Grinding Noise when Accelerating??
Old Jan 13, 2011 | 11:31 PM
  #41
ifti_sit's Avatar
Hello Guys..
like all maxima owners I had the issue which I tried to fix as per the two TSBs. I replaced the brackets and also welded the loose parts. The vibration got reduced to almost 70%. But still I get it when I am below 40 mph speed with the rpm between 1.5 to 2.5 K...its little vibration in the pedal along with vmmmmmmm noise..its for sure coming from exhaust ,..but i checked again and found no other loose parts...Only i saw the rubber holders which protects the pipe to touch the car chasis are little loose but those are i think supposed to be..i tried to shake the pipe but it dint move so much..only very little movement..
any ideas what other things to check in the exhaust ?
Old Jan 13, 2011 | 11:38 PM
  #42
lighty0770's Avatar
i had a problem just like that and it turned out to be my exhaust heat shield... i took it off and havent heard the problem since... hope this helps
Old Jan 14, 2011 | 12:36 PM
  #43
sunny2007's Avatar
I am kind of new to the forums. I need help. I have a couple of issues. One is vibration at idle my passenger seat shakes and if there is anything in the cup holder behind the shifter shakes. The other problem I have is my tires keep getting cupped on the inside. I have gotten an alignment a couple of times and it doesn’t help. I do hear the noise in my car. I am planning on changing the strut mount and struts with kybs. Could the strut mount moving around cause the vibration and cupping on the tires.
Old Jan 14, 2011 | 04:44 PM
  #44
ifti_sit's Avatar
Vibration at idle should not be by Tires..Clean you MAF sensor and Throttle Body..if required change your airfilter. That should be your first step towards this. If your car got high mileages then you might need to look your PCV and EGR. But first try with the first one - cheap and easy. Btw, while at idle whats your rpm speed ?
For the second issue - Tire Pressure / Wheel balance and Alignement is the first option that i wud try. You also need to describe the noises like is it from suspension or axle or wheel bearing..if you are not so sure..just get it inspected...
There are better members in this great forum who can correct me and guide you in a more better way-- so watch out for them to reply
Old Jun 2, 2011 | 10:26 AM
  #45
venusmoon777's Avatar
Grinding Noise
Hi My 2004 nissan maxima is doing the same thing ..... it's making a rattling noise everytime I accelerate, & worse going up hills & coming our of corners. It doesn't do it when I'm going faster I think because you don't hit the gas that much once you have gained speed. I think it's a loose exhaust clamp. I heard this noise once before when I picked my car up AFTER an oil change. No noise before the oil change, then it began after I picked my car up. I found out from a friend that the exhaust system runs all the way up to the front of the car & is possible to knock a clamp loose during work. The clamp was replaced ($50) & no more noise. I had tires put on a few weeks ago & now the noise has begun again. I suspect the same thing has happened.
Old Jun 6, 2011 | 12:38 AM
  #46
thuglife47007's Avatar
read this http://www.justanswer.com/nissan/2eb...nd-around.html
but before you try that try (engine flush)
i used engine flush bottle (8$) and cheap 5W20 oil (15$)
put about 2k miles on that oil and flushed it again but this time i use
my reg oil (castrol synthetic oil 5W 20) and ever since then i been changing my oil at
2k and i never heard that sound again
and also if ur O2 bank1 or bank2 light is showing then u might wanna get ur catz looked at as well hope this helped
Old Jun 6, 2011 | 05:11 AM
  #47
Costee's Avatar
Guys, what's the DTC for the timing chain tensioner, if there's one?
Old Sep 10, 2011 | 06:02 AM
  #48
super8sean's Avatar
I figured out where the sound was coming from
My engine block. Checked my oil and there was 0 oil in the engine smh.
After i put oil in the engine the sound completely went away.
Check your oil first!!!
Old Sep 10, 2011 | 05:06 PM
  #49
chernmax's Avatar
Nations 1st 6th Gen Turbo
The grinding sound for the last 6 years has been a result of a heat shield under the engine area that cracks off but still held in place, every time you rev the engine the 2 pieces make a grinding noise. Check that first!
Old Sep 19, 2011 | 09:14 PM
  #50
shuhengzhao's Avatar
same here. I had local nissan checked and even send this thread to them. They cannot find any problem on my car.
Old Sep 19, 2011 | 10:35 PM
  #51
Rsprince89's Avatar
I deffentily hear it, I geuss I will have my dealer check the heat sheild :-/
Old Jan 26, 2014 | 09:58 PM
  #52
jasminerobert's Avatar
May be bad wheel bearing. You definitely can get grinding noises, and sometimes clunking noises...
Old Jan 27, 2014 | 06:07 PM
  #53
chernmax's Avatar
Check the Heat Shield first, they have a known history for cracking, when you accelerate the grinding noise comes from the vibration of the 2 pieces rubbing together!
Old Jan 27, 2014 | 07:22 PM
  #54
KevMaster's Avatar
This is a common issue with 6th gen Maxima.
user 11122324
42
Jul 18, 2022 03:35 PM
D Mason
Jun 21, 2016 04:43 AM
Need help
23
Oct 2, 2015 08:56 AM
uttadms31
Sep 30, 2015 05:24 AM
