LED's in Door Handles
Old 06-29-2008, 06:38 PM
  #81
Ankit69's Avatar
its dark....... where the pics at
Ankit69 is offline
Old 06-29-2008, 07:19 PM
  #82
anthny2040's Avatar
I just tried taken them and my camera on my phone sucks and there not turning out. But i swear i will get them tomrow when my girl gets back with my camera.
Sorry guys
anthny2040 is offline
Old 06-29-2008, 07:41 PM
  #83
Bjs470's Avatar
What an awesome mod, looks great.
Bjs470 is offline
Old 07-01-2008, 09:15 PM
  #84
anthny2040's Avatar
Heres some of the pics i took tonight of the handles sorry bout the quality and they look awhole lot better in person!
Old 07-01-2008, 09:20 PM
  #85
Ankit69's Avatar
ahh cool you did white? Nice def need more pics and any suggestions or tips
Ankit69 is offline
Old 07-02-2008, 07:46 AM
  #86
cfr94's Avatar
looking at doing white also....looks good.
cfr94 is offline
Old 07-02-2008, 08:23 AM
  #87
anthny2040's Avatar
Ya thanks it looks really good in person !
Old 07-02-2008, 08:25 AM
  #88
Ankit69's Avatar
any suggestions or tips while doing the install?
Ankit69 is offline
Old 07-02-2008, 09:07 AM
  #89
cfr94's Avatar
Where did you get the white LED's, resistors (if needed), etc. I want to get a brighter white....any suggestions? Part # from the website for your whites, etc. Thanx in advance.
cfr94 is offline
Old 07-02-2008, 10:06 AM
  #90
Maxxedout01's Avatar
nice work
Maxxedout01 is offline
Old 07-02-2008, 12:54 PM
  #91
anthny2040's Avatar
I got the led's from here
http://www.allelectronics.com/
And went to radio shack for the resistors they are 470ohm resistors.
Old 07-02-2008, 03:40 PM
  #92
cfr94's Avatar
Sounds good, but what LED did you get? I mean I got 4 pages & about 14 different categories to go through. I could narrow it down to white but is there a difference in LED...they are a single LED bulb correct? Nothing like the 194 (from www.autolumination.com) Reverse tail light that has 9 small LED's in a light bulb factory setting. Sorry for all the questions.
cfr94 is offline
Old 07-02-2008, 04:05 PM
  #93
anthny2040's Avatar
Oh its no problem but you need a single 5mm led.
http://www.allelectronics.com/make-a...1-3/4/-/1.html
Those are the ones i used
Old 07-02-2008, 04:24 PM
  #94
MAXXED OUT Member!
wildman04's Avatar
Those LED's are the type that you need but I used 13,000mcd 5MM LED's that are more than 4 times brighter than these. It just depends on what you are satisfied with. No disrespect intended, just thought I would point out that the mcd's are a lot less than what I had recommended for everyone to use. Looks really good, can you post some side shots at night.
wildman04 is offline
Old 07-02-2008, 09:46 PM
  #95
anthny2040's Avatar
Ya i couldnt find the 13000mcd leds i looked everywhere but i ended up using some other leds i got from radio shack for the install.
Old 07-03-2008, 07:57 AM
  #96
OMARL956's Avatar
THAT LOOKS AWESOME. HOW DID YOU MANAGE TO THROW THE LIGHTS IN?
OMARL956 is offline
Old 07-03-2008, 08:04 AM
  #97
You embarrass me.
zero2sixtyZ's Avatar
OMG, LAY OFF THE Caps Lock.
And if you read the first post, there is a link after the pictures.
http://forums.maxima.org/6th-generat...d-install.html
zero2sixtyZ is offline
Old 09-04-2008, 06:56 PM
  #98
cineMAX's Avatar
Okay, so I know that I'm late on this post, but I just ordered some 20000mcd LED's and I will post up some pics once i get this done.
cineMAX is offline
Old 09-05-2008, 07:07 AM
  #99
Maxlover1718's Avatar
now thats hot
Maxlover1718 is offline
Old 09-08-2008, 02:03 PM
  #100
cineMAX's Avatar
OK, so I saw this thread and decided I would do this mod. I bought my Max a little over a month ago and I thought that this is something I have to do. I am posting this reply for all 07-08 owners. . . .THIS MOD WILL NOT WORK WITHOUT EXTRA WIRING!!! The 07-08's are different from the 04-06 models in that the step lamps ONLY illuminate when the door is opened and NOT with the remote. I am researching if both models use the same BCM and if they do, can it be reset/programmed to work with the remote. I've already purchased everything to do the mod only to find this information out. If it cannot be reset/programmed, extra wiring will have to be run to make the LEDs operable. Needless to say, I'm very disapointed.
cineMAX is offline
Old 09-08-2008, 04:57 PM
  #101
Anand.Patel's Avatar
do they fade in and out?
that would be sick
Anand.Patel is offline
Old 09-08-2008, 05:26 PM
  #102
cfr94's Avatar
Keep us posted, I mean those with 07-08's. I don't mind runnin' more wires, as long as the mod CAN be done. Don't forget pics please.
cfr94 is offline
Old 09-08-2008, 06:35 PM
  #103
thealliance43's Avatar
yea i believe its all wiring ran through the doors... and you just drill a whole in the handle and wire the led through there... i like the modd alot but probably wont be tempting it... you can run the wires through your speaker tubing into either the fuse box or even ur courtesy lights... also... what ppl are meaning by remote is when you unlock your car doors your domes, door lights and usually all interior lights turn on... so you just find which one you want and wire it to that... very easy modd to wire up... good luck to all who try this!
thealliance43 is offline
Old 09-21-2008, 10:59 AM
  #104
jetsfan2008's Avatar
damn thats hot
jetsfan2008 is offline
Old 12-18-2008, 06:59 AM
  #105
Propa Teknique's Avatar
Do you have to get the 13,000mcd LED's or can you go higher to something along the lines of 27,000mcd?? Would the brightness just increase??
Propa Teknique is offline
Old 12-18-2008, 10:57 AM
  #106
po8pimp's Avatar
go to autozone, they have the 4 pack leds there. I have had mine installed since the day after I first saw this post back in April and no probs yet. This is a very hot mod and gets lots of attention. really doesn't take too long either. As I mentioned earlier you can also do the interior led mods too. Link is in my last post on this thread.
po8pimp is offline
Old 12-18-2008, 11:23 AM
  #107
Torgus's Avatar
looks good but i'd have used white...
Torgus is offline
Old 12-19-2008, 03:57 AM
  #108
MAXXED OUT Member!
wildman04's Avatar
You can use any MCD you want but the higher the MCD, the higher the intensity of the light. Hope all works out well.
Old 12-19-2008, 04:58 AM
  #109
Veniality's Avatar
GENIUS.................
Veniality is offline
Old 01-11-2009, 05:30 PM
  #110
Talon05's Avatar
very nice , will make Lexus copy you and then they will try and patent it, you better do it first.
Talon05 is offline
Old 01-11-2009, 10:45 PM
  #111
slick101's Avatar
Thought About doing something Like that... then figured its a waste
slick101 is offline
Old 01-19-2009, 04:27 AM
  #112
Buyers beware, local pick up recommended. Slow to ship out items already paid for.
cwfalconfootbal's Avatar
I saw this in a 2002 maxima and it looked cool. what car is this modeled from? where did you get the idea?
cwfalconfootbal is offline
Old 01-19-2009, 07:29 AM
  #113
I think someone had saw it on a BMW or a Benz, because I know the lights on one of those are aimed downward to the ground and they fade in and out. It's pretty cool to see on a Max too.
Old 01-19-2009, 02:32 PM
  #114
Eric-Holmes
This is really cool. I'd hate it if the stinking LEDs burned out though.
So they only come on when you lock and unlock the car right? They don't burn full time when you turn your headlights on, do they?
Old 01-20-2009, 12:04 AM
  #115
po8pimp's Avatar
right the work just like your curtousy <sp? lights.
po8pimp is offline
Old 01-20-2009, 07:49 AM
  #116
tbone587's Avatar
That looks very cool, im suprised the led is soo bright!
tbone587 is offline
Old 02-02-2009, 12:53 AM
  #117
eric_holmes's Avatar
lets bump this to the top. Has anyone else tried this. It looks good, but Id sure hate to mess something up.
eric_holmes is offline
Old 02-02-2009, 01:43 AM
  #118
po8pimp's Avatar
this is a very easy install and if you follow the instructions you shouldn't mess it up. The only thing I could see someone messing up is drilling. Take your time and do it right. Push too hard with drill you might crack it. Worst case you have to buy a new door handle. Being that it is a two part handle it probably won't cost all that much. Might come unpainted though. Then you have to figure that all out. Yea just be careful. You can allways have someone you trust do the install. This mod is about as easy as they get. I swear this took about 10-15min a door. Spending about 9-14 of those minutes taking the door apart.
po8pimp is offline
Old 02-02-2009, 03:04 AM
  #119
po8pimp's Avatar
I read through all the lighting service manuals for the 07 model. I couldn't find anything that said the step lights worked when the doors unlocked, but couldn't find anything that said they didn't. The only way you will be able to test this is to take the inside of the door apart and get in the car and close the door. You will have the plug that came from the light available to take voltage readings from. Take voltages with the doors unlocked and shut, then take them with the doors locked and shut. You should get 3.8 volts when the light is illuminated. If you get 3.8 volts when it is unlocked, then you will be able to use this as a connecting point for this project. If this test doesn't work then you will still be able to use the foot lights connection inside the car. More wires to run but worth it. I don't see why they would change the BCM for 07 and 08.
po8pimp is offline
Old 02-05-2009, 01:06 PM
  #120
danrob's Avatar
Great job, something else to add to the list of things to add.
danrob is offline
Quick Reply: LED's in Door Handles
