Right amount of Oil
Right amount of Oil
Hey guys I have a 2007 SL and I have heard a lot of different things about oil issues so what is the amount you put in your engine. I know to check but what would be a reasonable amount to put in to stay out of trouble.
Manual says 4.2 L but what would you say??
German cars usually take 50% more oil, so there would not be an oil starvation.That's Y he recommended me to put extra 1/2-1qt. I put 5qts in there.
Mine takes about 4.5qts to the top level, but my mechanic says, that most japanese car makers save on oil, that's Y most jap cars don't take a lot.
![Tard](https://maxima.org/forums/images/smilies/tard.gif)
Nismology, my 07 manual calls for 4.5 q.
ah 4.5 qt if you change your filter
4.25 qt if you don't change your filter.
lol, yes, it says 4.2l if you change your filter
4.0l if you don't change your filter.
What a hoot!
What a hoot!
You're right. I just checked and it seems the 07 FWD VQ's have a different upper oil pan part number. This probably accounts for the increase in oil capacity.
4 1/2 quarts w/ filter change
4 1/4 quarts w/ no filter change
The 4 1/4 quart capacity applies to 95-06 FWD VQ's then.
I've worked on engines and 4.5 quarts with a filter is what the 6th Gen calls for but if you add an extra half to make it an even 5 your not gonna cause any damage, when the engine is running the pickup is sucking the oil out of the pan and spraying the engine, thats the only time all the oil is in the pan after that maybe half is in the pan.
![Wink](https://maxima.org/forums/images/smilies/wink.gif)
I stand corrected.
Please. Oil capacity is trivial compared what I know about the VQ, inside and out. I don't have a 6th gen, so I tend not to spend as much time thumbing through the 04-07 FSM's.
Post # 15 above in this thread (Nismology post) mentioned a VERY important point. If the level of the oil reaches the bottom of moving parts, a churning or aeration effect takes place, and the oil becomes filled with tiny bubbles, and can no longer be mechanically sprayed by the oil injectors onto critical engine parts. Engines have been destroyed by this aeration/churning caused by overfilling.
At NO TIME and under NO CONDITIONS should the oil level be allowed to get more than very slightly higher than the 'full' mark on the dipstick.
It is OK to run the engine below the full mark, but you should not run it below the low mark. Also, "light" above is correct with his advice.
I should also have included in my post above what SilverMax_04 said about rechecking the oil after the engine has been run. The initial reading after installing the oil will change as the engine is run, the filter fills up and oil is moving throughout the engine. The reading can also change slightly again overnight as the oil drains off engine parts into the crankcase.
Since he won't have the car to recheck, and in an apparent effort to allow for all this, my dealer always leaves a little 'cushion'; after he changes my oil, the level eventually settles to a point about 3/4s of the way from 'add' to 'full', which, since my car uses almost no oil, works great.
Not that it matters but I noticed that Nissan and Toyota always add the extra half quart on the oil change, my V8 4Runner (6.5) they put in 7, my fathers ES300 (5.5) they put in 6, and now my fathers ES350 (6.4) they put 7
BMWs, BTW use regular Castrol Synthetic oil, nothing special as was mentioned before, I had a BMW with a 4.4 V8 which took about 8qts and a 3.0 which took 6.5. Our engines are 3.5L and take only 4.5qts, which might be enough, but it's right on the border. If You have a ECU upgrade with redline moved to 7100, You do need more oil in there since the oil pump, than suck oil from oil pan is mechanically driven by the engine and depends on the rpms, and if You floor it to the 7100 redline the pump migh grab some air instead of oil...............
Also, higher revs doesn't necessarily mean you need to add more oil. How many VQ's that rev past that stock redline have had trouble due to insufficient oil? The greater the volume of oil pumped into the engine the greater the amount that returns to the sump. It's not like oil disappears at higher engine speeds.
litch
123
01-04-2024 07:01 PM
06-06-2017 02:01 PM
Unclejunebug
04-02-2016 05:42 AM
