squeaky clutch!
squeaky clutch!
My clutch tends to squeak a lot, sometimes when engaging, sometimes when disengaging. Is there any simple or quick fix to this? As far as Im aware, I have to replace it. Otherwise it works fine, just an annoyance.
Is it the clutch pedal or coming from under the hood? If its under the hood, theres a rubber piece thats attatched to the tranny on the top front side. pull the rubber piece out and put some grease in there using your finger. Try to use a grease with no detergents and oil based. It will keep it from squeeking again for a long time. If its the pedal itself then you can use the same type of grease or even a silicone based grease in spray or tub form and just rub every joint and moving part down and it should go away. Its worked for me in the past. Good luck.
AHH!!!! IT WORKED! lol thanks again guys..that was a HUGE annoyance to me..especially when I have people in the car. stupid dealership told me i needed a new clutch.. i put grease under the dashboard on the moving parts of the clutch..squeak went right away.
-inside the hydraulic piston?
-at the ball/socket joint between the end of the pushrod and the clutch fork (just outside that rubber boot)?
-down inside the clutch housing?
I tried hosing down the first two items with Tri-Flow (maybe not the best long-term lube, but it makes troubleshooting easy), but the noise is still there.
I pulled the rubber boot out of place to peer inside the clutch housing, but I'm reluctant to just spray lubricant randomly inside there.
Ideas?
Yea just pull out the rubber piece and put lube down in there. I wouldn't use a spray lubricant because its very thin and will wear off quicker. Use a thick grease for that area and make sure it has no detergents so it will last longer. Forget the type I used exactly but go to the autoparts store and ask them, they will probably know. I'm sure bearing grease would do the trick. Dont be scurred its just the fork down in there and the slave cylinder. It wont hurt anything.
Mar 12, 2020 12:06 AM
spencerwh1
Jun 30, 2016 05:44 AM
carlosvq30
Sep 26, 2015 09:44 AM
