P1402? Need some help....
Old Mar 24, 2009 | 12:02 PM
jimmypronet's Avatar
i looked under the hood and i tried some research but no luck so can anybody show me wheres the egr valve located at on our maxima? thanx
Old Mar 24, 2009 | 12:24 PM
Apollos2's Avatar
You might find some help in this thread:
http://www.6thgenmaxima.org/forums/viewtopic.php?t=8478
Old Mar 24, 2009 | 02:13 PM
Fastmax05's Avatar
"Ok,Whats next?!?!"
Bla.. have this on my ride right now.. I just made an appointment w/ my local dealership to get the car fixed..
Old Mar 24, 2009 | 04:44 PM
Oolatec's Avatar
EGR valve is a pain in the *** to get to... it's between the engine and the cabin firewall.
Old Mar 24, 2009 | 05:38 PM
GrimMax's Avatar
Where is my shirt?
Yeah the EGR is a real pain to get to. A great way to see it if you can lift the car and its actually connected from your manifold and runs into your rear exhaust header.
It has some black wrapping stuff around it. Here a pic. It should run into some sort of connection that leads to the valve itself.
Old Mar 25, 2009 | 09:23 AM
Thanx for some info guys i guess i need to start takin g those parts apart... let you guys know whats the oucome....
Old Mar 25, 2009 | 09:37 AM
i got one more question guys... is it cleanable or just replace it cuz for me it looks like just a metal tube... correct me if i was wrong....
Old Mar 25, 2009 | 09:58 AM
The Presence's Avatar
Ahhh... I got the P1402 code several weeks ago and my ride started
idling all weird and over-all performing very awkward. My mechanic
said the EGR valve shouldn't be bad but it's a possibility that it is.
He advice me to get new pre-cats but those damn things are super
expensive. So yesterday I order a set of Cattman headers and they
should be arriving next week. Being that I have a good friend that
has been a automotive fabricator,mechanic and body work specialist
for over 20 years. He has taught me a lot over the years to where I
can say I'm a D.I.Y weekend mechanic. I had everything taking apart
to remove that dang EGR Valve and I couldn't get good access to the
single bolt that connects it to one of the Pre-cats. Once I have access
from underneath while pull out that precat next week it should slide right
out but still connected. Then I can remove it once it's out of the engine
bay/firewall. OH!! The bolt that everyone is referring to on the EGR valve
is huge "@ least a 31 or 32 mm" but I'm not 100% sure. You can try but it
is extremely difficult to get a good grip/access to that bolt. I was able to
get a set of grip plyers on and try to tap it loose with a small pry bar. Plus
I tried using a few solid small steal pipes that I use for difficult bolts & nuts.
If you can get it off "Please let me know how". You would be officially my hero of the year bro!!!
The pipe that their showing you above runs from the IM to the EGR Valve. Cant' miss it!!
Old Mar 25, 2009 | 10:08 AM
It's really easy to remove the tube itself to see if there
is a build-up of carbon in there. Which might or might not
be the case!! Go ahead and try that out to see if it's just
a build-up. Mine was pretty clear.
Old Mar 25, 2009 | 06:06 PM
GrimMax's Avatar
Where is my shirt?
Yeah the tube runs for about $60 from Nissan. Part number should be 14725-7Y001
Old Mar 25, 2009 | 08:04 PM
i just order the EGR valve cuz none of them carries it... they said it takes like 3 to 5 days... so now all i can do it wait...
Old Mar 26, 2009 | 06:33 PM
STARR's Avatar
Any updates, driving home tonight my SES light went on, no driving problems whatsoever, 59600 miles
Old Dec 17, 2009 | 09:06 AM
Les7311's Avatar
Code appeared with me also.
What is recommended here?
Remove and clean EGR-TUBE????
Remove and clean EGR-VALVE????
jasba
Jul 16, 2005 08:18 PM
Ted_MEng
Mar 29, 2004 12:49 PM
maximagoodcar
Feb 22, 2004 10:43 AM
StillenMax32
Nitrous
Mar 7, 2003 05:17 AM
