LED tails installed!!! Lot of pics...
Old Aug 4, 2008 | 04:14 PM
  #401
Hilbe's Avatar
Originally Posted by jattsingh
Thanks, I did try to take the existing lights off, however they are very hard to get loose. I unscrewed the bolts and the lights were able to move a bit, but I am having a problem pulling them straight out.. They just don't seem to budge.. Any suggestions on getting them out?
As previously posted make sure to tape the heck out of the bumper. I gently tapped my bolts with a rubber mallet. That seemed to get them loose enough to pull.
Old Aug 4, 2008 | 07:11 PM
  #402
larsim's Avatar
Wink. I'll do the rest.
Oooookay. I am back at having issues with these lights again. Tonight I noticed that my radio button lights were out - so I thought "oh no, the LED lights are probably acting out again". And sure enough, get home, pull into the garage, and both lights are completely out.
The funny thing is when I step on the brake, it lights up fine. But the moment I let go off the brake pedal, its complete darkness (not good for night driving).
And yes, I did check all of the fuses o-n-e-b-y-o-n-e and they are fine. So what gives? Am I the only that has had this issue?
Old Aug 4, 2008 | 07:59 PM
  #403
MAX2DAMAX's Avatar
if the radio button lights are out, it has to be a fuse, try unplugging the lights and see if you get your interior lights back, if you do we need to warranty those lights.
Old Aug 4, 2008 | 09:12 PM
  #404
larsim's Avatar
Well - I just unpluged and re-pluged both lights to make sure it isn't a bad connection, but no luck. I have break lights, but no lights and now my radio button lights don't work either. I re-checked all of the fuses, and none are blown. My choices are 1) put the OEM lights back on to see if the problem persists, 2) bring it in to someone who understands electrical or 3) the hell with these lights that have given me so much headache lately
Old Aug 4, 2008 | 09:15 PM
  #405
MAX2DAMAX's Avatar
I just thought of something else, make sure you have the right plug in the right connector, meaning brake light plug with brake light connector on the lights and running lights with running lights on the tail lights.
Old Aug 5, 2008 | 04:23 PM
  #406
larsim's Avatar
Now my situation just went from bad to worse. I got home today and went to mess around with the lights, plugging, unplugging making sure that everything is connected the right away. No luck - the lights still did not work - only the brake lights did (also remember that my radio lights inside the car don't work anymore either).
Then I thought, "let me plug in the OEM lights to see if they work", and for my surprise even the OEMs didn't work . Next I decided, "ok, let me put the LED's back on because at least with them I have break lights" and this is where things REALLY went bad....
After installing the LED's back on, I noticed that even the brake lights weren't working anymore!!! Checked the fuse box, and discovered that the brake light fuse was blown, replaced it and still no go. Then I thought, "let me see if the car drives ok". Turned the engine on, went to put the car in reverse, and guess what? Now it won't change gears. I opened the little hole thing on top of the gear panel and stuck a screwdriver in so it would let me change gears.
So a summarization of the day = No LED Lights. No OEM lights. And now everytime I need to put the car in park or vice-versa, I need the assistancce of a screwdriver
I just called a mechanic and he is charging $120 bucks to come take a look at what the problem is and fix it. These lights are w/o a doubt beautiful, but had I known that I would have all of these problems, I certainly would have stayed with the OEMs
UPDATE: got the brake lights back working and resolved the gear problem (at least I no longer need a screwdriver to start the car ). However, it still a no go on the LED lights or the inside radio button lights (and yes, all of the fuses are okay).
So regardless, I am still having to have someone look at the car tomorrow to tell me why the inside lights aren't working.... what a pain in the A$$
Old Aug 5, 2008 | 06:08 PM
  #407
jsmithsole's Avatar
*moderator*
Wow man that sucks, hopefully it's nothing major. mine (and it seems everyone else's) were plug and play...
  #408
MAX2DAMAX's Avatar
I really wish I could help me more than what I have told you already, but without been able to actually look at the car and the connections my options are limited, please keep me updated, as of now your lights are the only ones that have had this type of issues( from my side there is a good 80-90 lights out there), regardless you are covered under warranty so a full replacement will be sent out to you if you lights turned out to be bad.
Old Aug 5, 2008 | 06:15 PM
  #409
larsim's Avatar
Thanks Edgar. You have been very responsive and I understand it is not your fault. The guy tomorrow will perform all of the tests to determine what the problem is and I'll let you know.
Old Aug 6, 2008 | 04:28 PM
  #410
larsim's Avatar
Okay - the mechanic came and took a look at it and it looks like my car is a total loss......
nah, just kidding
Here is what happened. The mechanic came, started working on the car and 15 minutes later he comes back and says:
Mechanic: Your problem is fixed.
Me: What?!
Mechanic: Yea, it's fixed.
Me: What was the problem?
Mechanic: It was a blown fuse.
Me: But I checked ALL of the fuses and none were blown!
Mechanic: Did you check the ones in the engine compartment?
Me: NO! I didn't know there were fuses in the engine compartment! I thought they were all housed in the dash box inside the car!
Mechanic: No, you have a bunch of fuses here next to the engine too.
Me: (about to beat myself in the head ARRRRRRRGGGGGGGHHHHHHH )
Bottom line: because of the simplicity of the job, he "only" charged me $50 bucks. And he also did say that when I was messing with the LED lights I must have somehow touched the two pins together and that caused the fuse to blow (and the funny thing is I remember seeing sparks when I was messing with the lights a couple of days ago ).
So boys and girls - lessons of the day: 1) There are fuses housed inside the engine compartment! 2) When messing around with these lights, make sure your turn the car completely off and it is also a good idea not to let the pins touch each other
Old Aug 6, 2008 | 04:41 PM
  #411
MaXXXpower's Avatar
name came from hairdryer
nah, just kidding
Me: What?!
Glad it turned out well. I'm shocked no-one mentioned there was a fuse box under the hood in this thread, but like myself, we figured you knew.
Also, when changing the lights or anything electrical, undo your neg. battery terminal.
Old Aug 6, 2008 | 04:59 PM
  #412
chernmax's Avatar
Nations 1st 6th Gen Turbo
nah, just kidding
Me: What?!
LOL, Duh when you bought the car didn't you get an owners manual?
When I went boost I had to move it!!!
Glad it turned out OK, your pride will heal...
Old Aug 6, 2008 | 11:30 PM
  #413
MAX2DAMAX's Avatar
guys the lights are on sale for the rest of the month, 319 shipped!!!
Old Aug 6, 2008 | 11:49 PM
  #414
jsmithsole's Avatar
*moderator*
Actually there are 2 fuse boxes under the hood, keep that in mind when something else goes wrong next time!!!!
Old Aug 7, 2008 | 07:14 AM
  #415
OMARL956's Avatar
i recently got my lights but hadnt installed them since i didnt really have time and it just so happens that my brake lights dont work on one of the tails and the other just completly doesnt light up. wtf??
Old Aug 7, 2008 | 07:33 AM
  #416
MAX2DAMAX's Avatar
hey omar try this:
http://forums.maxima.org/6th-generat...look-here.html
Old Aug 12, 2008 | 07:40 AM
  #417
OMARL956's Avatar
hey thanx max2damax i opened up the connectors a bit and they work nicely....they look so sweet!!!! now its like to tint or not to tint...that is the question?? haha
Old Aug 16, 2008 | 01:18 PM
  #418
Libz's Avatar
okay love these so far, 1 problem i searched all 11 pages of this thread i dont think its in here...1st day, worked fine all day...2nd day worked fine half the day. my brother took my car for a minutre to check it out when i noticed my left tails are out.. so when he gets back i turn off the car and figured w.e ill wait untill my reverse l.e.ds come and ill take a look to see if its loose... i turn on my car an hour and a half later to leave and there both working again... is this going to be a consitant problem?
Old Aug 16, 2008 | 06:24 PM
  #419
Libz's Avatar
now a differnt problem awaits, both lights work except the left brake light now.. i just turned on my car, works fine.. 30 seconds later it doesnt turn on at all..heres some pics someone help! this is what it looks like sorry for the bad pic its with my phone ..notice the left light is completely turned off when it press the breaks do you think this is a loose connection or what? i dont feel like constanltly redoing it so im waiting for my reverse lights which will be here in 2 days =
Old Aug 16, 2008 | 06:27 PM
  #420
MAX2DAMAX's Avatar
Libz, just try to do this
Old Aug 16, 2008 | 07:28 PM
  #421
Blulytes's Avatar
same thing happened to me last week.
Just open the pins... it comes back to life!
Old Aug 22, 2008 | 11:17 AM
  #422
SmokinMaxSE's Avatar
SmokinMaxSE
Well I ordered the clear tails first and from the rear it looks good but from the side/angle its to much. It would look good with black wheels,tint and without the chrome door handles. So I decided to exchange for red and I'll have finished picks next week.
But for anyone who wants to see what chrome tails look like on smoke here you go.....
Old Aug 23, 2008 | 07:15 PM
  #423
roddykaregaran's Avatar
looks awsome.
nice job
Old Aug 25, 2008 | 04:02 PM
  #424
SmokinMaxSE
Ok, so I installed the Red tails today and I had to play with the connectors to get them to work. The reverse tails worked right away no problem. The main brake light did not work until I took the pins and spread the inward.
My biggest problem is my 04 Maxima has one brown connector and one grey connector for the 3157 bulb and I found that they had the connections switched around the wrong way. I can't get the Brown connector to lock into its place. I had to stretch the wire with the shortest length over into the next hole where this Brown connector does lock into to.
For now they work ok except both blinkers will blink normal and then real fast.
I looked here http://www.vqpower.com/v2/news.php?readmore=212 and I have a different harness with a brown connector and different wire colors too.
Old Sep 11, 2008 | 12:30 PM
  #425
OMARL956's Avatar
whats going on guys? i put int the lights and they worked perfectly only thing was that i had already ordered lights from autolumination and my excitement took control of me and i ordered the wrong set of bulbs. i apparently ordered the front turn single lights which are 1157. would this be the light above the the hid light or the side marker light.
Old Sep 18, 2008 | 12:50 PM
  #426
uavscrappy's Avatar
Need fellow LED Tail Light Peeps Opinion
I am looking at purchasing some LED Tail lights for my Maxima but not sure what fixture I should get. I have a '05 Smoke Metallic with Chrome Rims and dark tinted windows. I saw the clear on SmokinMax's and the Reds. Do yall think the smoke would look too tacky?
Thanks.
Scrappy
Old Sep 18, 2008 | 12:53 PM
  #427
MAX2DAMAX's Avatar
I like the smoke lights, they look classy not ricey like the chrome ones
Old Sep 18, 2008 | 01:29 PM
  #428
uavscrappy's Avatar
I agree Max and I value your opinion on this, thanks for replying.
Old Sep 20, 2008 | 02:12 PM
  #429
I3LAZEN's Avatar
Here's some night pics of my LED tail's.. Thanks to 04MAX_ILLIN for installing them for me... some pics came out a lil blurry... keep in mind.. the pics dont look as hot as seeing it in person.. i cant stop looking at them!!
Old Sep 20, 2008 | 02:13 PM
  #430
I3LAZEN's Avatar
This pic is with the car in reverse [18 led reverse bulb] & no brakes applied...
This is with the brakes applied and in reverse...
a nice photoshop edit of 1 of the pics..
Old Sep 20, 2008 | 02:24 PM
  #431
I3LAZEN's Avatar
heres some really nice pics of the tail lights
Old Sep 20, 2008 | 03:46 PM
  #432
SmokinMaxSE
Wow, very good pics. Your license plate light is lighting the ground? or is that another light?
Old Sep 20, 2008 | 04:33 PM
  #433
I3LAZEN's Avatar
thanks.. nah.. i have blue LED ne0n underbody lights.. my license plate bulbs are white LEDs
Originally Posted by SmokinMaxSE
Wow, very good pics. Your license plate late is lighting the ground? or is that another light?
Old Sep 21, 2008 | 02:09 AM
  #434
chernmax's Avatar
Looks Great, I get mad props for mine, welcome to the club!!!
Old Sep 21, 2008 | 10:13 AM
  #435
blaxima06's Avatar
looks great bro...
Old Sep 21, 2008 | 10:27 AM
  #436
jetsfan2008's Avatar
damn those look incredible. When I get my max this is one of the first mods Im gonna buy.
Old Sep 21, 2008 | 12:00 PM
  #437
MAX2DAMAX's Avatar
hit me up when you are ready
Old Sep 21, 2008 | 04:43 PM
  #438
zuko's Avatar
the anti rice
FYI
These are cheaper on ebay
Old Sep 21, 2008 | 05:05 PM
  #439
blaxima06's Avatar
FYI for zuko,
no its not, i got it for $319.
Old Sep 21, 2008 | 05:08 PM
  #440
zuko's Avatar
the anti rice
Originally Posted by blaxima06
FYI for zuko,
You're doing it wrong
http://cgi.ebay.com/ebaymotors/2007-...mZ110290474450
