Installed RotorPros, need a lil help!
Old Nov 5, 2007 | 02:47 PM
whitem1ke88's Avatar
All rotors are on, look and perform great.. but.. there's a scratching noise coming from the rears. I can't tell if it's the metal plate in back (i didnt bang it up or bend it at all to my knowledge) or if it's the actual brake pads (I didn't replace them) but it's definitely annoying.. any thoughts on this ?
Old Nov 5, 2007 | 03:50 PM
NIKV69's Avatar
I got a similiar noise in my rears after I did a 4 wheel brake job (drilled and slotted rotors and pads)about a month ago but it went away in a couple of days. I adivse you to wait a little and if it doesn't go away pull the wheel and inspect.
Old Nov 5, 2007 | 04:33 PM
orlan85's Avatar
Newbie
When i changed the rotors on my old car i was told that it is best to change the brake pads becuase they already "formed" to the old rotor. So when you put new rotors on it takes a while for the actual brake pad to even back out with the new "flat" rotor. Just what i was told by a mechanic in the family.
Old Nov 5, 2007 | 07:05 PM
Sounds good guys. I suppose i'll wait about a week, if it doesn't stop i'll have to inspect. I really suspect the metal plate behind the rotor for this noise but we'll see..
Thanks for the help.
Old Nov 5, 2007 | 07:13 PM
NIKV69's Avatar
I thought the same thing but it went away so give it a few days.
Old Nov 5, 2007 | 07:26 PM
Mack's Avatar
I would've recommended new pads with the new rotors. And definitely get ceramic pads for better braking and less brake dust.
Old Nov 5, 2007 | 08:41 PM
I VIK I's Avatar
I don't know if you guys are familiar with this but when you get new rotors or pads there is a break in procedure, do that it may make the difference...
http://www.zeckhausen.com/bedding_in_brakes.htm
Old Nov 6, 2007 | 06:36 AM
xoomer.com's Avatar
I Donate! Why Don't You?
Dude you always change pads when you change rotors.
Old Nov 6, 2007 | 07:23 AM
Hilbe's Avatar
I don't know. If something is not seated right, you can warp/ruin your rotors. I ruined one of mine because the brake pad somehow got in crooked. The longer the rotor is exposed to a problem like that, the higher chance you are going to have to ruining it. I'd seriously consider reseating all the pad on that rotor just to make sure its all in there correctly.
Old Nov 6, 2007 | 07:30 AM
!PrjctMax!'s Avatar
I had a noise the first couple of days that I had my new pads and rotors, but after some highway driving and breaking them in properly, it STFUed!
Old Nov 6, 2007 | 11:28 AM
GrimMax's Avatar
Where is my shirt?
Yeah brother get some pads. I just got those also and bought the hawk pads. Break em in for sure though or you wont be stopping in time.
Whats up with some pics???
Old Nov 6, 2007 | 12:19 PM
VigilanteMax's Avatar
ceramics not needed for daily driver. get the extended life semi metalic as they are also easier on the rotor life.
Old Nov 6, 2007 | 12:38 PM
Mack's Avatar
Yes, ceramics ARE needed for daily driver. In fact moreso.
Old Nov 6, 2007 | 02:14 PM
madmik's Avatar
I tried semi-metallic but went back to ceramic. OEM is ceramic. I always get new pads with new rotors.
After each rear rotor was back on, did you rotate them? Did you adjust the parking brake too tight or rust get trapped in the inner drum?
Break-in is called 'burnishing' in the shop manual.
Old Nov 6, 2007 | 05:00 PM
Mack's Avatar
OEM are NOT ceramic.
Old Nov 6, 2007 | 05:38 PM
OK guys i'm buying new pads, what do you all recommend? I typically drive my car daily and usually not too hard but occasionally (night time) I push the RPMS, yea..
Old Nov 6, 2007 | 05:41 PM
larsim's Avatar
Wink. I'll do the rest.
Ceramics: way to go.....
Old Nov 6, 2007 | 05:50 PM
Mack's Avatar
I have Posi-Quiet ceramic pads but I've heard really good things about HAWK Ceramic pads. I'll probably go with those next time around.
Old Nov 6, 2007 | 05:54 PM
I have the posiquiets metallic extended wear. Dont mind changing pads to keep the rotors lasting longer. Rotorpros guy recommended these and I have been happy thus far. Ypu are going to get dust no matter what pad you get.
Old Nov 6, 2007 | 05:57 PM
larsim's Avatar
Hmm, not sure if it is just me but with ceramics i don't get any dust....
Old Nov 6, 2007 | 05:58 PM
Mack's Avatar
True but man, I have I'd say 70% less brake dust than with my stock pad. And it's not that super nasty BLACK dust as it was with stock as well. Ceramics are one of those upgrades that's worth it IMHO if you like to take good care of your ride.
Old Nov 6, 2007 | 06:05 PM
redls1's Avatar
MAXIN' ON
Never knew I was supposed to change the pads with new rotors. I changed both front and rear rotors and still have factory pads.
Old Nov 6, 2007 | 06:07 PM
Zero dust huh? Interesting...quite a pad you got there. Does it ever wear down, and if so where is it going? It may not stick to your wheels, which is great. I get mild dust on my nismos, but they are smoked wheels
Old Nov 6, 2007 | 06:10 PM
larsim's Avatar
Well.... not too sure if it REAAAAALLLY doesn't dust.... At least I don't see any dust....
Old Nov 6, 2007 | 06:14 PM
larsim's Avatar
Old Nov 6, 2007 | 06:15 PM
BlackSpeed's Avatar
I put AutoZone ceraminc pads on my wifes Benz and they have 75% less dust and out performs the OEM Mercedes Pads. Once I change my rotors next month on the Max, it's ceramics for me all the way round..
Old Nov 6, 2007 | 06:20 PM
BlackSpeed's Avatar
I think I will go with the Hawk ceramics this go round..
Old Nov 6, 2007 | 06:23 PM
I hate it when the wife gets the benz. Im sure the autozone pads were 75% cheaper as well. Glad you like them. Not trying to be sarcastic
Old Nov 6, 2007 | 08:43 PM
GrimMax's Avatar
Where is my shirt?
The hawks are great. I got them on now and they are great. Take some pics!!
Old Nov 7, 2007 | 11:13 AM
madmik's Avatar
So all the brake manufacturers are wrong! Sorry if I misled anyone.
RAYBESTOS Part # SGD905C {Service Grade; Ceramic}
Rear; OE Ceramic; Recommended Replacement
RAYBESTOS Part # PGD969C {Professional Grade; Ceramic; 2.600" X 5.340"}
Front; OE Ceramic; Recommended Replacement
RAYBESTOS Part # PGD905C {Professional Grade; Ceramic; 1.490" X 4.150"}
MONROE Part # CX905 {Premium Ceramic Pads (
Rear; Original Equipment Replacement Recommendation.
RAYBESTOS Part # ATD905C {Advanced Technology; Ceramic}
AKEBONO Part # ACT905 {OE Ceramic}
Rear - ProACT Ultra Premium Ceramic Pad
AKEBONO Part # ACT969 {OE Ceramic}
Front - ProACT Ultra Premium Ceramic Pad
RAYBESTOS Part # ATD969C {Advanced Technology; Ceramic; 2.600" X 5.340"} Front; OE Ceramic; Recommended Replacement
ACDELCO Part # 17D969C {#19108027}
PAD KIT,FRT DISC BRK DURASTOP CERAMIC; FOR DURASTOP, CERAMIC RECOMMENDED DUE TO ORIG EQUIP BRAKE PARAMETERS
ACDELCO Part # 17D905C {#19108016}
PAD KIT,RR DISC BRK DURASTOP CERAMIC; FOR DURASTOP, CERAMIC RECOMMENDED DUE TO ORIG EQUIP BRAKE PARAMETERS
Old Nov 7, 2007 | 11:48 AM
Mack's Avatar
These are not standard equipment. You've posted replacement pads. Show me any Nissan off the lot that comes standard with ceramic brake pads. Here I'll save you the trouble, they do not. You've posted aftermarket parts. "CERAMIC RECOMMENDED DUE TO ORIG EQUIP BRAKE PARAMETERS " I'd recommend ceramics if I were in brake sales too as they are a buttload more expensive! LOL.
MaxLife17
Jun 27, 2019 01:37 PM
Excalibur23
Oct 13, 2015 04:33 PM
2kmaximel
Sep 16, 2015 03:19 PM
Johnny9595
Sep 3, 2015 05:18 AM
