Installed new 3K HID fogs from Operatic. And KP independent fog module
Old Apr 4, 2009 | 09:19 AM
jsmithsole's Avatar
*moderator*
I bought a kit from Operatic here on the org, the product looks great and the install was (almost) plug and play but easy none the less. I did end up dropping the bumper for easier access. I also installed the KPTechnology fog module so I can turn the fogs on by themselves using he stock switch by the headlights.
They are damn bright!!!
Fogs only (with the new KP module)
Bonus art fart pic...
Old Apr 4, 2009 | 09:31 AM
MyGirlsMaxima's Avatar
those look hella nice...what they look like on with your headlights on too?kinda amixture of colors I assume. I wanna do that! haha
Old Apr 4, 2009 | 09:37 AM
ILL-Maxima's Avatar
J, you said they were almost plug n play. Other then the module to keep the fogs on by themselves (which i assume you really don't need unless you want to turn the fogs on by themselves) was there anything else you needed to install. Any splicing or resistors?
Also where does the module install that you bought?
Old Apr 4, 2009 | 09:46 AM
Terrentius's Avatar
Dang, those are awesome!
Old Apr 4, 2009 | 09:56 AM
I will let him answer, but I'll throw my theory in I assume being HID conversion lights there is no need for resistors. They plug up like any other HID I would think.
Old Apr 4, 2009 | 09:57 AM
I too would like to know where I can get ahold of the module, so I can creep on some peeps
Old Apr 4, 2009 | 10:02 AM
Looks great!
Old Apr 4, 2009 | 11:00 AM
jsmithsole's Avatar
*moderator*
Here's a pic with all the lights on...
Old Apr 4, 2009 | 11:02 AM
jsmithsole's Avatar
*moderator*
They truly are plug and play, just had to drill holes in the cap to run wires through, and yes the module is a separate deal...
Old Apr 4, 2009 | 11:08 AM
jsmithsole's Avatar
*moderator*
KP Technologies makes all kinds of cool modules/fixes for cars. I spoke with Kevin the owner and got him a test car to make sure the fog module worked and it does. It is a bit more involved as far as install goes but I did it myself in a couple of hours...
http://www.kptechnologies.com/index.php
Info on the install:
http://kptechnologies.com/forums/vie...hp?f=30&t=1094
Old Apr 4, 2009 | 11:30 AM
That 3rd pic should be your new sig.
Old Apr 4, 2009 | 11:54 AM
I VIK I's Avatar
You know I bought this a while ago, couldnt figure out how to install it (this was before the writeup) and then eventually I lost the module somewhere.
Old Apr 4, 2009 | 12:01 PM
I agree this setup looks bad to tha bizzie bone!
Old Apr 4, 2009 | 12:02 PM
so are you saying the HID bulbs you got dont just snap and twist into the original fog light housing?
Old Apr 4, 2009 | 12:07 PM
KCMAXX's Avatar
KC's FINEST
J, are they better than the PIAA's?
Old Apr 4, 2009 | 12:16 PM
I want to try out the push button start from Kevin! be sick
Old Apr 4, 2009 | 03:49 PM
jsmithsole's Avatar
*moderator*
Yes, WAAAAAAY better/brighter/yellower I would go for it!
Old Apr 4, 2009 | 04:13 PM
jsmithsole's Avatar
*moderator*
Yes but there are wires that go to the ballasts. I suppose a professional would use the rubber grommet they provide and cut a bigger hold in the cap, but I'm no pro!
Old Apr 4, 2009 | 04:14 PM
blaxima06's Avatar
When you drilled a hole in the cap, how big is the hole so the wires can run through them?
Old Apr 4, 2009 | 04:37 PM
BLACKNESS MONSTA's Avatar
Looks AWESOME...Love the new sig also
Old Apr 4, 2009 | 08:04 PM
Kryogen's Avatar
I love mine also. Good choice
Old Apr 4, 2009 | 08:06 PM
Kryogen's Avatar
I personally cut the HID wires and threaded them through the OEM cap. I'd rather cut the wires than the OEM seal cap.
Old Apr 4, 2009 | 10:23 PM
jsmithsole's Avatar
*moderator*
Yeah probably what I should have done. I made sure it was sealed up good though!!
Old Apr 5, 2009 | 12:18 AM
ramberg's Avatar
GrandPa
It looks good. Do you have a link for the bulbs? Thanks
Old Apr 5, 2009 | 07:21 AM
KCMAXX's Avatar
KC's FINEST
HID LINK
Old Apr 5, 2009 | 08:46 AM
Wantastic's Avatar
looks good. good job
Old Apr 5, 2009 | 09:30 AM
BadBlackMaxSL's Avatar
Close Encounters of the Maxima Kind!! Looks tight, J.
Old Apr 5, 2009 | 12:59 PM
ramberg's Avatar
GrandPa
Thanks KC for the link.
Old Apr 5, 2009 | 08:55 PM
eK9aT10pSi's Avatar
how does this compare to the other thread of the DIY where i believe you just cut one wire and ground another to have the same effect? [cant find the link at the moment ... still searching for it]
Old Apr 6, 2009 | 12:29 AM
jsmithsole's Avatar
*moderator*
Not sure what you are talking about but find the link and we'll see!
Old Apr 6, 2009 | 03:57 PM
eK9aT10pSi's Avatar
here you go!
http://forums.maxima.org/6th-generat...-write-up.html
Old Apr 6, 2009 | 03:59 PM
eK9aT10pSi's Avatar
jsmithsole, it was on your how to page as well, lol.
http://forums.maxima.org/6th-generat...pecs-info.html
Old Apr 6, 2009 | 09:25 PM
redmaxima06's Avatar
looks vevy good man
Old Apr 7, 2009 | 08:46 AM
jsmithsole's Avatar
*moderator*
Sorry, I thought you we're talking about the HID install not the fog module. I went with KP because that is what they do, and this module and the wiring is all set/cut to fit our cars.
Old Apr 14, 2009 | 12:48 AM
jsmithsole's Avatar
*moderator*
Oh yeah forgot to add the HDR pic I did!!!
Blended six different frames together, came out pretty cool...
Old May 10, 2009 | 01:05 PM
eK9aT10pSi's Avatar
how was the module install? i.e. the wiring? was it plug-n-play or cut/splicing?
The Frye
Sep 2, 2021 11:03 AM
MaxLife17
Jun 27, 2019 01:37 PM
Vistance
Sep 17, 2015 05:17 AM
mpbclutch33
Sep 8, 2015 06:21 PM
MaxLife17
Sep 8, 2015 02:36 PM
