High pressure wash made my car turn off...
Old Dec 1, 2007 | 09:13 PM
!PrjctMax!'s Avatar
...a couple of days ago I was coming home from school, and a semi-truck sitting next to me at a stop light had diesel leaking/spraying everywhere from under his motor, which my entire right side got sprayed with
K, so I didn't have time to actually hand wash my car at work, so I took it to a Jewel "high-pressure"/touch-less wash. The thing shoots hard as a **** and I had my car turned on the whole time, until the car just shut off by itself I was like and just laughed and turned it back on.
When I got out, I opened the hood and a good amount of the bay was "wet," and the radiator was smoking noticeably. I am going to assume that the Fujita sucked it some water and it stalled?
Either way...is this something I should worry about, or is it all good now? I drove the car for about 30ish miles, and had no problems...knock on wood
Old Dec 1, 2007 | 11:19 PM
Fastmax05's Avatar
"Ok,Whats next?!?!"
you should be good... how did the fujita suck it up... ??? only way that could happen is in you were at WOT ... hmmm
all in all u should be fine... keep us posted...
Old Dec 1, 2007 | 11:26 PM
DrunkieTheBear's Avatar
Turbo'd Saab
If you really are worried about it alot, change the oil and see if the oil has water in it and then flush a quart of oil through and then all should be fine.
Old Dec 1, 2007 | 11:59 PM
S_Klass's Avatar
The Fujita would have to be immersed to draw water.
Old Dec 2, 2007 | 12:39 AM
Fastmax05's Avatar
"Ok,Whats next?!?!"
+1....
Old Dec 2, 2007 | 05:50 AM
4MySwee's Avatar
Perhaps an electrical wire was 'hit'. It may have shorted out or gotten tempermental until it dried.
Old Dec 2, 2007 | 09:02 AM
STARR's Avatar
Cars at idle do not take a lot to stall out, a high pressure wash could have suffocated your car and made it turn off
Old Dec 2, 2007 | 12:36 PM
redmaxpa007's Avatar
i SeE what you did therE
your fine...... that happened once or twice with my GTP
Old Dec 2, 2007 | 01:29 PM
!PrjctMax!'s Avatar
yay
The car has been sitting for the past few days because I got my sisters 99' Civic for the "winter"
Old Dec 2, 2007 | 01:38 PM
OUCH..... might as well walk...
Old Dec 2, 2007 | 04:11 PM
Aaron92SE's Avatar
NWP Engineering.com
That's very likely. I see people pressure washing their engine bays and then the car runs like crap. I usually tell them to let things dry and see if the problem goes away. It usually does.
!PrjctMax!, if the car is running ok now, I wouldn't worry about a thing.
Old Dec 2, 2007 | 08:23 PM
!PrjctMax!'s Avatar
28mph ftw!
Old Dec 2, 2007 | 08:26 PM
Originally Posted by !PrjctMax!
28mph ftw!
mpg? or the civics top speed is 28mph???
Lakersallday24
Jun 16, 2019 01:35 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
acw
Aug 13, 2015 12:50 AM
altome15
Aug 10, 2015 07:05 PM
mrgooch
Aug 9, 2015 11:00 AM
