making memory seat work while moving.. help!
Old Jun 4, 2007 | 03:32 PM
Y2k2maxse's Avatar
I think its quite annoying that the memory seat won't let you use the function unless you are stopped with the emergency brake engaged (6MT) as when in my daily route, I go from city to highway driving, and than later back to city I move my seat back some and down, steering wheel out, and mirrors. Does anyone know what wire(s) Id have to modify to make it always think the car is stopped w/the brake up? Or is that even possible?
Old Jun 4, 2007 | 06:41 PM
RichA's Avatar
Do you mean being able to set the memory on the seats? My seats adjust any time but I can't lock the settings unless I'm in park.
Old Jun 4, 2007 | 08:07 PM
Ritz's Avatar
I think he means switch the setting from 1 to 2...
I'd think it's possible.. it's a safety feature, similar to navigation options being disabled while driving...
might be harder to do with a manual, because of the ebrake thing....
Old Jun 5, 2007 | 05:15 PM
BadBlackMaxSL's Avatar
Why don't you have position 1 as your city driving position and 2 as the highway cruising position. Then, before you set out on your trip, hit the button for the type of driving you will be doing. Problem solved.
When you are at a red light and near to getting on the highway, pull your E-brake and hit the button. And after you get off the highway, do it again.
Old Jun 5, 2007 | 07:28 PM
pmohr's Avatar
No more Maximas...
Just bring the ebrake up one click while driving, good to go. A little wear on the parking brake shoes for a second or two. Same thing my friends do on their S10s to keep the DRL's off...except they drive with it on one click all the time.
Old Jun 6, 2007 | 07:22 PM
Y2k2maxse's Avatar
I tried these things...ebrake up..but you have to be stopped too. I dont hit any lights at the convienent times to change positioins. i drive city for about 5 mins..than I want to switch to memory 2 (highway mode) for about 45 mins..than w.o stopping i drive in the city again for about 20 mins (back to memory 1, city mode) the lights I encounter are rarely red..so its hard.
Old Jun 8, 2007 | 10:33 PM
Ritz's Avatar
read up on the navigation fix for the same thing.. the nav shouldn't work while moving either.. should be the exact same fix, and then just pull the e-brake one click..
Old Jun 30, 2007 | 09:03 PM
MAXIM0's Avatar
You dont need the e-brake the car just has to be in park with the engine running.
Old Jun 30, 2007 | 10:29 PM
Ritz's Avatar
we're talking about a manual transmission.
you got your 15 posts and then some. chill out on the post whoring.
Old Jul 5, 2007 | 02:40 PM
Y2k2maxse's Avatar
thanks guys ill look up on the navi fix.
Old Jul 7, 2007 | 05:00 PM
bushpilotmexico's Avatar
Thanks for the info.
scutmud
Aug 16, 2018 10:56 AM
scutmud
Jun 30, 2016 05:16 AM
jerrod99_se-l
Aug 27, 2015 08:27 PM
criminalslang810
Aug 16, 2015 08:12 AM
kenc15
Aug 5, 2015 08:29 AM
