Cold air box for Maxima
Old Jul 9, 2007 | 09:36 PM
  #41
d00df00d's Avatar
Old enuf to pick his own gears
You really need an open-top filter!
What is the diameter of the CAI tubing?
Old Jul 9, 2007 | 09:55 PM
  #42
DeusExMaxima's Avatar
Ur right. Im going to look into that this weekend. That way, the air channels right into the opening of the air filter.
Old Jul 9, 2007 | 09:57 PM
  #43
3 inches i think
Old Jul 9, 2007 | 10:11 PM
  #44
d00df00d's Avatar
https://www.amsoil.com/storefront/eaau.aspx
PM talkinghorse and ask for the Amsoil EaAU3051.
Old Jul 10, 2007 | 12:01 AM
  #45
The only problem is my adaptor is much larger. ill have to measure it tomorrow am.
Old Jul 4, 2008 | 11:41 PM
  #46
Update: Im thinking of putting my newfound fiberglassing skills to work and building what I really wanted - a sealed ram air box that draws air front my front factory (but opened up) scoop. i may actually be able to get slight pressurization at highway speeds. I can use my heat shiled as one side of the box and build a mold for the other sides and then make an opening in which the factory scoop would slip over and clamp down. Thoughts, suggestions, opinions?
Excellent write up of ram air:
http://www.vararam.com/ramairinaroadcar.html
Old Jul 5, 2008 | 05:34 AM
  #47
Apollos2's Avatar
When you mean sealed, are you saying the only air coming in would be from the stock intake scoop? ie......nothing from the fender well which I am sure is missing the stock resonator box. If so I don't know if you will get enough air, I like our stock scoop but, I've opened mine up too for testing purposes and I think the problem with it is the crimp before it gets into the engine bay (as it goes by the battery).
Old Jul 5, 2008 | 08:47 AM
  #48
I thought about that crimp as well. I kind of unkinked my crimp with a heat gun to make it more round. I'll look into taking air from fenderwell, but the problem is that I am looking for pressurized air being rammed into the scoop, and I dont believe it is pressurized behind the fenderwell. I could draw air from under my splitter, but then the last thing I need is less ground clearance.
Old Jul 5, 2008 | 09:45 AM
  #49
DMT's Avatar
DMT
Originally Posted by DeusExMaxima
I forgot to mention that a few weeks ago, I cut out the right side of the OEM air scoop which sits over the radiator. For some reason Nissan blocked the right side. I unblocked it so it allows more air into the air filter area.
BEFORE:
AFTER
Nice job. Anyone know where to get a piece of foam that goes over the air intake? Mine's kinda chewed up
Old Jul 5, 2008 | 09:51 AM
  #50
Apollos2's Avatar
Yeah, we fuss about a tiny crimp in the exhaust, that one in the intake is much worse IMO. I think we would have to relocate the battery in the truck to really eliminate this problem. But I like the concept
Old Jul 5, 2008 | 09:55 AM
  #51
Apollos2's Avatar
Check this thread
http://www.6thgenmaxima.org/forums/v...1235&highlight
Old Jul 5, 2008 | 10:56 AM
  #52
Or, do what I did and get a smaller,lighter battery. I got a 28 lb battery to save about 15 lbs of weight which should also give me enough room to widen the crimp. I may even chop off the crimp and build the fiberglass box to a wider part of the scoop. Still working on the GTR Proto rear, but this will be my next project I think.
Old Jul 5, 2008 | 11:35 AM
  #53
hybridioN's Avatar
all teh single ladiez
that looks amazing. with a little fine tuning, you could have it looking like one of these:
Old Jul 5, 2008 | 11:39 AM
  #54
Well that looks pretty cool, but I dont think its the same idea. Im looking for a sealed system that may actually build pressure at highway speeds. That looks more like a neat looking open element filter.
Old Jul 5, 2008 | 11:55 AM
  #55
DMT's Avatar
DMT
Sweet. Great find. Thanks!
Old Jul 5, 2008 | 01:50 PM
  #56
NmexMAX's Avatar
dot dot dot ...
The ID is 2.75", if it were 3", it would run lean as shat.
Old Jul 5, 2008 | 02:45 PM
  #57
ID of what, Nmex?
Old Jul 5, 2008 | 03:31 PM
  #58
07 Graymax's Avatar
hey dues i've done the same to my scoop awhile back, does look better with it smoothed and cleaned up, you've seen mine and the foam, dmt, check home depot in the door jam foam area
Old Jul 5, 2008 | 04:02 PM
  #59
NmexMAX's Avatar
dot dot dot ...
ID of the intake piping.
Old Jul 5, 2008 | 04:13 PM
  #60
slvrmax7's Avatar
[QUOTE=DeusExMaxima;4851607]I forgot to mention that a few weeks ago, I cut out the right side of the OEM air scoop which sits over the radiator. For some reason Nissan blocked the right side. I unblocked it so it allows more air into the air filter area.
Great Idea man Ill'e do this tonight!!!
Old Jul 5, 2008 | 11:51 PM
  #61
Yeah I have to replace my foam for sure and paint the scoop like Graymax. I really dont know why Nissan blocked it off.
maxinout93
Oct 27, 2015 01:29 PM
cheftoo
Aug 20, 2015 05:17 AM
Balkins
Aug 12, 2015 06:39 AM
kirkhilles
Aug 8, 2015 10:53 AM
