Checking CVT Fluid
Old Feb 3, 2009 | 05:10 AM
mwh's Avatar
mwh
Checking CVT Fluid
Looking under the hood and then in owners manual I do not see a dip stick to check it. I searched this site and found a recommendation to have the dealer check the viscosity of the fluid but that is it. So how do I check it?
Old Feb 3, 2009 | 05:48 AM
07 Graymax's Avatar
its the long tube between the fuse box(next to battery) and the engine cover. it sticks up so you cant miss it. the top is kinda hard to get off so just pull up on it
Old Feb 3, 2009 | 07:22 AM
mwh's Avatar
mwh
I thought that may have been it but it felt like it was going to break when I pulled it up so I referred to the manual and nada. Will try it again
Old Feb 3, 2009 | 07:25 AM
mynameispee's Avatar
take a mini-screw driver or pick and push on the release tab, it secures the dipstick to the tube.
Old Feb 3, 2009 | 10:02 AM
nene503's Avatar
I had the same question. Thanks to all the info!
Old Feb 3, 2009 | 10:23 AM
nene503's Avatar
Also, has anyone added a tranny cooler to their CVT transmission (like either B&M or Stillen)?
Old Feb 3, 2009 | 01:53 PM
mwh's Avatar
mwh
not done yet
so I got the dip stick out and did not see any writing on the stick except "hot". Since there was nothing in the owners manual I expected to see "check it when hot in neutral..." on the stick. So does anyone know if it should be in park or neutral and what color fluid is acceptable?
Old Feb 3, 2009 | 03:38 PM
Terrentius's Avatar
Okay, make sure th car is really warm...like been on the highway for twenty minutes. Anything less and you will get a reading of zero. Then put it on flat ground and check the fluid while the car is still running. This will give you your reading.
If you have to add fluid, then take it to the Dealership cause there is a problem.
Old Feb 3, 2009 | 07:40 PM
PhotoGus's Avatar
According to Nissan, the car will tell you when the CVT fluid needs to be replaced, or added. If you need to add CVT fluid to your CVT equipped vehicle then there is something seriously wrong with it.
As far as replacing CVT fluid, could take 50k, could take 150k. Depends on how and where you drive. Have fun, and never let some quickly lube grease monkey touch your tranny fluid.
Old Feb 4, 2009 | 04:29 AM
nysmaxima's Avatar
while we're on the subject...does anyone else notice that their cvt tranny seems to be noisier when cold and during city driving...
Old Feb 4, 2009 | 05:40 AM
mwh's Avatar
mwh
Based on the lack of info in the owners manual I assume that it tells me it needs to be replaced when I am broke down on the side of the road 3k miles after the warranty ends. This is what I am trying to avoid and want to check it now and make sure it is not going to be a problem.
Old Feb 4, 2009 | 10:53 AM
Terrentius's Avatar
Well, not much I can say except change it when you feel you need to. For me, I am gonna change at 60k regardless of what the techs say. On that note, changing CVT is $$$. I bought a litre to have just in case and it cost me $40.00 Canadian. Do the math for how much our tranny takes and you can see that it is expensive.
As to when to change the fluid, hard to say. My Dealer tells me that they can test it to see when it needs to be changed. He also said that he couldn't give me a firm time-line when to change, which, like you, makes me uneasy. So, I am gonna just change it at 60k and be done with it.
Mar 12, 2020 12:06 AM
DarjeelingRose
Sep 15, 2015 01:20 AM
Maxxx10
Sep 13, 2015 03:16 PM
jfl330
Sep 4, 2015 01:44 PM
dcardello
Sep 3, 2015 11:44 PM
