operating auto lights
Old Oct 22, 2007 | 03:51 PM
smackaslide's Avatar
Hello everyone, I'm finally able to post threads and wanted to introduce myself to the forum. I've been reading through the threads for 3 months now and am now a proud owner of a beautiful smoked gray 05 max se fully loaded wit every option but the navigation. I had a few questions I hope someone out there would be able to answer for me.......
1. How long does it usually take for the lights to turn off when in auto mode? (i.e., entering a tunnel and exiting? they dont seem to turn off by themselves)
2. Im confused on the sensitivity of the auto lights cutting on by themselves.
I set it to the least sensitivity, which is 1, but they seem to still cut on a little early,
or is level 1 the most sensitive level and level 4 the least sensitive???
Thanks in advance.....I'll post some pics up soon
Old Oct 22, 2007 | 04:21 PM
4MySwee's Avatar
Welcome Smackaslide! Let me see if I can help you out a bit.
1. Mine also seem to vary times for shut off when in the auto mode. If you go into settings, and scroll through your choices, you should come across 'Auto on/off' options. It allows you to set your time. I believe the increments are 30-40-60 seconds after car is off.
2. Im a little confused by your question, it could very well be because I haven't had coffee lately!
Check out www.6thgenmaxima.org also. Great group of people over there also. Many of us frequent both sites.
Swee
Old Oct 22, 2007 | 05:25 PM
RHMax's Avatar
Newbie just Registered
Hello, too.
1. Like Swee suggested, turn the car to on, but don't start and you can get to that menu.
2. #1 is the least sensitive setting for auto headlights.
Old Oct 22, 2007 | 09:19 PM
myer84's Avatar
Welcome
Old Oct 22, 2007 | 09:25 PM
chernmax's Avatar
Nations 1st 6th Gen Turbo
Welcome to the Org bro...
Old Oct 22, 2007 | 09:36 PM
Majestic_MAx05's Avatar
WELCOME!!!!
Old Oct 23, 2007 | 05:18 AM
ramberg's Avatar
GrandPa
Welcome to the org. Pictures of the car please.
Old Oct 23, 2007 | 06:41 AM
BigPete's Avatar
Incognito
Old Oct 23, 2007 | 07:28 AM
xoomer.com's Avatar
I Donate! Why Don't You?
Wilcommen.
Old Oct 23, 2007 | 09:24 AM
MaxMaybe's Avatar
Good thing you didn't start your message title with "Please" because I would certainly suspect you were looking for some "sympathy" (hopefully not so obscure R&R reference).
Old Oct 23, 2007 | 12:18 PM
philoforlife's Avatar
You can also set the lights to go off immediately (upon closing the door). These are how mine are set.
Joshua
Old Oct 23, 2007 | 12:34 PM
xoomer.com's Avatar
Joshua
when its on auto or when you forget to switch it off. are you talking about inerior lights or head lights?
Old Oct 24, 2007 | 01:35 AM
kamski's Avatar
.org extraordinaire
Originally Posted by xoomer.com
Wilcommen.
szkop jebany!!
Old Oct 24, 2007 | 01:48 AM
Muyrec's Avatar
he's talking about the headlights. When it's on auto, turn that setting to off and they turn off when you close the door.
Old Oct 24, 2007 | 06:17 AM
xoomer.com's Avatar
Originally Posted by kamilkluczewski
szkop jebany!!
ja ja
Old Oct 24, 2007 | 07:24 AM
Mack's Avatar
Welcome bro. And grats on your great choice of car. Mine is an '06 with the exact same options. Loaded w/out Nav.
Old Oct 24, 2007 | 11:18 AM
NismoMax80's Avatar
SuPeRmOd
Originally Posted by smackaslide
1. How long does usually take for the lights to turn off when in auto mode? (i.e., enering a tunnel and exiting? they dont seem to turn off by themselves)
I set it to the least sensitivity, which is 1, but they seem to still cut on a little early, or is it supposed be set to for if i want them to cut on as late as possible?
how to operate headlights:
http://forums.maxima.org/showpost.ph...0&postcount=67
1. they will turn off according to the sensitivity level.
2. found in the sticky http://forums.maxima.org/showthread.php?t=311430
Old Oct 24, 2007 | 01:58 PM
jsmithsole's Avatar
*moderator*
Welcome aboard! I didn't even know about the door closing deal!!!
Old Oct 24, 2007 | 05:08 PM
bb700092's Avatar
In the sticky as well as the links, everyone is talking about a "settings" button. I could not find any such button in my 07 max which does not have navi. Is that button present only in cars with navi?
Old Oct 24, 2007 | 05:28 PM
NismoMax80's Avatar
SuPeRmOd
i dont have nav. i use the "joystick". there should be a button right next to it.
ur salesman didnt show it to u? it was the only thing he did for me, realizing i knew everything else about the car (teaching him some of the finer points) thanks to the org.
Old Oct 25, 2007 | 07:28 AM
bb700092's Avatar
My salesman was a moron in the true sense of the term. He reported the wrong extended warranty and price to Nissan after I purchased the car and I had to run around like crazy to fix that. I don't think he even knows the word "setting", forget about its button.
Anyway, I will check right now.
I did check but didn't find any. I am assuming you are talking about the joystick that is used to control the side mirror positions and is located on the left and bottom of the dashboard. One side of the joystick are the buttons for VDC, side mirror retracting, and rear sonar. On the other side is the instrument brightness control.
There is another joystick just below the navigation screen in the middle of the dash. This joystick is present only if navi is installed. I do not have that since I don't have navi. Beside this joystick is a "setting" button which I don't have either. Maybe you are talking about it. I am surprised how you can have it without the navi.
What is the function of your joystick and where is it located?
Old Oct 25, 2007 | 07:47 AM
ecks's Avatar
I piss on Civics.
hi! this is maxima.org! prepare the bashing sticks chern.
Old Oct 25, 2007 | 07:49 AM
Mack's Avatar
I don't think '07's have the joystick. I think it's more like the dial that is in the Infiniti M series.
Old Oct 25, 2007 | 08:10 AM
bb700092's Avatar
I could not find out any way to access the settings in a 07 maxima. I went through the manual but it does not say anything for cars without navi. It however does say how to work out the settings for cars with navi. From this, I am assuming there is no way to access the settings in a 07 maxima without navi.
But that is so weird, especially because the 04-06 maximas seem to have it
Old Oct 25, 2007 | 08:28 AM
VigilanteMax's Avatar
Just so Im on the same page...least sensitive means that it comes on quicker, ie when its starting to get dark or does that mean that it has to be dark like 2AM?
Old Oct 25, 2007 | 10:28 AM
NismoMax80's Avatar
SuPeRmOd
I didn't realize you had the 07. you have a completely different layout. check with your dealer, or some other 07 owner chime in.
Old Oct 25, 2007 | 10:40 AM
NismoMax80's Avatar
SuPeRmOd
looking at the 07 manual, non-nav owners got jipped. you probably have to get the dealer to make changes. I would have them show me and report back here.
Old Oct 25, 2007 | 05:03 PM
Gilmo's Avatar
Welcome. Mine is the complete opposite. It's a Smoke BUT "unloaded"
Only option installed is the Bose
Still flies though ... a 528i took me on... I lost, but didn't know I was racing
Old Oct 30, 2007 | 03:52 PM
Thanks to all for welcoming me and trying to help me out.
I'm not having problems with setting the headlamps to off through the settings, i was confused on the sensitivity level of the lights when they cut on. I basically want them to come on as late as possible
And im still trying to figure out how to post pics up, i will post soon
Old Oct 30, 2007 | 03:53 PM
I think least sensitive means it wont come on as quick
Old Oct 30, 2007 | 04:35 PM
redls1's Avatar
MAXIN' ON
I just covered my sensors on the dash and keep all my lights on all the time.
Old Oct 30, 2007 | 06:05 PM
xoomer.com's Avatar
not too smart, i read somewhere that these are also used when you have your ac running on auto. Sunny weather will make your ac run stronger to accommodate for higher temp.
Old Oct 30, 2007 | 06:35 PM
redls1's Avatar
MAXIN' ON
hmm will have to look into that.
Old Nov 1, 2007 | 07:40 AM
thecritik's Avatar
As to the question of how long they take to turn off after auto turn on (tunnels and such). I was under the impression since they warn that turning the lights on and off too quickly could damage the bulbs and reduce the life of the HID's, the car waited longer before turning them off in the auto setting. Only thing I could think of. Now before I go into a tunnel or an underpass it's second nature to quickly look at the switch and make sure it's set to off instead of auto.
Old May 27, 2008 | 02:56 AM
nancyliu
I R dumb
Old May 27, 2008 | 03:06 AM
nancyliu
silly spammers
Old May 27, 2008 | 03:48 AM
lowpro19s's Avatar
nancy..umm wrong section..old thread.
Old May 27, 2008 | 03:50 AM
CanadianMoFo's Avatar
Originally Posted by nancyliu
Obviously a spammer. Just joined and posed the exact same message a few times. I smell a ban in her future.
CM
Old May 27, 2008 | 04:25 AM
Kryogen's Avatar
Personally I switch them to on manually... The auto setting was not lighting them when I wanted it to, plus it always turned them on in my garage when leaving home or arriving, just for a few seconds. Also when in traffic under a tree or something...
And then, I want to show off my quad xenon setup so I sometimes turn them on during the day, too.
Old May 27, 2008 | 05:14 AM
lowpro19s's Avatar
CM
If she/he is a spammer then i agree what **** said.. choose your scent Nancy!!
mvm062
Nov 30, 2020 09:00 AM
Maxima30
Sep 7, 2015 06:13 PM
MidnightMaxima_22
Sep 6, 2015 01:18 PM
dcardello
Sep 3, 2015 11:44 PM
