Painted Calipers
Old Jun 9, 2007 | 09:42 PM
Elimackman's Avatar
Painted Calipers
Anyone know of a good place to get the calipers painted in South Florida?
Old Jun 9, 2007 | 09:43 PM
Ritz's Avatar
for like $5 you can get caliper paint from your local parts store..
Old Jun 9, 2007 | 10:13 PM
DeusExMaxima's Avatar
For $15 you can get a whole kit from Dupli-color.
Old Jun 9, 2007 | 11:40 PM
jsmithsole's Avatar
*moderator*
Yeah just buy the paint, I would've painted mine my elf but at the time didn't have the tools/space. I just had the guys that installed my brakes do it, they didn't even charge me, it's really easy. I'm sure someone would charge you an arm and a leg if you let them....
Old Jun 10, 2007 | 07:36 AM
Elimackman's Avatar
Tire Rack wanted 35 or so....
Old Jun 10, 2007 | 08:36 AM
bigwei's Avatar
What Deus said...
http://duplicolor.com/products/caliper.html
I used it on my Prelude's calipers about two years ago and they still look good...
Before...
After...
I found the kit at Walmart. AutoZone and other auto stores should carry too.
Old Jun 10, 2007 | 09:42 AM
2LEET4U's Avatar
Duplicolor FTW..........
Old Jun 10, 2007 | 12:34 PM
SER Max's Avatar
I painted my brake calipers.. I used VHT Brake caliper paint in a spray paint form. I gotta say, taping off the brake caliper and then grinding the corrosion off was a pain in the *** and time consuming, but I was satisfied in the end. The red VHT caliper paint looks red in sunlight and sort of orange when your parked indoors. Hope this helps..
http://i101.photobucket.com/albums/m...Picture015.jpg
http://i101.photobucket.com/albums/m...Picture016.jpg
Old Jun 10, 2007 | 01:02 PM
Nismo Scorpion's Avatar
Walmart 15$ Brush on kit took way longer than i wanted it to...
But it was worth it!!!
Old Jun 10, 2007 | 01:12 PM
sebaztian's Avatar
did you took it down or mounted?
Old Jun 10, 2007 | 01:19 PM
im lazy i left them mounted
Old Jun 10, 2007 | 02:59 PM
SuperMario's Avatar
I'd like to get the calipers that say 'NISSAN', like Chernmax. Those are nice!!!
Also, SER Max, where did you get that grille? I want one just like it!
Old Jun 10, 2007 | 03:46 PM
MaximaRacer_95's Avatar
do it your self..get some high temperature paint like the ones they use for barbque grill and stuff...this is what i used its been 2 months and still shines like if i painted it today...here a pic
Old Jun 10, 2007 | 03:52 PM
Ajlal24's Avatar
NO MASKING FTW!!!
Old Jun 10, 2007 | 04:13 PM
lowpro19s's Avatar
You can also use the folia tec brush on kit. It comes with high temp paint and separate hardening lacquer that you have to combine then brush on. I did it when i had my 5th gen but i put two coats and then followed up with a nice coat of high temp clear. Makes it easier to clean and brake dust doesnt stick as easily and keeps them shiney much longer with no color fade. Downside....its not 15$. aprox $50-60.
Old Jun 10, 2007 | 05:45 PM
SER Max's Avatar
My grille was from www.activetuning.com the S4.1 Grille. Check it out, they got lots of other Max stuff there.
Old Jun 11, 2007 | 09:31 AM
The Presence's Avatar
Painted calipers make a huge difference in the appearance of your wheels, Alloy, gunmetal, brush aluminum and especially chrome. I used a brush kit @ first then touch them up for a real high temp spray, to bring out the awesome gloss. The G2 brush kit is really good or you could try the Metal cast from any auto parts store.
Old Jun 11, 2007 | 07:36 PM
spatel8600's Avatar
where did you get your painted calipers? or did u paint them urself?
Old Jun 12, 2007 | 09:07 AM
Of course if you have larger brakes, it looks even better!!
Old Jun 12, 2007 | 12:56 PM
I believe a lot of guys on this post did a D.I.Y caliper painting project, including myself, it's really easy. If you want a professional finish, remove all the components that you want painted and spray them separate from the car or wheel well. But I've seen guys just mask off the areas that they don't want painted an use a really good O.T.C High Temp. Spray paint, an the outcome is excellent. My calipers have been painted a little over a month now, an the paint/gloss coat is like new.
Old Jun 12, 2007 | 04:14 PM
MAXDOUT04's Avatar
* THIS SPACE FOR RENT *
Old Jun 12, 2007 | 04:16 PM
MAXDOUT04's Avatar
That looks good
REDinLV
Aug 15, 2024 12:30 AM
litch
123
Jan 4, 2024 07:01 PM
Apr 16, 2020 05:15 AM
imported_Nismo_max
Sep 21, 2015 07:24 PM
beerman1378
Sep 8, 2015 02:19 PM
