Single exhaust??
#41
If you do this with a nice free flowing intake setup (IE 3.25" intake setup) you'll see a huge increase.
I can't preach enough the more air you allow in and out freely makes a big difference, even when still NA, more air + tune for more fuel = more powah
#43
Yay on the single exhaust. Ill prolly have it fabbed up this week. Trying to figure out the best tube diameter and best tip and muffler. Also, trying to figure out the best what to block off the exhaust cut out on the driver's side.
#45
I doubt Cattmans exhaust guy would fab me something because he seems very busy. At this stage, Ill prolly get a resonator-back 3" exhaust to the passenger side rear. Not sure of muffler choice at this point. I am going to try to tuck the muffler up as far as I can to minimize that hanging look. Ill also probably black out the muffler for the aforementioned reason.
#46
Deus you goin boost? 3in is far to big for na. 2.5 max, you will loose power even with a nice tune and 3in. Even for turbo cars 3in isn't always the best way
#47
wow, you're acting on this faster than I expected. How exactly do you plan to block off the empty space? As far as mufflers go, my favorites are Magnaflows because of decent price, quality, and sound. Unless you wanna go big with Remus. I assume you're going to keep the dual tip design right?
#49
2.5", mandrel bent, as straight as possible. Muffler - HKS Ti, Apexi N1, or Blitz nur-spec. You'll need a big resonator to keep the noise down.
#51
One larger straight thru muffler might be a tad bit louder. The are shops in El Monte area, or you can get pre-bent pieces. Most shops should have those.
#52
#53
Not too mention that its been proven on a 3.5 with little mods to give as much as 15whp.
3" exhaust isn't just for boosted applications, I wish people would stop thinking that.
#54
3" exhaust can make power up top, but will lose low/mid for daily driving.
#55
he only had a couple bolt-on's (yes a 5.5gen but its the same engine)
then he added the 3" (seems to be gains through out)
http://mdpagi.com/merlyn/dyno.jpg
#57
Merlyn's Max...
#58
#59
Merlyn's Max...
You should do some more research about what size exhaust gives better performance, check muscle car forums too. 2.25 to 2.5 is best for excavating exhaust gas in NA because there's less room for the gas to cool and become heavier and harder to push. It's only one puff at a time, like how headers are designed. That's my $.02.
#60
I love center exhaust too. The problem is the spare tire holder is right in the way. The Lexus IS-F is interesting, but I dont really like "stacked" exhaust pipes, and even if i did, I would have to do some serious bumper mods, unless someone wants to try to photoshop it?
#61
Show me some dyno sheets of an na build w/ 3.5 and 3 in that gained throughout rpm range LOL honestly you may get slightly better power up top but will loose massive amnts of low end and torque Not bashing you or nothing dave just dont see eye to eye I had a sentra with a 3.5 in it and 3in exhaust w/ tune and when I switched back to 2.5 much more responsive and torquey and laid down better power band on dyno at zfever in tampa
#64
the bottom line is before the 3" exhaust.
#69
Because there is no SSIM, the SSIM keeps your top end real nice and he only has a rev limit to 6,500
blue line is before, the bottom line and the rest is after the 3" exhaust.
This is not mine...cause 3.0s are better
but thats a 5.5 gen with a 3.5, only intake/header/3" cat and back
#70
#71
This is one of those mods that responds well with the VQ. Like the SSIM, spacers, big bore maf and intake stack and others, just to name a few.
As technology advances its becoming more of a reality for a maxima to possibly break 300whp compared to 4 years ago. Its just alot of money involved to do so but I think with time and money someone could do it now.
#76
Larger displacement makes breaking 300WHP possible for an NA Maxima. There may not have been any different in the output with freeflowing 2.5" vs 3" exhaust since the headers and y-pipe are clearly not 3". But I digress...
I say Deus does some more research before committing to a size.
#77
#78
Is this proof enough:
http://forums.maxima.org/dyno-discus...44-ft-lbs.html
#79
This was proof for cattman to start trying to make the 3" exhaust for us as an NA application cause there has been enough proof that it provides gains.
And deus you could cut the cat out, weld in 2.5" exhaust flanges in so that you can unbolt the exhaust if need be. On the otherside of the y-pipe add another 2.5" exhaust flange and weld in a 2.5" to 3" section then from then on back do a 3" exhaust
