07 headunit
Old May 5, 2008 | 07:09 PM
blackmax07's Avatar
07 headunit
Has anyone upgraded the headunit in the 07 maxima..When you upgrade to a double din, do you also loose the AC screen? I know we loose the mpg screen ect ect, but how about AC..Has anyone figured out how we can keep those screens working? I know the screens tap into the bose unit, so its pretty weird trying to figure out how to keep them working, when the bose unit is being removed..wack nissan always making **** complicated! post some pics if you dont mind
Old May 16, 2008 | 10:23 AM
brnxv8's Avatar
Metra makes the kit u need to install a double DIN HU. i have the pioneer avic d3, looks awesome an no u dont lose the AC display. In my opinion though due to the fact u lose some of the little features like the timer an avg mpg gauge i would recommend getting something on the high end side to make up for it. the d3 was is perfect for me because it has the nav, the bypass is simple, u can add a rear view cam an if u tap into the VSS wire u get real time tracking an a couple other small features which more than makes up for the little things u lose. once again those just my opinion.
Old May 16, 2008 | 01:35 PM
Eddiesalsa's Avatar
hey brnxv8 what is the VSS wire? and what other real time tracking info do you get on the display?... I have been thinking about changing out my 07 HU, but would like to see pics of one if possible.... can you post some pics?
Eddie
Old May 16, 2008 | 05:19 PM
VinneousMaximus's Avatar
VSS would be the Vehicle Speed Sensor. Correct me if I am wrong. I too would love to see some pics. Sounds like a nice install.
Old May 16, 2008 | 05:43 PM
blackmax07's Avatar
Someone actually found a way to leave both screens working..there is enough room to stash the old bose unit behind the dash...
http://www.6thgenmaxima.org/forums/viewtopic.php?t=5358
scroll to the bottom to see pics.
Old May 19, 2008 | 11:34 AM
brnxv8's Avatar
the VSS is the vehicle speed sensor, its located bahind the speedomete, its kind of a ppain to get off, u need a very lond extension to get to the 2 lower bolts an what it adds is real time tracking, as in if u zoom all the way to street level an watch ur marker as u travel it moves as u move in real time! it turns when u turn an so on an also if u tap the screen when the map is up a cpl option come up an one of them is a meter display, u can customize it to show u battery voltage an other thing, if the VSS is hooked up u can look at ur speed in real time an lateral acceleration an a couple other things.
Old May 19, 2008 | 11:36 AM
brnxv8's Avatar
oh an i have no idea how to post pics, if some one can explain to me how, ill post pics of everything i have done, my ride with the rims an my system thankx
Excalibur23
Oct 13, 2015 04:33 PM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
Max139617
Aug 29, 2015 02:55 PM
Abdelrhman
Aug 17, 2015 12:16 PM
norton2099
May 9, 2001 08:46 PM
