Coolant Smell
Old Jan 27, 2008 | 09:46 AM
eK9aT10pSi's Avatar
Coolant Smell
hey guys, i just got my car fixed after a <a href="http://forums.maxima.org/showthread.php?t=548680">Wreck</a> [t-bone on pass side]. but now when i drive around and have the heat on, it smells like coolant is burning and coming through the vents. i cant figure out what it can be. i was thinking the heater core?
Old Jan 27, 2008 | 10:54 AM
redls1's Avatar
MAXIN' ON
Could be a leak elsewhere also if you have outside air on wouldnt it still come in the vents?
Old Jan 27, 2008 | 11:03 AM
eK9aT10pSi's Avatar
if the outside air was on, id get outside air, not a coolant burning smell id think.
Old Jan 27, 2008 | 07:21 PM
eK9aT10pSi's Avatar
also, ive noticed this while under acceleration as you get to a cruising speed
Old Dec 10, 2008 | 11:05 AM
Finding Nismo's Avatar
Same thing is happening to me. I recently changed my radiator cap so I'm assuming it's now creating more pressure in the system and a leak has formed. Are there any common places that I should start looking at for the leak?
Old Dec 10, 2008 | 03:54 PM
po8pimp's Avatar
get a sniffer and check it while driving, actually have someone else test it while you are driving.
Old Dec 10, 2008 | 06:32 PM
trini_maxima's Avatar
hey i have the same exact prob with mine, i searched but found nothing on coolant smell.....i did se whisps of smoke coming out from behind the throttle body but when i felt the rad hoses the were dry.......i was told by a mechanic if it was the heater core it would be leaking on the inside of the fire wall and smelling constantly.....but thats not the case i smell it off and on and only when the heat is on and (outside air). i did see a little antifreeze on my garage floor in the front drivers side.
Old Dec 19, 2008 | 11:15 AM
JoeyAces07's Avatar
I just had a nasty coolant smell in my car. I was actually changing my oil at the time and i saw coolant on the bottom of my ac compressor.. Come to find out there was no coolant leak.. There was however a broken AC line which has a green dye that looks just like coolant.. I would have your mechanic sniff test/black light test for leaks on your ac.
Miket2006
Mar 1, 2021 03:55 AM
captchaos
Mar 15, 2016 12:18 PM
homewrecker
Sep 24, 2015 07:01 PM
msellas
Sep 23, 2015 09:16 PM
junito1
Sep 23, 2015 12:14 PM
