utec??? technosquare??? neo??? ecu reflash??
Old Nov 3, 2008 | 06:33 PM
drzcrazychulo4u's Avatar
ok so i want to take off the governors and rev limiters and all that good stuff the car was restricted on. what should i do??? i read alot about the utec and neo and TS but which is best for a auto 06 max?? please help
Old Nov 3, 2008 | 06:43 PM
IIvIIoNsTeR MaX's Avatar
+1
Old Nov 3, 2008 | 06:54 PM
JRoX85's Avatar
newbie
if you guys plan on going boost def the utec is you plan on staying all motor go with t-square
Old Nov 3, 2008 | 07:03 PM
no boost but i heard the utec is better
Old Nov 3, 2008 | 10:43 PM
RHMax's Avatar
Newbie just Registered
I don't think utec remove speed limiter.
What did you hear that's better about utec?
Old Nov 3, 2008 | 10:55 PM
well they are better for auto 6th gen because with TS its said that it goes back to oem standards unlike the utec it stays with the changes
Old Nov 4, 2008 | 08:05 AM
RHMax's Avatar
You heard wrong. TS has nothing to go back to since it rewrites the codes in the ECU. In other words, TS ECU is permanent.
Old Nov 4, 2008 | 08:41 AM
NiZMo1o1's Avatar
UTEC does removed the speed govener , If your planning on a ECU that can be tuneable then go with the UTEC.
If your not prone to tunning then stick with the TS,
I have no speed govener with the UTEC in.
Also the NEO cant compare to either of these ECU/Piggybacks
Old Nov 4, 2008 | 09:06 AM
90max's Avatar
lol @ op......
Old Nov 4, 2008 | 10:15 AM
RHMax's Avatar
How do you tune to remove limiter?
aw11power
Oct 10, 2021 04:57 AM
gigabyte
Jan 6, 2017 06:05 PM
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
BLACKKILA.GTR
Sep 29, 2015 11:23 AM
QueensMAX
Sep 15, 2015 04:14 AM
