Question about air intake
Old Jun 7, 2008 | 09:21 AM
  #41
Veniality's Avatar
i've decided im getting the fujita CAI, ordering it monday =) Again, thanks for the input guys
Old Jun 7, 2008 | 09:30 AM
  #42
WINTERFAUST's Avatar
Originally Posted by Hilbe
That valve can be purchased separately and installed up by the throttle body with the Fujita. I would consider doing it if I lived near a flood plain...
thats scarey... a bit too close to the throttle chamber for my liking...
Old Jun 7, 2008 | 09:43 AM
  #43
Hilbe's Avatar
Someone also sells a filter water cover thing to prevent water in the intake. Looks sort of like a beer cozy
Old Jun 7, 2008 | 09:48 AM
  #44
yes, its called a pre-filter. A few companies use them. they do not give you the same flow, but protect it from more dirt/debris and water getting in. I have one on my dirt bike.
Old Jun 7, 2008 | 12:38 PM
  #45
chernmax's Avatar
Nations 1st 6th Gen Turbo
I go to PTuning in VA for my ride tuning and during one session walking around the shop I noticed Injen makes a Hydro shield cover for their CAI's which prevent water from going into the filter. Anyway, here's a picture...
Old Jun 7, 2008 | 05:35 PM
  #46
NmexMAX's Avatar
dot dot dot ...
Anyone got an ID on the Fujita?
Old Jun 7, 2008 | 06:25 PM
  #47
VigilanteMax's Avatar
Originally Posted by WINTERFAUST
love my Nismo. I would go with the Fujita, but it does not have the bypass valve to help prevent hydro lock and it gets WET here....
Why then would you go with the fujita...I too have the nismo as you do and love it, yet you say go with the Fujita...
Old Jun 7, 2008 | 08:44 PM
  #48
chernmax's Avatar
Fujita IMO is a much cleaner look with equal if not slightly better HP gains...
Old Jun 8, 2008 | 01:16 AM
  #49
NmexMAX's Avatar
dot dot dot ...
But still no ID?
Old Jun 8, 2008 | 08:06 AM
  #50
If you say so, however to each his own. I dont think anyone has done a comparison on Fujita vs Nismo on stock, so dont think anyone can say slightly more. Nismo says 14hp gains and I know thats not right becuase Ive done bothe stock and nismo dyno and 5-7 hp at best.
Old Jun 8, 2008 | 10:22 AM
  #51
NmexMAX's Avatar
dot dot dot ...
Got the runfiles for that? Or better yet, an ID on the Fujita?
Old Jun 8, 2008 | 07:04 PM
  #52
ILL-Maxima's Avatar
You got an audio clip of the nismo CAI??
Old Jun 8, 2008 | 07:14 PM
  #53
GrimMax's Avatar
Where is my shirt?
Is anyone except me running the AEM? I say go with the AEM so atleast me and you can be in the same boat! lolol
The AEM is the same as the Fujita (one Piece) except it is mounted on a lower bolt that is already in place instead of next to where the stock box was. Oh and trhe filter looks slightly different! lol
Old Jun 9, 2008 | 03:50 AM
  #54
4MySwee's Avatar
I do not, just to answer your question.
I had the Fujita. I did dyno it. I had 220.3whp and 232.9 tq. The intake was all I had, performance-wise when I dynoed.
From what I had understood, we make a bit over 200 whp so if someone has an SL they can dyno with 17 wheels one it, that might give us a base to run from.
I would recommend the Fujita for a few reasons, but my specific ones are that:
1- If bought from RideTuner, the money supports a 6thgen website. (6thgenmaxima.org) for reference sake.
2. It pours here and I never had an issue with hydrolock. Your car is a car, not a pontoon boat and as long as your remember that, you will be good to go.
3. The looks and sound are out of this world.
4. Your warranty isn't any different than if you went with Nismo. Fujita stands behind their products. I'm not bagging on Nismo, merely noticing that folks are getting them based on this warranty idea.
5. Did I mention that buying from RideTuner supports a 6th gen site? RideTuner has an incredible reputation. Read his feedback.
Old Aug 26, 2008 | 10:18 AM
  #55
BETO6700's Avatar
Help me out here, I took my berk intake out and put the OE back in. The car feels faster and the throttle is more responsive. I checked with a mechanic friend and he told me that might be possible. He some computer are set to certain air flow. Any input from the intake Gods?
Old Aug 26, 2008 | 02:22 PM
  #56
chernmax's Avatar
Well if you read my statement again, I didn't note the type of Intake, I just stated look wise I think the Fugita looks better, HP wise she puts out as much gain and in SOME cases better gain than all true CAI's (Fujita, Injen, NISMO, AEM, etc.). And 3+ years ago when I installed my Injen I saw a dyno gain of 12 hp, couldn't compare it when I put on the Fujita because I already had Headers, UD Lightweight Pulley, Full catback, and the car had been APEXi tuned). But damn before I went boost, loved the look!!!
Old Aug 26, 2008 | 02:27 PM
  #57
chernmax's Avatar
Which means based on the decreased airflow, your ECU in about 3-5 days (depending on how much you drive) should recalibrate the ECU and you eventually will feel slightly less power...
Old Aug 26, 2008 | 03:39 PM
  #58
Apollos2's Avatar
It pretty common to loose some bottom end (take off/launch power) when a CAI is added but it's also pretty common to make it up on the top end...ie highway speeds and when you punch it and the rpms climb above 4k.
I've done lots of back and forth with the Nismo...Stock and Fujita intakes. Stock box with a K&N gave me the best launch but just didn't pack the punch I wanted when traveling on the highway. (Which is what I do most of the time).
As far as I know the only way around this is the Technosquare reflash but even then I'm not sure. I believe Shawndon had the flash and opted to go back to the stock air intake anyway. Also NNMax has talked about a MAF upgrade that I need to investigate.
Old Aug 26, 2008 | 08:37 PM
  #59
elitemaxima's Avatar
i want something that sounds agressive but not to loud to make my car a rice..i was gonna go with nismo brand but does the fujita one sound better?
vingodine
45
May 21, 2016 12:46 PM
A32goldylocks
Sep 2, 2015 06:39 AM
95Maxi
Aug 29, 2015 09:38 PM
cheftoo
Aug 20, 2015 05:17 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
