Halo Group Buy The Install
Old Mar 4, 2008 | 08:18 PM
  #81
2k4MaximaSE's Avatar
Originally Posted by MaXXXpower
Well, you should have gotten 4 halos total. 2 smaller for the top and 2 larger for the bottom.
Each halo has 2 bare white wires coming off them.
You will have also gotten 2 inverters with 2 plugs on each and 2 bare wires (+ and ground)
There are 4 empty black "quick disconnect" plugs you will be attaching to the bare white wires on the each halo.
Hopefully yours came with some epoxy glue, if not go to the hardware store and get some crystal clear 2 part epoxy in the double syringe.
You will need to get some 18 gauge wire. And lengthen each white wire coming off the halos. Splice into the middle of the white wire, you'll want to reuse the end of each white wire to attach to the plugs provided.
I added about 18" to each white wire since I was mounting the inverter outside the headlights.
On the end of each white wire you will see the special metal end, its not just braided wire strands. On one side it will have a little extra piece of metal in the middle this is to line up with the empty notch on the bare plugs provided.
DO NOT ATTEMPT TO SEE HOW THIS GOES TOGETHER UNTIL YOU ARE DONE AND READY TO MOUNT THE PLUGS. If you snap them in, you will not be able to pull the plug apart from the wire. Then you will need a bigass hole in the back of the headlight housing to get those wires out.
There are 3 slots in each of the plugs but only 2 wires. You'll connect the wires to the outside slots and leave the middle open. You'll notice thats how the other plugs are wired from the inverter.
If you have more questions let me know. I don't think I left any thing out though.
Good Luck!
....wow, I'm speechless. Without a doubt, this was way more than I imagined you would hit me off with, but it is GREATLY appreciated. Thank you. I did get the kit with the epoxy glue as well as a ton of their business cards and brochures, lol. Once I have these installed I will "vouch" for their product by passing out their advertisements. Rich (Richard) was without a doubt very useful. Never got to speak to Justin, but never needed to when I had Rich helping me out from the moment I told him about that issue the installer had told me (not to mention refusing to take my order and telling me to hold off on ordering them). I finally have every part I need in order to do my exterior mods. Let the fun begin.
Old Mar 4, 2008 | 09:47 PM
  #82
MaXXXpower's Avatar
name came from hairdryer
Originally Posted by larsim
Man - this thing is growing on me... the only thing that bothers is having to bake my headlights.... what if it melts?! Isn't there another way of "gently" opening it?
Trust me at 225degrees, the only thing that melts is the sealant they use.
Ive used my heat gun at 750degrees on the cover to apply eyelids.
Those covers are strong, they are made to withstand rocks and other flying debris.
Do it Do it Do it Do it Do it
Old Mar 4, 2008 | 09:50 PM
  #83
MaXXXpower's Avatar
No problem 2k4.
I'm here to help.
Old Mar 5, 2008 | 04:33 PM
  #84
wildman04's Avatar
MAXXED OUT Member!
I'm not sure what the sealant is called. But, my suggestion is to purchase a heat gun that you would use to melt the existing sealant and mold the gooey sealant around the housing to get a better seal without any lapses in the sealant.
If you try the wrong kind of sealant it may cause more humidity to form inside while it is drying.
Btw, you will be very happy with these halos.
They are bright as hell during the day, still very noticeable in direct sunlight.
When i took my lights apart, I tried to move the sealant up to the top of the lip while it was still hot hoping that it would reseal. One light is fine but I had to rebake the passenger light a second time due to someone in a post telling us to remove the bags of dessicant before baking and I tore the bag and didn't notice until i got it back together and white particles of dessicant were everywhere inside the light housing. I had extra dessicant bags from another light and put them in when I resealed the light but it must have not sealed good. Light does not fog unless headlights are on and it begins to fog very quick. I wanted to get more sealant to add to the seal when i take them apart to install the halos.
Old Mar 6, 2008 | 09:33 AM
  #85
90max's Avatar
has everyone from the groupdeal recieved their halos?
Old Mar 6, 2008 | 01:37 PM
  #86
philoforlife's Avatar
No.
Old Mar 6, 2008 | 04:11 PM
  #87
too_Da_MAX's Avatar
not yet
Old Mar 6, 2008 | 04:19 PM
  #88
SteadyC's Avatar
newb question
hello all. I have a noobie question for ya. I am extremely interested in making the halos happen in my car. I was wondering if it would be possible to get a heated steering wheel switch and turn that into my halo switch (part # 251937y000). simply because i want to have control but i dont want anything to look like i bought the switch at radio shack (no offense). Also i am slightly inclined to do it myself would it be too much for me to handle? (painting, clearing the orange, and doing the halos). any help is appreciated
Old Mar 6, 2008 | 04:38 PM
  #89
MaXXXpower's Avatar
Read my post in this thread on page 2, post #65
Old Mar 6, 2008 | 10:12 PM
  #90
wildman04's Avatar
MAXXED OUT Member!
If anyone does need extra sealant to reseal the headlights, I have found that it is a hot melt butyl tape or rope. The only problem is that I have yet to find a supplier of the product. I am going to check at a local glass shop and see if they have the sealant or if they can direct me to a supplier.
Old Mar 7, 2008 | 08:11 AM
  #91
muskrat20's Avatar
Just got off the phone with a lady from Advanced Automotive and she said half the group buy was sent out yesterday and the other half was sent out today....
Old Mar 7, 2008 | 08:17 AM
  #92
MissMiami's Avatar
Yeah, I just got an email stating the same thing:
Half of the kits were shipped out yesterday, the other half is going
out today. So you should be receiving your package in the next few days.
Old Mar 10, 2008 | 09:41 AM
  #93
90max's Avatar
i'm hoping everone got their's today ...i just recieved mine!!!
Old Mar 10, 2008 | 02:48 PM
  #94
I received mine today too WHOOOOOOHOOOOOOOOOOOOOOO
Old Mar 10, 2008 | 03:47 PM
  #95
too_Da_MAX's Avatar
yup i definitely got mine today, its gonna have to wait for the weekend tho. Im gonna paint the housings also. Cant wait
Old Mar 13, 2008 | 06:21 PM
  #96
After an entire day of install. That's from 9 this morning till 9 tonight, they are in. Still haven't wired the switch, it took so freakin long to do. You get better as you go along but there are so many parts, just taking the damn thing apart was hard for this newbie.
Pics in the next couple of days.
Joshua
Old Mar 13, 2008 | 07:58 PM
  #97
wildman04's Avatar
MAXXED OUT Member!
I just got my halo's today and will be putting them in this weekend along with the switchbacks. I have already painted the headlights and tinted the sidemarkers prior to this so I hope it doesn't take as long to complete the project. Will post pictures as soon as I can.
Old Mar 15, 2008 | 09:37 AM
  #98
that_dude_ILLA's Avatar
hay, can people still get in on the group buy?
Old Mar 15, 2008 | 01:19 PM
  #99
too_Da_MAX's Avatar
i just tried to take a pic with them on, and its soo bright the pics dont come out right.
Old Mar 15, 2008 | 04:16 PM
  #100
So for anyone who put a switch in the cabin, how the hell did you go through the firewall? Did you put the car up on jacks? Go through the drivers side? I realized at this point how much harder it is...I can't even get under the car to do it, nor do I want to drill into the engine somehow...help!
Joshua
Old Mar 15, 2008 | 04:19 PM
  #101
Take a pic!
Old Mar 15, 2008 | 04:27 PM
  #102
MaXXXpower's Avatar
It wasn't fun.
Temporarily, I followed the driverside fender at the top, and ran 2 18gauge wires out a crack to near the driverside door hinge. Then there's a large rubber grommet for the speaker wire and door lock, and windows and ran them into the inside.
Old Mar 15, 2008 | 05:57 PM
  #103
wildman04's Avatar
MAXXED OUT Member!
Joshua
I removed the inner fender well and ran my wiring along the existing wiring harness that leads into the cabin, when you get to the cabin firewall you will see a large rubber grommett and I poked a hole with a sharp punch and then pushed my wires through the hole with the punch. Grommett will seal tight around the wires and that was it. Worked good for me anyway.
Old Mar 15, 2008 | 06:06 PM
  #104
What exactly is the inner fender well and how did you take it off? I'm guessing its the black plastic on the inside that goes around where the tire is? Is there screws to take it off? Did you have to twist the wheel?
Drove with them on today for the first time, they are awesome.
Joshua
  #105
MaXXXpower's Avatar
Why didn't I think of that. (take the fender off).
About how many bolts are there for the fender?
Old Mar 15, 2008 | 08:11 PM
  #106
wildman04's Avatar
MAXXED OUT Member!
Joshua
You have to remove the front wheel and remove the 4 screws holding the (black plastic) inner fender to the fender lip and there are 3 or 4 of the push in clips to remove, but it makes a very neat installation for the new wiring.
Old Mar 15, 2008 | 08:17 PM
  #107
wildman04's Avatar
MAXXED OUT Member!
I replied right before your post. Just remove the inner fender and you will see where the factory wiring is ran. I didn' get to work on my halo's today(busy trying to get all led's switched inside) but I am hoping to get the halos in tomorrow. Cant wait.
Old Mar 16, 2008 | 07:14 PM
  #108
wildman04's Avatar
MAXXED OUT Member!
I was installing my halo's today and completed the first headlight. Took pictures to post when I was finished with the install. I went outside to install the one headlight and looked down and the lower halo was broke in half. I went back in and looked on my camera at the pictures I had previously took and the halo was not broke. What could have happened. I am very sick now.
This is right before I walked out with headlight.
This is what I saw after I went out.
Old Mar 16, 2008 | 07:25 PM
  #109
MaXXXpower's Avatar
This is right befor I walked out with headlight.
You didn't bend them open did you?
That top pick looks like its alot wider than mine at the bottom.
Old Mar 16, 2008 | 07:30 PM
  #110
wildman04's Avatar
MAXXED OUT Member!
No. I placed the loose bulb up against the light housing and lightly scratched a location to drill the holes and did not pull them wider or push them together at the bottom. It looked great after it was all complete as the first picture shows and I just walked outside, plugged the light into the harness and was screwing the bolts in by hand when I looke down and saw it broken.
Old Mar 16, 2008 | 07:32 PM
  #111
wildman04's Avatar
MAXXED OUT Member!
I did paint the rubber boots at the base of the halos so they would blend to the housing better and that may be why they look wider.
Old Mar 16, 2008 | 07:37 PM
  #112
MaXXXpower's Avatar
That must be what I see.
Can you post larger pics? Maybe 600pixels wide.
Old Mar 16, 2008 | 07:45 PM
  #113
wildman04's Avatar
MAXXED OUT Member!
Check post 108 (my original post). Sorry I copied the wrong link.
Old Mar 16, 2008 | 07:49 PM
  #114
PunjabiJAtt's Avatar
where can i order dez from
Old Mar 16, 2008 | 07:58 PM
  #115
MaXXXpower's Avatar
Not sure what could have happened.
Is the painted part assembled sitting in there correctly. not outta place/twisted.
Old Mar 16, 2008 | 07:59 PM
  #116
MaXXXpower's Avatar
Follow this link for the group buy price $119
http://automotivelightstore.com/inde...ROD&ProdID=162
Old Mar 17, 2008 | 05:26 PM
  #117
too_Da_MAX's Avatar
From looking at those pics, it looks like the holes you drilled for the halo where a bit too far apart. Causing outward stress on the halo. Those halos are fragile.
One question, did you insert the boots of the halo inside the mounting holes or just the wires?
Old Mar 17, 2008 | 07:37 PM
  #118
wildman04's Avatar
MAXXED OUT Member!
I inserted the boots into the mounting holes, but they fit into the holes loosely and then I epoxied the boot and the top edge of the halo to the light housing. I had everything drilled just perfect to match the way the halos came out of the package. I painted the remainder of the boot so it would blend with the light housing and I think that is why it looks wider than some other ones.
Old Mar 19, 2008 | 07:34 PM
  #119
bdiddy619's Avatar
question
so i see you have the halos but do you also have the 8000k hids as well?
Old Mar 19, 2008 | 11:58 PM
  #120
Mightymousehhd4's Avatar
Is there any way to test these lights before putting the in the housing? I would hate to get everything in there and glued and have them not work.
