to leak test and recharge the system, because they've had a lot more experience with your car than the local shops have. It sounds as though your system is leaking refrgerant...
Old May 31, 2007 | 06:32 PM
2LEET4U's Avatar
good point lobewiper....
i am pretty sure i am not leaking because i dont see any leaking in my drive way.
I am just assuming it needs a good flush.
Old May 31, 2007 | 07:06 PM
4MySwee's Avatar
you wont see the refrigerant for the ac leaking because it is gas like and disipates, (Someone more knowledgeable, correct me if I am wrong).
You could see radiator fluid leaking. That's the greenish color.
Old May 31, 2007 | 09:38 PM
usually you dont have your AC system flushed. maybe they might evacuate it then recharge it.
and yes swee, you wont see it leaking unless it has been treated with dye, in which case it will stain the area around where it is leaking.
Old Jun 1, 2007 | 05:32 AM
4MySwee's Avatar
Ok, thank you.
Which is it 2Leet? Are you having AC issues? Or is the car in general, running warmer as indicated by the temp gauge? Your symptoms will indicate which item needs attention.
Old Jun 1, 2007 | 06:55 AM
2LEET4U's Avatar
my fault.....
i am talking about my AC in my car..... It's not as cool inside as it was before.
Old Jun 1, 2007 | 09:30 AM
kidd4l's Avatar
Cool Member
Check the AC hose, Rick. I had mine replaced because it was leaking.
Old Jun 4, 2007 | 10:45 AM
2LEET4U's Avatar
yep. it had something to do with an AC hose and leakage. It blows nice a cold now, versus a cool wind. Also it seems after fixing the hose. im getting better gas mileage. I will confirm in a week.
Old Jun 28, 2007 | 06:27 PM
GrimMax's Avatar
Where is my shirt?
Yeah check the hose. If your AC isnt rocking like it use to then your freon is low. Freon is what makes the AC cold.
I always say go to the dealer. That way you dont have to put up with the whole "Thats gonna charge you extra" mechanics. You Max is worth the extra 20 bucks.
user 11122324
42
Jul 18, 2022 03:35 PM
Miket2006
Mar 1, 2021 03:55 AM
MichMaxFan
Sep 30, 2015 09:18 AM
Socalstillen
Sep 26, 2015 12:01 PM
