LED tails installed!!! Lot of pics...
Old May 23, 2008 | 12:11 PM
  #321
Veniality's Avatar
Originally Posted by bdmaxima
jw y just get the black ones or smoked?
and veniality black or smoked would look good...jsmith and hibe are the only ones i know of with ur color rockin the black ones so see how theres looks and see if u like it
thanks man......
Old May 23, 2008 | 12:36 PM
  #322
Hilbe's Avatar
Originally Posted by Veniality
so, u mean it doesn't come with LED reverse light. if thats the case where can i get the LED's.
thanks
No it does not. You have to use your stock reverse bulb otherwise.
http://autolumination.com/906.htm
About 1/3 of the way down the page. Looks like this:
Clear Focused Lenses
921 Signal/Marker Bulbs.
(Focused Lenses Emit Light out the nose of the bulb, like a flashlight beam)
Clear Lens: Light emits out the nose of the bulb, and is sharp like a flashlight beam.
Old May 23, 2008 | 12:54 PM
  #323
AscendantMax's Avatar
guess i'll post my pics as well
Old May 23, 2008 | 06:04 PM
  #324
FIU Panther's Avatar
Anyone with a Blue Max want to throw up some pics? I'm wondering what would look better the stock red or tinted LEDS.
Old May 24, 2008 | 03:33 PM
  #325
kamski's Avatar
.org extraordinaire
MY left side blinks fast, tried the posted fix no luck. Anyone else have this problem?
Old Jun 6, 2008 | 11:29 PM
  #326
DeusExMaxima's Avatar
I am not sure if the safety aspect of this has been explored. I noticed on a car with both LEDs and regular bulbs, that the LEDs turn on substantially quicker than the regular bulbs. I heard that the time differential could result in shorter braking reactions by drivers behind cars with LED equipped tails, as much as 14 feet shorter stopping due to the faster reaction times.
Case and point:
http://www.356registry.org/Tech/safe...aillights.html
Quote taken from article above:
Besides the increased brightness, another advantage of any LED unit is they come on instantly when the brakes are applied. Incandescent bulbs take a brief period of time (some people say about 0.2 seconds) to achieve full brightness. But at 70 mph, 0.2 seconds equals about 20 ft. So having LED taillights in a 356 is like putting another 20 ft. of distance behind you in terms of the reaction time of the driver following you. When the 356 driver with LED taillights applies his brakes, in essence the driver behind sees the brake lights 20 ft. "earlier" (at highway speeds) as compared to incandescent bulbs.
Old Jun 7, 2008 | 12:16 PM
  #327
MAX2DAMAX's Avatar
Neat!, never thought about that
Old Jun 7, 2008 | 12:49 PM
  #328
WINTERFAUST's Avatar
love the looks of these led tails.. wish they were'nt so darn expensive.. other mods will have to come first =)
Old Jun 7, 2008 | 02:56 PM
  #329
jsmithsole's Avatar
*moderator*
Yeah Deus, I remember when the 2000 Cadillac De Ville came out, this was big talk.
Old Jun 7, 2008 | 03:03 PM
  #330
Its a great selling point Edgar!!!
Jsmith: I remember the Caddy too. Loved all those LEDs!!
Old Jun 8, 2008 | 11:18 AM
  #331
Hilbe's Avatar
So has anyone figured out the magic combination of what you need to get LED switchbacks in the front to work with these tails?
Old Jun 8, 2008 | 11:58 AM
  #332
Ankit69's Avatar
i duno how but i have both working... never had a problem with em. worked since day one
Old Jun 8, 2008 | 12:01 PM
  #333
bdmaxima's Avatar
im tryin to see if the 6 ohm load resistor in the front will work but i can't find the info on which wire i need to splice into.....
ankit, what are u using to makin ur l.e.d tails + switchbaks work right?
Old Jun 8, 2008 | 01:50 PM
  #334
Ankit69's Avatar
did everything jsmith's install guide (http://www.vqpower.com/v2/readarticl...article_id=120) only problem i have is my driver side headlight turns yellow when i brake... not sure why that is
Old Jun 8, 2008 | 05:44 PM
  #335
04MAX_ILLIN's Avatar
One 6ohm resistor on each side of the vehicle will do the trick.
Old Jun 9, 2008 | 07:14 PM
  #336
ctrent86's Avatar
Very nice peice well done. Look like great quality.
Old Jun 17, 2008 | 04:10 AM
  #337
DaBossMax's Avatar
What to do to solve this problem?
I received my lights a few days ago. I installed them just to get an idea of how they will look and all I can say is WOW! The only problem I have is the driver side rear turn signal not working and the front blinking fast. I am not using any led reverse or turn signal lights. I reverse the connection of the brake and turn signal to see if the turn signal lights would work and they did. So will a resistor solve this? And how do I install it and where. I need help soon, I want them on so bad. I want to be the first in Memphis, TENN to have this on. Any help would be appreciated. Maybe a step by step.
__________________________________________________ ___________
Old Jun 17, 2008 | 06:07 AM
  #338
VigilanteMax's Avatar
A resistor is not needed for your car lights to work. Make sure that the metal leads on the connectors are not turned in any way and that there is full contact with the leads to your car connectors.
Old Jun 17, 2008 | 06:38 AM
  #339
PapaL's Avatar
It's your connector not making contact like VigilanteMax said. Once the connection is fully restored that hyper flashing will stop.
Old Jun 19, 2008 | 08:06 AM
  #340
DCUnited10's Avatar
wow, these lights look great!!!!!
Old Jun 20, 2008 | 06:50 AM
  #341
KiNgOfQuEeNz's Avatar
they are nice, alil too ricey for my taste though. I would just tint out the stock lights personally
Old Jun 20, 2008 | 07:04 AM
  #342
Albeit its fine for you to have an opinion but there are 4 styles and one is almost identical with the red, but the added leds inside that are not ricey at all. personally I dont think any of these styles are ricey but to each his or her own.
Old Jun 20, 2008 | 07:39 AM
  #343
fcoral 05's Avatar
Maybe you were blown away by the looks of one passing you on the road and knowing that you probably can't afford a set so you decided to hate on these lights, but to each his own.
Old Jun 20, 2008 | 08:59 AM
  #344
jsmithsole's Avatar
*moderator*
Yeah everyone is entitled to their opinion, but "ricey" really??? These are the farthest from that "in my opinion"
Old Jun 20, 2008 | 09:25 AM
  #345
blackmax07's Avatar
ricey? the red ones are not ricey at all..now if you want to say the other colors are, fine everyone has their opinion..but i duno about ricey..
Old Jun 20, 2008 | 10:04 AM
  #346
Is it me, or do the tails look a bit like an Altima
Old Jun 20, 2008 | 07:52 PM
  #347
In Borat voice...I get a step, he get a step. I get a window, he get a window. I get LED tails, he cannot afford! GREAT SUCCESS!
LOL JK man. To each his own.
Old Jun 21, 2008 | 05:45 PM
  #348
Macintosh's Avatar
I have the '04 max in Radiant Ember (burnt orange). My tint is 35% all around (if that matters). Which color lights would look good on my car?
Old Jun 21, 2008 | 09:24 PM
  #349
MAX2DAMAX's Avatar
black or red, both would look great, what kind of wheels do you have?
Old Jun 21, 2008 | 11:25 PM
  #350
Macintosh's Avatar
I have the factory wheels right now, but I'm on a serious lookout for 20" chrome wheels. So the lights have to match both styles.
Would you happen to have any pics of burnt orange max's with the lights?
Old Jun 22, 2008 | 11:11 AM
  #351
jsmithsole's Avatar
*moderator*
I think blk would look good even with the chrome rims...
Old Jun 24, 2008 | 05:53 PM
  #352
i still get compliments on the tails from time to time. people think my red tails come like that from the factory.
Old Jun 27, 2008 | 10:30 AM
  #353
Yankeeblue04's Avatar
<--- Just got an 04 blue maxima SE Coming from a Acura Legend (rest its sole). I have enjoyed the max so far.. No mods yet, except for the tints and puddle lights. I think I have to have those taillights, haven't seen those in Atlanta yet....
Old Jun 28, 2008 | 02:10 AM
  #354
jsmithsole's Avatar
*moderator*
Welcome aboard, the tails are a nice first upgrade. Just not sure why you'd show us a stock dirty engine bay...
Old Jun 28, 2008 | 09:45 AM
  #355
He's a newbie. We'll learn 'im . . lol
Old Jun 29, 2008 | 08:46 AM
  #356
shadowfox777's Avatar
Regarding the LEDs for the backup lights, how do these two compare (below)? And which ones would you recommend??
Also, are resistors needed for the LED backup lights?
Thanks!
921 Superstar Bulbs With Heat Sinks
"Outfitted with the latest Super High-Flux 1 watt low profile Leds
Designed especially for gauges, and applications requiring a large uniform field of bright light
Note: These have the all metal heat sinks for constant-on applications to reduce heat related failures
Only 15mm diameter x 30mm overall"
Link to bulbs
921 9 LED
"Clear Focused Lenses
Clear Lens: Light emits out the nose of the bulb, and is sharp like a flashlight beam."
Link to bulbs
Old Jun 29, 2008 | 08:52 AM
  #357
Hilbe's Avatar
I got the 9 LED ones and they work great.
Old Jun 29, 2008 | 10:21 AM
  #358
0077's Avatar
if you are unsure just go red, can not go wrong with those
I have a question I have got a winter frost SL (white) tinted windows i'm thinking to get these tails but i'm not sure if I should go black or red. I'm thinking to get Tenzo Type-M rims so sometimes i'm thinking may be black and sometimes red its hard if I can't see them in person what do you guys think red or Black? thank you any opinion is appreciated
Old Jun 29, 2008 | 11:21 AM
  #359
bizzee's Avatar
Seems like I'll be the 100th person that can't decide on what color :x But I'm looking to purchase these and the 9 Way LED Reverese Lightbulbs. Question, what color do you think would look the best on a dark slate w/ 35% tint all around. Thanks guys!
Old Jun 29, 2008 | 11:41 AM
  #360
MAX2DAMAX's Avatar
bizzee, black for you, and 0077 go red,
