Microphone with Blue Tooth
Old Nov 14, 2007 | 05:55 PM
Jopa416's Avatar
When I talk on the cell phone via Blue Tooth most people tell me that I sound far away, do others hear this complaint meaning that the mic just sucks -or- does my microphone need replaced.
Old Nov 14, 2007 | 05:57 PM
!PrjctMax!'s Avatar
Not sure if it's the one that came from the dealership, but if it is then take it to them and warranty that shiznit!
Old Nov 14, 2007 | 06:02 PM
Jopa416's Avatar
Oh yes, it is the built in microphone. I was going to take it the dealer, but if they all suck and that is just the way it is, I don't want to waste my time getting it replaced.
Thanks for the reply.
Old Nov 14, 2007 | 07:21 PM
tehaviator's Avatar
Do you yell or talk louder while on the phone? I used to when I first got it, and my callers complained that my voice sounded muffled. I tried speaking normally, and there were no problems after that.
Old Nov 14, 2007 | 07:39 PM
Mack's Avatar
I get the same complaints bro. I think it's just a crappy unit.
Old Nov 15, 2007 | 09:45 AM
VeeMax07's Avatar
I have the same problem. I think all the mics are like that though. Since I'm trying to have a normal conversation.... the caller keeps saying WHAT? WHAT? I CAN'T HEAR YOU. I end up yelling or screaming back. So, I'm figuring its just the mic.
Old Nov 15, 2007 | 10:01 AM
Mack's Avatar
I wonder if the mic could be replaced with a higher quality unit? That would be a sweet mod.
Old Nov 15, 2007 | 10:04 AM
VeeMax07's Avatar
YEAH! If anyone figures that out.. PLEASE let me know. I'm tired of screaming.
Old Nov 15, 2007 | 02:24 PM
jc53's Avatar
no problems with mine.
Old Nov 15, 2007 | 06:53 PM
nss's Avatar
nss
The problem is the mike should be located on the sunvisor, now it is too far away from your face. I am in process of removing the mike/lamp assembly, and see if I can extend the mike wires (by splicing) to attach it to the sun visor. The sun visor would have to be in the down position.
Old Nov 17, 2007 | 07:31 PM
wolf2989's Avatar
Let me start with i have an '04 SE
I was taking apart my reading lamps the other day and noticed the little slit in between the reading lamps. First thoughts were "WTF is that for" and then remembered when i moved my display screen down in front of the shifter i noticed the phone icon on the screen and all the other supported bluetooth phone information.
So long story short, is the hardware all complete in 04's for the BT setup? Everything appears to be in place, just no way to use it (no steering wheel button).
Old Nov 18, 2007 | 03:21 AM
ramberg's Avatar
GrandPa
I don't have this in my '04 but I agree with nss that it should have been installed in the visor. This way your voice wou;d go directly into the mike. This could have been done without pulling down the visor. I use a bluetooth ear piece when driving and have had no problem with it. If I was you I would go to the dealer and complain.
Old Nov 18, 2007 | 05:15 PM
SHIFT_matt's Avatar
Yeah, I have an '06 with Bluetooth also. The system itself is decent, but I get comments about sounding far away, too. I found that if you look forward while driving and speaking clearly it evens out. My wife stopped using it for a while bc she felt like nobody could hear her. I pointed out that she was speaking at the speaker, not the mic (wives...ha!).
Granted, it's probably not the best mic, but it's better than trying to hold a phone to your ear or buying a gaymo Spock headset. Like tehaviator said, if you speak normally it works fine.
Old Mar 14, 2008 | 11:46 AM
nss's Avatar
nss
2007 SL Bluetooth Microphone
Finally got around to moving the microphone to the sun visor. WHAT A DIFFERENCE IN SOUND QUALITY! The steps were:
1) The mike is located underneath the roof switch cover. Open the sunglassholder, remove the screw, the cover drops down, only to be held by 4 plastic push pins. You will have to pull slowly but strongly each corner, to remove the plate. Two of my pins broke, the nissan dealer just gave me two others, however, as you will see later, never used them again.
2) The mike slides out of a plastic holder, and is attached by 3" cable to a connector, which is easily pulled off from the matching connector. Before continuing, I found the microphone/cable is Nissan Part#28336ET000, $50 in Canada, just in case I screwed up. Note the mike is hard wired to a small 1/2" square circuit board, probably the noise filter.
3) I cut the cable in half, and spliced/soldered about 1ft of bell 4 wire cable, you need 3 of the wires.
4) The mike is held in a plastic box, One side easily comes off to make it less bulky.
5) Then, reattached the mike connector to the connector in the switch box, replaced the switch cover with ONLY the screw, the wire is squeezed just a little between the switch cover and the roof liner, no problem. Later, I may make a cutout. I have a sunvisor paper holder, etc, which attaches to the visor with velcro wrap around straps. I ran the cable under the straps, attached the wire with wire wraps. The mike is positioned on the left side of the visor. I do have to bring down the visor for maximum performance, but WOW, what a difference. Next week I will try to post some pics.
Old Mar 14, 2008 | 03:36 PM
BennyButch's Avatar
i don't get that but people say I cut out and I just started to turn down the volume. So it would not cut in and out.
tarun900
19
Dec 20, 2021 06:57 PM
MaxLvr21
Oct 17, 2015 12:11 PM
Stagnet04
Oct 11, 2015 08:16 PM
BobTX10
Oct 7, 2015 08:43 AM
