In-cabin filter.
Old Jun 17, 2008 | 01:50 PM
scrui's Avatar
In-cabin filter.
just a fyi,
Pepboys sells them for 15 bucks over the counter.
just bought one.
Old Jun 17, 2008 | 02:27 PM
lebanondon61's Avatar
THANKS FOR THE HEADS UP
Old Jun 17, 2008 | 02:47 PM
Shoey1's Avatar
good call
Old Jun 17, 2008 | 04:52 PM
scrui's Avatar
check these out, my first change. I never knew I was driving around like this. wow
Old Jun 17, 2008 | 04:56 PM
Ankit69's Avatar
what type did you get ? pepboys bran or like fram?
Old Jun 17, 2008 | 05:01 PM
scrui's Avatar
Purolator BreathEASY
code C35530. they only sell this brand for Cabin Air Filters.
Old Jun 17, 2008 | 05:02 PM
scrui's Avatar
They look exactly the same as the Nissan.
Old Jun 17, 2008 | 05:46 PM
cfr94's Avatar
Pics don't work
Old Jun 19, 2008 | 05:14 AM
Torchcorvette's Avatar
Where is the cabin filter located??? Just turned 20,000 miles on the 2007 and never checked the filter. Thanks in advance.
Old Jun 19, 2008 | 05:43 AM
VigilanteMax's Avatar
behind glove compartment, held by 2 clips. Advanced auto is where I got my purolator $12
Old Jun 19, 2008 | 03:36 PM
Terrentius's Avatar
I change mine every winter.
Old Jun 19, 2008 | 04:06 PM
jsmithsole's Avatar
*moderator*
Here's what mine looked like:
Old Jun 19, 2008 | 05:01 PM
scrui's Avatar
man, I used to get this stale odor every time I turned the vents, it was this crap.
now i get a clean smell.
will be changing mine every spring going forward.
and so easy to install.
Old Jun 19, 2008 | 08:02 PM
Kryogen's Avatar
I still get a crap odour sometimes with the AC. No clue why, changed the filter.
35$ in canada from NAPA, thats dumb.....
Old Jun 19, 2008 | 09:34 PM
DAlastDON's Avatar
WOW that thing looks heavily resonated.
Old Jun 20, 2008 | 05:57 AM
scrui's Avatar
that's weird, I use to get a smell only when i turned the hot and cold vents, as soon as i started the a/c, the stale odor went away. when i changed the filter - no smell.
Old Jun 20, 2008 | 10:40 AM
Wagnum 1's Avatar
Just changed mine and it was NASTY advanced sells them for 13.88 and a 25 % discount Mine was also bent because some one rammed it in there big difference in the air flow.
Old Jun 20, 2008 | 04:49 PM
Pardon my ignorance, but I reached behind the glove box and then looked under the box and I could not find any filter. Do you have to remove the glovebox??? If so, how does it come out?? or is mine the only 07 Maxima without a cabin filter?? Any advice will be helpful. Thanks.
Old Jun 20, 2008 | 04:59 PM
redls1's Avatar
MAXIN' ON
Keeping the glove box closed (empty), look under the glove box and you will see 2 plastic hing pins with tabs. Slide them inward and remove, then while holding the bottom of the glove box with one hand, open and tilt in a 40-45 degree angle so that the glove box comes out of the groove. Let hang by the wire. You should now be able to see the access cover for the filter, I used a small flap tip screwdriver to release the tabs and open for access to the filter.
Reverse procedures once installed.
Excalibur23
Oct 13, 2015 04:33 PM
homewrecker
Sep 23, 2015 03:41 AM
sdotcarter
Sep 2, 2015 09:53 PM
kirkhilles
Aug 8, 2015 10:53 AM
