right side door lock sticking
Old Apr 25, 2008 | 03:23 PM
Lovemycar's Avatar
So out of no where my right side lock stopped working when i hit the unlock on the key frob it just moves a little not enough to open the door locking is the same way anyway to fix this i thought some one on the org had this issue
Old Apr 25, 2008 | 04:00 PM
redls1's Avatar
MAXIN' ON
I had my right passenger rear door sticking but Im under warranty and dealer fixed it, sorta.
Old Apr 25, 2008 | 04:28 PM
Lovemycar's Avatar
well it's funny because i don't think it's broke. so when i lock and unlock it work fine only if i wait maybe a second or two then it works it's almost lke it setup to do that
Old Apr 27, 2008 | 11:44 AM
LandsEnd's Avatar
I was probably the guy with that issue. Your symptoms are the exact same as mine when my front passengers side door lock started to fail. You will notice it getting worse, and worse. Mine never fully opens, or closes anymore. I have to do it the old fashioned way my finger.
Old Apr 28, 2008 | 11:10 PM
po8pimp's Avatar
take it out and clean it. really easy to do. search for door led install it should get you where you need to be for removal. then just clean it and cycle it with your finger till it is completely loose. LUBE, LUBE, and more LUBE.
boomerbrian
Oct 31, 2018 10:25 AM
FanaticMadMax
Sep 4, 2015 02:45 PM
maximusrising
Sep 2, 2015 09:55 AM
Hailstatejig
Sep 2, 2015 06:52 AM
