Headlight Lenses.. HELP
Old Jun 7, 2007 | 06:24 PM
Elimackman's Avatar
I installed a plug and play convo kit for my headlights and today I noticed that the headlight lenses were fogging up... I never noticed this before so I'm thinking it has something to do with the install. Any ideas?
Old Jun 7, 2007 | 06:31 PM
MaximaGT-R's Avatar
I'm a Happy Man!
check the placement of the bulbs to make sure u have installed it correctly. fog could be caused by you not tighting the bulb in correctly.
Old Jun 7, 2007 | 07:35 PM
SickSE
Same problem last week...Tried multiple attempts to get rid of fog. Gave up, fog keeps coming back. Buying xenon headlights which just plug in and go. Sorry for the bad news but I just hope to save you some trouble.
Alex
Old Jun 7, 2007 | 08:14 PM
jsmithsole's Avatar
*moderator*
It would have to be the seal for sure. Good luck...
Old Jun 7, 2007 | 08:30 PM
watsupbabyboy's Avatar
I had the same problem but my kit was a kit for 9006 because there was not other kits available at the time, I'm not sure if they actually make the correct bulb to fit the weird 9012 but I had to slightly cut parts of the socket to make the bulb fit....if it does fit perfectly for your kit then it's like what J say....it's got to be the seal....I couldn't get rid of the fog problem and it was really bothering me so I just ended up buying some used OEM headlights w/ HID on ebay. I really liked the 8000K I had on the kit but I'll live with the stock 4300K just so I wouldn't have anyone mistaken my headlight as a fish tank....
Old Jun 7, 2007 | 09:07 PM
AscendantMax's Avatar
no issues of fogging here with my 9006 aftermarket HID kit. is the end cap screwed on correctly?
Old Jun 8, 2007 | 12:27 AM
SickSE
look behind your projectors, there is usually some forming there with bolt on kits
Old Jun 8, 2007 | 07:07 AM
Elimackman's Avatar
ah, seems to be a common problem then.... I'll continue to monitor it to make sure that it won't interfere with night vision.. thanks
Old Jun 8, 2007 | 09:32 AM
turbodub's Avatar
take a hair dryer to the lights!!
Old Jun 8, 2007 | 09:34 AM
CanadianMoFo's Avatar
Hair dryer in one hole, open another to let the moist air out.
Alternatives include putting in a silica gel pack to absorb moisture.
I found that after I did my HID upgrade I had fog for a couple weeks, but it went away eventually. Only returned when I pressure washed the engine bay. Disappeared after a good couple days in the sun.
CM
Old Jun 8, 2007 | 12:22 PM
i dunno man, it's been well over a month now and no fogging issues here...
Old Jun 8, 2007 | 12:47 PM
Elimackman's Avatar
i've noticed one side is worse then the other....
Old Jun 11, 2007 | 07:53 PM
spatel8600's Avatar
my brother had the same problem. he bought a whole new headlamp but when we took off the old one.. we noticed the bottom part of the cover wasnt complete on.. so over time it got fogged up.. but havnt really heard of it instantly doin it.. but u neva knw wit otha places n the humidity ther
Old Jun 11, 2007 | 08:29 PM
Elimackman's Avatar
Ya the lenses are still fogged... I'm thinking it could have been when I had to drill a hole to run the wire through the plastic... But i used silicone and tape to cover up the hole. a friend said that I should have left the lights installed for a few hours before turning them on. Not sure about that
Old Jun 12, 2007 | 01:29 PM
SickSE
ROFL, I drilled the exact same hole. Currently have the exact same problem as you bro. Looking for some used oem hid headlights right now because im sick of taking the bumper off and correcting it.
Alex
doctorpullit
Oct 28, 2019 10:58 PM
trsandrew
Apr 8, 2016 06:45 PM
knight_yyz
Nov 1, 2015 01:34 PM
trsandrew
Oct 25, 2015 02:47 PM
Noela
Sep 26, 2015 08:22 AM
