Advice on 06 purchase
Found a really clean '06 SE with only 8k miles and am contemplating making the step up from my 2000 GLE (with stiffened suspension)
Anything I should be wary about with the '06? I've searched the forum and didn't find any dire warnings.
It's an automatic, but I'm not sure if it's the CVT or not - nothing on the info about teh car specifies whether it's the CVT. How can I tell and would it having the CVT be good or bad in the '06 - that was the first year for CVT, right?
I say go for it. If it is a 4 speed they have upgrades. If it is a 5 speed well get in line. As mentioned above not all 04's have the problem. I think most of mine is self inflicted due to the driving habbits I have. If you drive hard be careful. If you like to float around and show off the looks then a 5speed or 4 speed should be ok.
Buy it, nothing to really think about, my 06 has almost 60k and no problems, the only problem was the exhaust rattle which was a broken clamp which the dealer can fix in 5 minutes, drive around with the windows down and maybe under an underpass and see if you hear a rattle
Only other issue may be brakes, my 06 had extremely hard factory pads that ate right into the cheap rotors Nissan put on, car stopped fine but I got tired of the vibrating steering wheel.
