Replacing break pads
Old Sep 28, 2007 | 05:55 PM
tinuc's Avatar
Anyone know of a good "how to" guide for replacing front and rear break pads?
I know it seems easy but I'm a computer geek not a car mechanic but I've heard breaks are about the easiest thing to replace in a car, as long as you are tool savvy... which I am.
Old Sep 28, 2007 | 06:27 PM
Killah Kane's Avatar
you know, I actually would like to know the correct steps on doing this as well. By the way, its BRAKE pads lol
Old Sep 28, 2007 | 06:44 PM
Hilbe's Avatar
Here is how I did it...sorry if my lingo isn't exactly right...
1. Jack the wheel up.
2. Take the wheel off.
3. There should be 3 bolts behind each rotor / caliper. 2 bolts are the same size, and 1 bolt is much larger than the other 2. Remove the top of the smaller 2 bolts, loosen the bottom of the smaller 2 bolts.
4. Using the loose bolt as a hinge, pull part of the caliper holding the brake pads downward.
5. There are 2 brake pads, one on the front and rear of each rotor. They should just slide out. Slide out the old ones, and slide the new ones in.
6. You now need to put the caliper back together. The piston will need to be compressed. Use a C clamp to push the piston back in so the caliper can be reassembled.
7. Bolt the caliper back together and reattach the wheel. Move on to the next wheel.
Old Oct 1, 2007 | 06:15 PM
smackaslide's Avatar
BINGO!!!
Old Oct 1, 2007 | 06:54 PM
DeusExMaxima's Avatar
Course if you have 300zx tt brakes, you take the top retainer out, remove brake pads, squeeze pistons in, install new pads, done. 2 minutes. Woohooo!!!
Old Oct 1, 2007 | 06:56 PM
NmexMAX's Avatar
dot dot dot ...
Try not to break anything while changing your brakes.
Old Oct 2, 2007 | 03:06 AM
Hilbe's Avatar
I should note that if the brake line doesn't have enough slack to rotate the caliper downwards, do it in reverse (take out the bottom bolt and rotate the caliper upwards).
mvm062
Nov 30, 2020 09:00 AM
rbuswell
Nov 17, 2016 04:54 AM
A32goldylocks
Sep 2, 2015 06:39 AM
Cant_Get_Ryte
Aug 28, 2015 06:41 AM
Jeffesernia11
Aug 23, 2015 06:09 PM
