Help! Got new tires, now I have a humming motor noise
Old Dec 12, 2008 | 10:25 PM
-Sin-'s Avatar
I finally had to get new tires for my 05 and replaced my RSAs at 43,000. I got Continetials ContiExtremeContacts 245/45 18s. Now I am getting a humming motor noise from the engine when I take hard turns, when the car floats up (like hitting a dip in the road and you launch a little) or when braking hard. My ABS is also kicking in a lot more. It's not tire noise and it does not seem as though I am losing traction or skidding. It's fine when I accelerate hard and I get no noise when I start the car, put it in gear or when it shifts. Can anyone help with this one? It's freaking me out.
Old Dec 13, 2008 | 08:03 AM
popcorn's Avatar
Sounds like something is rubbing. Maybe when they put the tires on, they popped one of the plastic rivets from the wheel well liner and it's coming in and rubbing your tire.
Do you hear the sound when turning right and left? Or just one way? My guess is that it's on one of your front wheel wells because it does it when braking hard, when the front suspension is under load and you lose clearance between the front wheel well and the tire.
Old Dec 13, 2008 | 09:06 AM
-Sin-'s Avatar
It does not sound like rubbing and I looked at the wheel well. It sounds like a faint humming motor, like it's pumping or something.... could it be the ABS or motor mount? I check the disk temps on all 4 sides, front driver 96, driver rear 71, front pass 101, pass rear 102? not sure if that helps or provides more confusion. Also still on the orignal brakes and I am not hearing the wear indicators so I think they're still OK. I'll check those today.
Old Dec 13, 2008 | 09:24 AM
Shoey1's Avatar
im going to say wheel bearing
Old Dec 13, 2008 | 09:54 AM
-Sin-'s Avatar
How would the wheel bearings being doing this?
Old Dec 13, 2008 | 10:11 AM
06maxima's Avatar
wheel bearings will cause more of a constant noise whereas -Sin- is having it when turning or braking
Old Dec 13, 2008 | 10:19 AM
Lovemycar's Avatar
You did say your ABS was kicking in more that my be the sensor none issue or like they siad something rubbing
Old Dec 13, 2008 | 03:31 PM
-Sin-'s Avatar
Yup, the ABS has come on more times in 24hr than it has in the three plus years that I owned it. It also does it when the car floats (lifts up a little)....
Old Dec 13, 2008 | 05:19 PM
Lovemycar's Avatar
dirt in the sensor
Old Dec 13, 2008 | 06:35 PM
-Sin-'s Avatar
Originally Posted by Lovemycar
dirt in the sensor
How would I go about checking and cleaning that?
Old Dec 14, 2008 | 11:18 AM
STARR's Avatar
Who put your tires on, many times I have heard of places doing one thing only to break something else in the process, are you getting any engine lights, is it under warranty, take it to the dealer
Old Dec 14, 2008 | 07:28 PM
-Sin-'s Avatar
Discount Tires put on the tires on. No lights and out of warrenty 43,000 no extended. I concure with Lovemycar, dirty sensor. I read the threads and I am having the same issues.
Old Dec 15, 2008 | 09:44 AM
Blulytes's Avatar
have them check the wheel bearings...
I just had a similiar noise and that was it.
Old Dec 15, 2008 | 10:21 AM
-Sin-'s Avatar
It's the ABS, I unplug the fuse and no more noise. Dirty wheel sensor. i am working to get that clean now....
MR2 T'd
Jul 9, 2021 05:06 AM
alahjahwan09
18
Sep 21, 2015 09:12 PM
jfl330
Sep 4, 2015 01:44 PM
