Transmission fluid question.
Old Jun 17, 2007 | 11:55 AM
Muyrec's Avatar
Exactly how much fluid is in the tranny if the oil marks the tip of the dipstick? I went to check on the fluid today and noticed it it barely marks the tip. I did a triple check to see it wasn't just a fluke but sure enough it kept on marking the tip. I did the steps correctly as well. I think the Nissan dealership is trying to sabotage my car. Got the car at 26,100k 2 months ago and hasn't been change.
Old Jun 17, 2007 | 12:00 PM
4MySwee's Avatar
I have had mine since it's beginning, it now has 45,xxx miles on it. I haven't changed the fluid yet. We aren't supposed to for a while since it is a type of synthetic.
I'm not sure why your reading low. Might be worth taking it in and asking.
Swee
Old Jun 17, 2007 | 12:55 PM
!PrjctMax!'s Avatar
stupid question...............but did you have the car RUNNING for at least 30 minutes and RUNNING while you checked the fluid?
Old Jun 17, 2007 | 01:04 PM
Muyrec's Avatar
I let it heat it up till normal temps. then drove for 10 mins. made sure it went through all gears. then checked it.
Old Jun 17, 2007 | 01:41 PM
Albert's Avatar
My ATF level was low since the day it rolled off the dealer lot.
I think some other org members also noticed that.
I just bought one qt and filled it to the proper level.
Old Jun 19, 2007 | 01:33 AM
Muyrec's Avatar
Hmm, i'll just do a flush and refill then. Got some matic k here. Anyone have a guide on how to flush? is it the same as the other gens? drain fluid from the bottom, then disconnect the inlet and outlet hoses from the fluid cooler, and i'm lost after that. Anyone care to fill in the rest?
Old Jun 19, 2007 | 01:32 PM
Muyrec's Avatar
Ok just did it. Didn't flush though. 3 3/4 quarts came out. Refill with same quantity. Measured again. Same measurement as before the change. Filled some more till i got to 5 quarts. Just at the tip of the 'OK' mark. The fluid that was inside was a little bit brownish but didn't smelled bad. I think the little amount that was inside caused that. Now i got pink color and no shift shock! Drives like new.
Old Jun 19, 2007 | 02:50 PM
Albert's Avatar
Where is the cheapest place to get k matic ATF?
Old Jun 19, 2007 | 03:10 PM
Muyrec's Avatar
I Couldn't find it anywhere. Had to go to the dealership. 9.95 a quart
Old Jun 19, 2007 | 05:26 PM
!PrjctMax!'s Avatar
Alright ummm...where was the "drain plug?" I've looked on the trans and I couldn't see any sort of plug...so please let me know where that is so that I could do it myself!
Old Jun 19, 2007 | 06:38 PM
Muyrec's Avatar
It's in the bottom front. It's that big bolt right on the middle next to the cable.
and another one
and you're gonna need a 10mm allen wrench.
Old Jun 19, 2007 | 07:48 PM
!PrjctMax!'s Avatar
!!! NICE NICE, THANKS!
So did you actually feel a difference in shifting or do you "think" there is a difference? How long did you run the car before you drained it? Did you drop the pan and clean the filters or just the drain and fill?
dan
Old Jun 19, 2007 | 09:09 PM
RHMax's Avatar
Newbie just Registered
If you only drain and refill, it could take up to 5 quarts; but it would take 14-15 quarts to fill if you do a full flush.
Old Jun 19, 2007 | 09:18 PM
Muyrec's Avatar
dan
I don't feel that much of a bump now. Barely feel it now. car was off the whole night/day when i drained it. There's no pan on mines. Just a simple drain and refill.
Old Jun 19, 2007 | 10:20 PM
MaxFan's Avatar
I did it twice and only 3 quarts came out each time (engine warm after 10 minute drive). that's the amount a few of people here got. I checked the stick and the level is fine. The shift shock is still there, nothing change..well except it gets worse, I feel like the trans get jumpier.
Old Jun 19, 2007 | 10:36 PM
RHMax's Avatar
I had my car on a lift, and drained almost 5 quarts. If you had it on a jack, less fluid would come out.
Old Jun 20, 2007 | 01:57 PM
Albert's Avatar
Do you need to open up both drain plugs or either one is good enough?
Old Jun 20, 2007 | 04:17 PM
Muyrec's Avatar
There's only one.
Old Jun 20, 2007 | 04:40 PM
!PrjctMax!'s Avatar
I plan on doing this right after cruising for a good hour or so...just so that the fluid is REALLY warm and thin, so that more can come out
Anyone think that this is a bad idea to only do a drain and fill?.........
Old Jun 20, 2007 | 05:15 PM
RHMax's Avatar
I think it's a better idea than a full flush. You can get more fliud out if the either level the car or raise the back a little. Check the fluid level before hand to see if you need to put more fliud than you drained.
doctorpullit
Mar 29, 2016 11:08 AM
Need help
23
Oct 2, 2015 08:56 AM
Pied
Sep 26, 2015 03:29 PM
