Air filter almost got wet....
Old Oct 19, 2007 | 04:37 PM
jimmypronet's Avatar
wow! after washing my car i went cheack the CAI filter cuzz it was my first intake installed and i wanted to make sure it doesnt get wet.... and what i see it thers a lot of drop water on it so i took it out and wipe it.... is ther any way i can put a shield on it cuz im scared water might got in to it or are those hydroshield on injenonline.com will work http://injenonline.com/cgi-bin/Merch...tegory_Code=PF need advise plz..... Thnx
Old Oct 19, 2007 | 04:46 PM
xoomer.com's Avatar
I Donate! Why Don't You?
buy it and report on how it worked for you.
Old Oct 19, 2007 | 11:41 PM
!PrjctMax!'s Avatar
I think that was already discussed before.
My opinion is that if that "condom" gets wet, then it will act as a wet sponge that holds the water and just waits for the intake to suck it in. And it also acts as a slight barrier for performance gains, since it's holding back the air a little bit
Old Oct 20, 2007 | 12:02 AM
NismoMax80's Avatar
SuPeRmOd
u pretty much have to be submerged and revving hard to worry about damage. more likely normal intakes get some moisture sucked in from grille during rain than a CAI.
just avoid lakes.
Old Oct 20, 2007 | 05:34 AM
!PrjctMax!'s Avatar
just avoid lakes.
and I think for the thread
Old Oct 20, 2007 | 06:38 AM
xoomer.com's Avatar
Unless you get the "rough rider" then you don't have to worry about performance. I'll personally leave it "bare"
Old Oct 20, 2007 | 08:11 AM
ramberg's Avatar
GrandPa
I have had my injen on for a long time went thru car washes and heavy rain and have had no problems. I think that the shield will block air from going into the filter.
Old Oct 20, 2007 | 08:23 AM
chernmax's Avatar
Nations 1st 6th Gen Turbo
Same like my bro Warren, Had an Injen for over 3 years and now Fujita, still zero issues...
Just don't drive your car like a Submarine Commander and you'll be fine...
Old Oct 20, 2007 | 11:09 AM
AnDyMaN's Avatar
submerge is probably the only way, or close. if you're slammed and have a cai, you might have to worry in the event that you accidently run through a puddle that is deeper than you thought. happened to a buddy of mine and his idle went crazy. a wai or short ram should have no problem ever as far as hydrolock.
it is okay for water to enter your engine, it just can't be an enormous amount at any given time. to clean throttle body's on 01 and older, you have to spray inside the throttle to clean it without damaging a thing.
my03maxima
Jul 28, 2024 07:40 AM
tarun900
19
Dec 20, 2021 06:57 PM
Miket2006
Mar 1, 2021 03:55 AM
Justin Kroll
Oct 1, 2015 07:03 PM
