hot air from under dash????
Old Jan 6, 2008 | 07:43 PM
gtp2k1's Avatar
Has anyone experienced this? It's almost like you have the heater on. With the a/c off and the recirculate button pushed, the warm air is still coming in under the dash/ floorboard areas. Is there some sort of actuator that may be bad? Any suggestions?
thanks, Dean
Old Jan 6, 2008 | 08:34 PM
!PrjctMax!'s Avatar
I would say it's normal...I have the button pressed that lets air come in from outside, and whenever I stomp on it..."warm" air hits my legs.
Old Jan 7, 2008 | 12:02 AM
lightonthehill's Avatar
Even in recirculate mode, the air comes out of the same air ducts, most of which are in/under the dash area. I would say your HVAC system is operating normally.
Old Jan 7, 2008 | 12:50 AM
AscendantMax's Avatar
yep. the air is just being forced in from outside.
Old Jan 7, 2008 | 10:21 AM
gtp2k1's Avatar
hot air under dash
OK then, I'll leave well enough alone. Thats 3 for three.
Thanks, Dean
Old Jan 7, 2008 | 10:25 AM
Lovemycar's Avatar
recirculate mode it shouldn't be pushing air from the out side only in fresh air mode should it be doing that
Old Jan 7, 2008 | 10:44 AM
DonP's Avatar
yeah i think its normal.
Old Jan 7, 2008 | 11:05 AM
My-Body-Is-Ready's Avatar
i have that too its really annoying in the summer time but thats what ac is for.
Old Jan 7, 2008 | 11:47 AM
shawndon's Avatar
Happens to me as well.
Old Jan 7, 2008 | 12:47 PM
!PrjctMax!'s Avatar
OR open sun-roof + 60 degree blowing w/o a/c = profit...literally cause' you spend less money on gas w/o a/c ftw!
Old Jan 9, 2008 | 11:35 PM
too_Da_MAX's Avatar
it will push out the air at the last temp it was left on. If you leave it at around 75 degrees it will push out that temp, when its turned off.
Old Jan 9, 2008 | 11:42 PM
jimmypronet's Avatar
Its normal happens to me too.....
Old Sep 29, 2011 | 04:20 PM
smplyamzng's Avatar
I know this thread is over 3 yrs old but i just started experiencing this issue a few days after fixing my timing chain rattle. Before i had the work done i never even knew this problem existed. It cant be normal because it just started happening and its bearable but uncomfortable to drive. Had a local mechanic do the chain job and im satisfied with the outcome except for this. Wanted to know if anyone else experienced this and what the resolution was before going back to them.
Old Sep 30, 2011 | 07:45 AM
Apollos2's Avatar
LOL I saw this thread way back and it wasn't an issue for me but I have noticed it from time to time like "what the!" where is all heat coming from. If I figure it out, I'll post something up, but for now I just turn on the fan or a/c.
Old Oct 2, 2011 | 05:20 AM
Kryogen's Avatar
Man he ruined the timing of your HVAC big time. Sue him.
Old Oct 2, 2011 | 12:35 PM
MaxPrime's Avatar
Normal same here
jmlee44
Oct 2, 2022 02:13 PM
Miket2006
Mar 1, 2021 03:55 AM
MichMaxFan
Sep 30, 2015 09:18 AM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
